Old 02-12-2015, 02:37 PM   #323
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Are you going to run the brake electric wiring under/outside belly pan?
Peace and Blessings..
Channing
WBCCI# 30676
Old 02-12-2015, 03:18 PM   #324
The-Marco's Avatar
1972 21' Globetrotter
Culver City , California
I'm running the brake wires up into/under the kitchen cabinets, and then into the walls. If there is ever a problem, I'll just cut those wires off and leave them in the walls, and re-run new wires under the trailer.
The-Marco is offline   Reply With Quote
Old 02-14-2015, 04:26 PM   #325
The-Marco's Avatar
Hired a pro to get my dents out before I put the shell back on. Still just waiting on inca plastics to send my wheel wells.... And they are taking their sweet sweet time
Name:	ImageUploadedByAirstream Forums1423956374.981792.jpg
Old 02-15-2015, 05:05 AM   #326
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Those aluminum banana wraps are a challenging part to make. Compound curves. I'm not too sure where to start if I had to form one on an English wheel. But there are metal workers who can. Amazing.
Tap, tap, tap carefully and I'll bet they turn out pretty good.
I wonder what year the banana wraps went to a molded plastic part? The plastic ones don't dent, they just break. And they are less cost.
David
Old 02-17-2015, 05:16 PM   #327
The-Marco's Avatar
Wheel wells and final floor plywood is installed, this baby is ready for the shell!!!
Name:	ImageUploadedByAirstream Forums1424218529.573865.jpg
Name:	ImageUploadedByAirstream Forums1424218545.107971.jpg
Old 02-17-2015, 07:55 PM   #328
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Look at that California sunshine! Here: snow, wind and 0 degrees. My dog won't even go out in it. New England, much worse. Winters are not fun.
Your wheelhouse came finally. Were they molded? I don't think I've ever seen one like that. Interesting.
Buy a keg and get the guys to carefully place the shell back on.
David
Old 02-18-2015, 01:16 AM   #329
The-Marco's Avatar
Hahaha, I'm dropping the shell down in the morning which should be interesting and terrifying.
As for tonight, I got half of my driveway back!!!!
Name:	ImageUploadedByAirstream Forums1424247395.823455.jpg
Old 02-18-2015, 02:34 AM   #330
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Looking good take your time!
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 02-18-2015, 03:01 PM   #331
The-Marco's Avatar
Just made this piece out of aluminum instead of steel to prevent another corrosive reaction like the one you are seeing up above on the skin
Name:	ImageUploadedByAirstream Forums1424296857.537720.jpg
Old 02-18-2015, 05:51 PM   #332
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
Great work. Those wheel wells look pretty nice. Q How much clearance do you have there above the fat tires? For my still to take life project I'm thinking 6" is the minimum above the rubber with the Timbrens.
truckasaurus is offline   Reply With Quote
Old 02-24-2015, 11:19 AM   #333
The-Marco's Avatar
I am making boxes to extend the clearance of the wheel wells to 5.5 inches above the tires. From the looks of it, those timbrens will only travel about 3 inches. Inca didn't have anything for a single axle that would be tall enough so this is the best I could come up with.
Name:	ImageUploadedByAirstream Forums1424801952.987468.jpg
Old 02-24-2015, 11:56 AM   #334
1960 33' Custom
Good solution
That's a neat idea. When I asked timbren about travel distance they suggested allowing 3" over the full load dimension so you are probably right on the money. I decided I was over analyzing my well needs and just put them in for duplication albeit out of a heavier gauge sheet
I'm still loving the deep dish chrome rims :-)
Old 03-02-2015, 01:30 AM   #335
The-Marco's Avatar
I started a new thread which only got one response, so figured I'd ask my good buddies over here:
For those of you that stay at RV parks, where would you recommend placing my cable tv input and power input on the trailer? Thanks!
Old 03-02-2015, 04:48 AM   #336
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Cable TV? What's that? I have found fewer and fewer RV parks have cable TV available anymore. Folks bring there own antenna. Satellites!
Hook ups are generally available on the street side, usually toward the rear of the trailer. Water and sewer connections are mostly located toward the rear street side.
That's where I located my "utilities" connection points on my Trade Wind project. I carry roughly 20 feet of cord, hose, and sewer hose so I can reach hook ups that don't follow the typical convention.
David
Name:	1406 Electrical New Twist Lock Plug.jpg
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Shower pan/bench and yellow vanity..HELP! bowhead13 Sinks, Showers & Toilets 0 07-28-2010 08:22 PM
Roto tool is a great help anyone tried it gutsgolf General Interior Topics 14 09-20-2009 03:52 PM
shower pan / shower toastie Sinks, Showers & Toilets 6 10-12-2008 09:58 AM
REplacing Copper in tub/shower HELP!! Sunny51 Plumbing - Systems & Fixtures 0 07-16-2007 08:45 AM
