Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 09-03-2004, 12:02 AM   #1
1 Rivet Short
krowsea's Avatar
Profile:
Inner space......
.....the aluminum frontier.
As I work my way through my '75 Sovereign, I've noticed that quite a bit of the factory hardware and such are screwed to the inner walls. Having perused the outer skin of my A/S many times, and noticing it doesn't look like a porcupine with a wealth of sheet metal screws sticking out of it, I'm going to make a giant leap of faith and assume there is some type of space between the inner and outer walls.
Does anyone know how thick that inner space is, and is it insulated perchance? I may need to replace a few items, or remount and replace a few screws in the near future. I'm pretty sure if I use a 3/4" X 12" lag bolt, it'll probably protrude through the outer skin. How much fudge factor 'do' I have though concerning the thickness of the space and the length of the screws? Is there any interior way to tell if there is a brace behind the walls, or if I use the original holes, should I feel fairly safe?
I'm not planning on doing any major changes, just repair. On the other hand, a 31' Sovereign with a 6' crystal chandelier, 5 or 6 velvet paintings from Mexico screwed to the walls (including the dogs playing cards, that's a given) on top of astro turf wallpaper would be pretty tasteful if done right, don't you think?
John-Boy
Sarchasm (n): The gulf between the author of sarcastic wit and the person who doesn't get it.
1975 31' Sovereign
2004 Dodge Ram 2500 'Laramie', HEMI
krowsea is offline   Reply With Quote
Old 09-03-2004, 12:49 AM   #2
71_safari's Avatar
Profile:
Images: 12
Well, if you look at the window and door openings you can get a pretty good idea - about 1 1/2 to 2" max. Yes, it is all insulated with fiberglass (the pink stuff).
1971 Safari 23
71_safari is offline   Reply With Quote
Old 09-03-2004, 08:41 AM   #3
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
One way to find the ribs is to look for the inner rivet lines. Unless it is a lap seam, the rivets are into ribs. Stay under an inch on the screw lengths.
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
Toilet for available space TomW Sinks, Showers & Toilets 15 02-04-2006 08:24 PM
idle ?'s about quality of space, life suspiria_2 Full-Timing 21 10-22-2003 07:53 PM
LPG furnace vs elec. space htr. Astrodokk Airstream Motorhome Forums 4 06-25-2003 09:11 PM
Tiny fan to bedroom of Sovereign helps cool and warm the space Joan D'Andrea Cabinets, Counter Tops & Furnishings 2 11-02-2002 12:10 PM
Interior help desired - We need more sleeping space Curtis-79MH General Interior Topics 3 03-19-2002 07:08 PM
