10-11-2014, 02:20 PM
#221
1972 21' Globetrotter
Culver City
So here is the new outrigger mentioned earlier:
And the boxed in c channel:
And that 5x5 box tubing is to support the new axle system I'm going to try out. As far as I can tell, no one has put these on an AS yet. So consider me your test dummy. And if they don't work, I'll put a more traditional axle on there. But figured someone had to try these sooner or later:
It's the Timbren axle-less suspension.
Okay fellas, rip me a new one! I'm ready for it!
10-11-2014, 08:23 PM
#222
1999 34' Excella
Hillsboro
Hey, your trailer! Your work!!! Good luck!
Btw. Welds appear to have good stick.. I suggest you move your "heat" (the really bright part of the arc) more onto each side. That will push heat out as well as give you more "hang time" over a spot.
Next, where you "boxed", you want to seP the gap where the pieces come together. Just touching will allow water to stay in there and rust unseen.
Peace and Blessings..
Channing
WBCCI# 30676
10-11-2014, 10:10 PM
#223
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
I tried replacing the shower pan. Please help.
Have you considered how hard your axle solution is going to be to initially align properly?
It is also going to want to twist the frame rail. You are going to need to account for that by really beefing up the frame. I think you are going to need to run a stout crossmember from rail to rail at each axle center.
I am not saying they wont work, I am saying you really need to think it through.
That solution is really going to place a strong torsion load on that frame rail that was not present when the old axles were in place.
The welds on these cross members are going to need to be very good, ESPECIALLY the welds on the bottom of the rail. The old axles transferred the torsion load to the opposite mount and the ground through the axle beam.
It is also my observation that the old axles simply added structure to the frame itself. Their part in making the frame solid should not be underestimated.
I have done lots of swaps in chassis, one thing to remember, as a rule of thumb, one change might mean four more changes are needed. Stuff like this begins to snowball and create problems exponentially, and quickly.
Does this mean I stop swapping stuff because it is too much trouble? Nope, but I have learned to really, really, really think things through before becoming committed to a certain direction.
My thoughts are that when all is said and done you will have found it easier, faster, and better to just go back with torsion axles. I wasn't in love with the notion of torsion axles at first look, but once I really looked at how well the work on Airstreams as an integral part of the trailer I have come to respect them. The only downside to this setup is that they wear out in twenty or thirty years... That is a long time for an axle system that is pretty cheap.
10-12-2014, 03:32 AM
#224
1966 17' Caravel
Newport
, North Carolina
I noticed a square hole is that for a rod of some sort and yes I believe you have learned not to bleed when swimming with the Sharks! What I am asking is if there is a stability rod from one side to the other? Looks interesting I wonder how it will look!
Cliff
Yes I said that! Or did I?
Gotta get busy! Have a great day! Now where did I put those revits?
10-12-2014, 08:22 AM
#225
1982 31' Excella
Hemingford
, Nebraska
Don't want to hijack your thread, but I have a quick question about the shower pan and thought you or your many followers would see it best here. We had to gut (ONLY) the bathroom, buy are having difficulty finding a replacement the shower pan. We have found plenty of 24"x 28" pans, but the drains are all in the upper right corner. Our shower drain (1982 Excella center bath) is in the upper left. We are not experienced plumbers or DIYers, plus we're working on a limited budget, so moving the plumbing is not an option. I'm wondering if the solution is obvious and we're missing it.
10-12-2014, 11:07 AM
#226
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Hi mwernke; I think Airstream service center may have a replacement shower pan that fits your Excella. Since you are not as California Crazy as The Marco, you might find a replacement shower pan is much, much easier than what Marco has done. I'll bet Jackson Center would do an excellent job of replacing it for you while you enjoyed the many amenities of Jackson Center, especially the convenience store that sells pizza by the slice. Imagine that!
Another option is to advertise in the Airstream Classifieds on this forum asking for a used shower pan. There are other Marcos out there who rebuild their Airstreams and may save you the shower pan.
Lastly, many folks have repaired and repainted their plastic shower pans to look as good as new.
The Marco, back to work! A lot of us are enjoying sitting with our favorite beverage watching you learn to weld.
David
10-12-2014, 03:42 PM
#227
Culver City
10-12-2014, 03:52 PM
#228
1999 34' Excella
Hillsboro
put that bar in and measure from trailer ball center to same point left and right before you mount the other suspension device.
Channing
WBCCI# 30676
10-12-2014, 04:34 PM
#229
Culver City
Yeah, I'm being pretty careful with these measurements, they said to do that in the manual for the axles too. It's good advice!
10-18-2014, 05:19 PM
#230
Culver City
Prepped the frame with the POR-15 de-greaser and metal prep, spraying it down with a pressure washer in between.
It did end up with a white residue and I'm hoping that is normal?
My plan is to pain with the POR-15 first thing in the morning. Hopefully someone can tell me about the white stuff before then
Attachment 224629
(White stuff is not in the pictures)
10-18-2014, 06:31 PM
#231
1986 34' Limited
1975 27' Overlander
Conifer
The white stuff is normal. The metal prep is a caustic chemical I believe to etch the "rust" for good paint adhesion.
David
10-18-2014, 06:51 PM
#232
Culver City
Okay perfect, looks like I have plenty of it. Well for anyone using this thread as reference for their shower pan removal. When you use the POR 15 prep, this is what it will look like after you wash it off and it dries:
10-18-2014, 10:57 PM
#233
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Given the average shower pan replacement leads to a total demolition and rebuild of the average Airstream, I'll do my best to avoid that one for a while.
Go Marco!
10-19-2014, 02:24 PM
#234
Culver City
First coat done! Only took 4 hours. And make sure you rubber band the sleeves of your tyvek suit over your rubber gloves. Scrubbing the first layer of your skin off is no fun.
10-19-2014, 02:34 PM
#235
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Attachment 224689
Not the first time a restorer has made that observation. That POR 15 stuff is EVIL. Perhaps you should merely think of it as a temporary tattoo!
Paula
10-19-2014, 03:27 PM
#236
1986 34' Limited
1975 27' Overlander
Conifer
The POR-15 application is a messy job that is well worth the expense and effort. I can see your frame smiling. It will protect it from future rust for a long time. You can add it to your trailer's resume.
But you need to live in cold, wet Minnesota to really appreciate POR-15. The stains on your arm are badges of honor. I did mine laying on my back. Imagine how I looked! No, don't, it will upset your stomach.
David
10-19-2014, 07:13 PM
#237
Culver City
Hahaha, these badges/tattoos look stupid! I got most of it off, leaving the small stuff so my skin can heal a little bit before the next scrubbing.
10-20-2014, 03:22 PM
#238
2019 23' Flying Cloud
Santa Barbara,
Lucy- I think you got some 'splaining to do...
10-23-2014, 11:30 AM
#239
Culver City
I installed the axles and everything is square and symmetrical... Thank God. And I welded the bar across the axles so the won't buckle.
10-23-2014, 12:14 PM
#240
1986 34' Limited
1975 27' Overlander
Conifer
You're a pioneer! The first one that I know of to use this type of axle. We want a full report after your first tow.
David
