Old 08-03-2014, 06:21 PM   #99
The-Marco's Avatar
1972 21' Globetrotter
Culver City , California
Hey Surfpod,
Thanks for the corrosion tip, I will definitely pick some of that up.
My horses are rated for a combined total of 5 tons, and I believe it, have had far heavier things on them. So have no fear
For the outdoor shower I'm going to use the hatch/hole of the battery compartment. Looks like the right size and then I won't have to alter the body.
The-Marco is offline   Reply With Quote
Old 08-03-2014, 06:22 PM   #100
The-Marco's Avatar
Hi Shaggy,
I'll keep the pics coming, and I have also been tracking my hours with a punch clock app, I'll post them for you guys in a bit.
Old 08-03-2014, 06:58 PM   #101
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
You may be disappointed to find that the hose for the outdoor shower is somewhat short (depending on what unit you install...I installed the new AS stainless steel unit), especially if mounted as low as the battery box. That is where I was going to mount mine. But at 6'2" tall, I didn't want to have to stoop over to rinse off. So, I moved the location up a bit.
arktos55343 is offline   Reply With Quote
Old 08-03-2014, 09:43 PM   #102
The-Marco's Avatar
Ugh! My plans foiled again! I'm 6'2 as well. I will look into one with a longer hose or deal with the stooping for how rarely I will probably be using it. Thanks for the heads up though!
Old 08-06-2014, 08:25 PM   #103
The-Marco's Avatar
Almost got all the belly pans off, what a gross job. They are pretty rough so I'm going to make some new ones using these as a template.
Name:	ImageUploadedByAirstream Forums1407378303.513659.jpg
Old 08-06-2014, 08:49 PM   #104
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Are to you DONE yet?????
Looks like great progress! Stay strong!!!
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-06-2014, 09:54 PM   #105
The-Marco's Avatar
Thanks for the encouragement. I am longing for the day that I get to start putting stuff back together. This part is not fun.
The PO added some junk in the back that is making this 10 times harder than it had to be.
Old 08-09-2014, 02:26 PM   #106
The-Marco's Avatar
Bought some aluminum today, 4 sheets of 4x12. They didn't have any C channel to match the airstream size of 1 3/4 inch so I bought this square tube and I'll cut it in half to make my own. Wish me luck as I have never worked with metal before :/
Name:	ImageUploadedByAirstream Forums1407615952.980506.jpg
Old 08-09-2014, 02:30 PM   #107
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Marco.... I think the C channel is thinner than the square you found... making it 'turn the corners' at the rounded ends is challenging... I look forward to how you approach that...
Don't heat this like you might do to steel..
Channing
WBCCI# 30676
Old 08-09-2014, 06:25 PM   #108
The-Marco's Avatar
Thanks cwf, it is MUCH thicker, all of my curves are salvageable so I won't be doing any bending. Thanks for the heads up On not heating it, I didn't know you shouldn't do that.
Old 08-09-2014, 06:46 PM   #109
The-Marco's Avatar
Just got all the plywood for the new floor. I splurged on the marine grade. $100 a sheet. My year (1972) takes 3/4 thick.
I'm going to check the boating forums on how to seal this stuff, unless anyone here has any suggestions?
Name:	ImageUploadedByAirstream Forums1407630645.712775.jpg
Old 08-09-2014, 09:17 PM   #110
e5earley's Avatar
1969 31' Sovereign
Paris , Texas
A few coats of spar urethane will do the trick. It's the same stuff they use to seal the plywood transoms on aluminum boats.
e5earley is offline   Reply With Quote
Old 08-10-2014, 05:22 AM   #111
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
And some folks have used polyurethane and epoxy products to seal up the plywood. Concentrate on the edges as that's an area where water likes to absorb into the wood. There is plenty of information on floor sealers in these forums. Take a look and pick one that suits your fancy.
David
Old 08-10-2014, 01:34 PM   #112
The-Marco's Avatar
I tried replacing the shower pan. Please help.
Thanks David and e5earley. I'll dig into the forums for sure! I never want to have to do this again, so I'll take the time and get it right.
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Shower pan/bench and yellow vanity..HELP! bowhead13 Sinks, Showers & Toilets 0 07-28-2010 08:22 PM
Roto tool is a great help anyone tried it gutsgolf General Interior Topics 14 09-20-2009 03:52 PM
shower pan / shower toastie Sinks, Showers & Toilets 6 10-12-2008 09:58 AM
REplacing Copper in tub/shower HELP!! Sunny51 Plumbing - Systems & Fixtures 0 07-16-2007 08:45 AM
