Old 01-28-2015, 06:14 PM   #309
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Cut out with a cut out disk,,,
With a little patience in the corners these things can do a very nice job.
http://i245.photobucket.com/albums/g...g/DSCN1104.jpg
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 01-30-2015, 06:20 PM   #310
The-Marco's Avatar
1972 21' Globetrotter
Culver City , California
Got the fresh water tank plumbing in place, tested my tank monitor, ran water through it, and everything worked!!!!
Name:	ImageUploadedByAirstream Forums1422667233.761050.jpg
Name:	ImageUploadedByAirstream Forums1422667247.259241.jpg
The-Marco is offline   Reply With Quote
Old 01-30-2015, 06:35 PM   #311
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Wait...tank monitors that work? Stop the presses!!
Rocinante is our 2014 International Signature 27FB
Old 02-02-2015, 03:08 PM   #312
The-Marco's Avatar
Gray tank intake plumbing checked off the list!
Name:	ImageUploadedByAirstream Forums1422914883.809214.jpg
Old 02-03-2015, 11:29 AM   #313
1966 22' Safari
Santa Barbara, , California
That looks great ! So. does all that plumbing fit inside the outriggers?
That is exactly almost sorta what I am planning. So I presume that your tanks will tie together with a by-pass for the grey and exit somewhere out the back side of the bumper?
Did you end up getting your tanks at inca?
I'm still at the bellypan removal stage (mostly out , frame looks good,gotta do the POR, then lay it out)
Getting close-
Good to see your progress
John
JRow is offline   Reply With Quote
Old 02-04-2015, 12:09 PM   #314
The-Marco's Avatar
Hey John, yeah all the black pipe is in the curb side rear outriggers. And they will dump out the street side out rigger.
The gray came from some RV store and my fresh and black are from inca. The wheel wells are on their way from inca as well
Old 02-05-2015, 11:58 PM   #315
1966 22' Safari
Marco –I appreciate the info. It Is starting to gel in terms of making this work. I am working with the stock frame depth and want to keep the tanks and plumbing within that space if possible, with the black tank in its original position by the bumper to take advantage of the extra frame doubling. Then I will get a shallow gray to put in the next bay forward or possibly in front of the axle.I will have backflow valves wherever necessary as well as a good flushing out device,and make sure there's enough drop from the tub to that grey tank.
Old 02-06-2015, 07:12 PM   #316
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
T Marco has a unique approach with drain plumbing within the outriggers. I was following another thread where the folks did an install with the tank drains straight out the back of the trailer. I thought I'd post the link so you could see another approach. There are many ways to skin a Globetrotter!
David
http://www.airforums.com/forums/f162...ml#post1577811
Old 02-07-2015, 12:21 PM   #317
The-Marco's Avatar
I'm keeping my dump valves in the original place around the rear street side, they never came out the back and putting them there never crossed my mind. In retrospect, I think it is good that mine are closer to the tire considering how low they hang, and that the back bumper might get pretty close to the ground.
And I finished my belly pan!!!!!
I'm ready to put the shell back on as soon as my wheel wells arrive from inca plastics. They had to do a custom job since my new tires are so wide
Name:	ImageUploadedByAirstream Forums1423336891.297168.jpg
Old 02-07-2015, 12:27 PM   #318
The-Marco's Avatar
Here is another pic, that jagged stuff is from the panorama, it's silky smooth in real life. I do still have to seal all the edges with that vulkem stuff.
Name:	ImageUploadedByAirstream Forums1423337198.717306.jpg
And here are a couple more pics of my wacky axles
Name:	ImageUploadedByAirstream Forums1423337241.336892.jpg
Name:	ImageUploadedByAirstream Forums1423337262.272342.jpg
Old 02-08-2015, 05:30 AM   #319
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I guess i don't know how the early 70s trailers were built. My 66 black tank drained out the back. I'll bet those California Airstream engineers sat there and thought "hey, I'm built to drain out the rear, so why not do it that way with the trailer."
I didn't seal the seams on my belly pan. I decided if rain water gets in there, I want it to drain out. In fact, I drilled 1/4" drain holes in it. Rain water easily enters at the rear bumper storage area as well as other places. Just a thought from a fella who lives in a state where it rains every now and then.
David
Name:	1311 Tank Black Removed.jpg
Old 02-08-2015, 04:12 PM   #320
1966 22' Safari
I have the exact black tank in my 66 Safari. Do you have a working slide-o-magic toilet on your Tradewind? My tank's shot, but Thetford works fine. I haven't pulled it out, and wonder if I need to. The flange is rusted out, wondering if anyone has figured a slip connector to tie into my new tank.
John
Old 02-08-2015, 06:34 PM   #321
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
T Marco's thread is going down the toilet! Your Safari and my Trade Wind are 1966 sisters. My toilet was not working, it was rusted shut. God, what a contraption! I hear people rebuild them.
I purchased a toilet grommet from Inca Plastics. It's the big one on the right. It provides the seal between the tank and the down pipe, and the down pipe OD. Then the new toilet is bolted to the subfloor with a standard toilet mount.
Knowing Marco, he will probably find some space age john for his trailer. Probably will involve microwaves, 4G LTE networks and no water. I can't wait to see it.
David
Name:	1311 Toilet Removed.jpg
ID:	231990   Click image for larger version
Name:	1404 Waste Tanks Grommets.jpg
Old 02-11-2015, 09:14 PM   #322
The-Marco's Avatar
David, you may be a little disappointed in what I went with, but I promise you I started out with my sights set super high with crazy incinerating toilets. But in the end, that approach just didn't make sense.
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Shower pan/bench and yellow vanity..HELP! bowhead13 Sinks, Showers & Toilets 0 07-28-2010 08:22 PM
Roto tool is a great help anyone tried it gutsgolf General Interior Topics 14 09-20-2009 03:52 PM
shower pan / shower toastie Sinks, Showers & Toilets 6 10-12-2008 09:58 AM
REplacing Copper in tub/shower HELP!! Sunny51 Plumbing - Systems & Fixtures 0 07-16-2007 08:45 AM
