Old 01-26-2015, 11:10 AM   #295
1966 22' Safari
Santa Barbara, , California
Bumper & Shear
Speaking of bumpers I'm looking for a 66 Safari fresh bumper. Mine's been dented and straightened a couple of times, and after tank replacement and new skins underneath, it would be great to replace it ( if I can find it)
I also was wondering if in anyone's experience cutting aluminum i.e. the belly pan, any power shear works much better than any other. I was looking at a Malco attachment to my power drill. The other was a Milwaukee power shear which doesn't look like it cut says smoothly. There are several jaw options for the Malco, and I am not sure which works best on aluminum.
For starters I am cutting the belly pan ahead of the axle, and replacing it later with fresh material. So right now it is straight cuts only, but I'm sure there will be curves before I am done. Thanks for any help fellow streamers.
Marco, I have really been enjoying watching your progress and solutions. Thanks for posting them all. I'm just up the coast a hundred miles having my own fun!
JRow is offline   Reply With Quote
Old 01-26-2015, 11:45 AM   #296
The-Marco's Avatar
1972 21' Globetrotter
Culver City , California
Hey Jrow! We might have to meet up if you ever make it down to LA! I'm about to do the belly pan myself...
My plan: use my old pieces as templates for the most part, and then cut them out using an angle grinder with a metal cut-out wheel on it. I've always hated sheers for some reason, but I have to admit, I may have always been using the wrong ones.
Then to reattach the skins I kinda wanted to use self tapping screws instead of rivets... Unless anyone can let me know why this is a bad idea (please hurry and tell me now!) I see a benefit to being able to easily remove these panels because I plan on taking the trailer to some rocky areas that may gouge holes in the bottom.
The-Marco is offline   Reply With Quote
Old 01-26-2015, 07:58 PM   #297
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Here is the power "nippers" I purchased that did a pretty good job. Several makes sell them. It looked to me like the head was the same, just the power drill was different, e.g. Milwaukee, DeWalt, Kawasaki, etc.
David
Name:	1406 Belly Sheet Cutting.jpg
dbj216 is online now   Reply With Quote
Old 01-26-2015, 10:09 PM   #298
1966 22' Safari
Hey thanks for the input. Marco, are you talking about an abrasive the disc onto angle grinder, or a fine tooth blade?I probably wouldn't mind a fine blade if I could find carbide with a negative rake on it, so it wouldn't get go on the first cut. But something about grinding through such a soft material makes me think that it would get gummed up in give you a ragged edge, The challenge of curved cuts would be even greater.
And as far as you're tool goes, David, I think that would work fine, however I have already about 4 or 5 drill motors. I have the Malco aviation shears that look like giant scissors, and cut like butter, but your hand gets pretty tired. I saw a sheer that attaches to your drill with a strap that clamps on, and saw a YouTube that made it look easy to get into tight areas. The question I have is that I don't know which one to get. They seem to have very short tips or longer cutting blades. I can't seem to find a recommendation for thin aluminum, straight and curved shapes. I know this is common stuff to some people.
John
Old 01-27-2015, 02:29 PM   #299
The-Marco's Avatar
Hey John,
Here is what I use, and you will go through a few of them depending how good you get. I have no trouble at all going around curves and have cut (really ugly) circles using these as tight as 3 inches across. As for the edge, I just grind it smooth afterward using the side of the same wheel.
Name:	ImageUploadedByAirstream Forums1422394183.458115.jpg
Old 01-27-2015, 02:32 PM   #300
The-Marco's Avatar
Did this whole area this morning and officially screwed down my first floor panel and boy did it feel good! I used the self tapping screws instead of elevator bolts and those things are amazing. So easy.
Name:	ImageUploadedByAirstream Forums1422394314.750088.jpg
Name:	ImageUploadedByAirstream Forums1422394327.565905.jpg
Name:	ImageUploadedByAirstream Forums1422394345.519409.jpg
Old 01-27-2015, 02:56 PM   #301
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Cutting Belly Pan
I started by cutting my belly pan with a dremel and ended up switching to an angle grinder - much faster! Looking for 5 ft width aluminum sheet now to fil the hole when I am done.
BambiTex is offline   Reply With Quote
Old 01-27-2015, 03:59 PM   #302
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Harbor Freight sells an air shear that I used to cut my whole belly pan and wraps. Cost about fourteen bucks, worked like a champ, if you've got a big old air compressor to run it.
Not sure where y'all are buying your aluminum, but I bought mine at ABC Supply (in Gainesville Fl) for about forty bucks per 4x10 sheet. Don't remember all the specifics on it. It was .032 thickness IIRC... a bit thicker than the original, but it formed up very nice for the wraps.
-Red, big head, short memory...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 01-27-2015, 10:04 PM   #303
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
yeah guys! go for it!
I think you have succeeded in replacing the shower pan.
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-27-2015, 10:08 PM   #304
millertimeUS's Avatar
1976 25' Tradewind
Another vote for the pneumatic nippers, they are like a jig saw for aluminum. Super easy to make tught curves.
I also used the HF shears, they are great for straight cuts but I found to hard to control on any curve.
The combination of pneumatic shears and nippers worked great on my new belly pan.
76 'Airstream Tradewind
Matt
millertimeUS is offline   Reply With Quote
Old 01-28-2015, 12:31 PM   #305
The-Marco's Avatar
If you are gonna put these jacks in, make sure you do it before you put everything back together and get a good game plan for the order you do things with the belly pan install. I half planned it and got super lucky, I ended up having to weld a bracket to the frame for it to screw into, which could have been a nightmare.
Name:	ImageUploadedByAirstream Forums1422473505.771649.jpg
Old 01-28-2015, 01:16 PM   #306
The-Marco's Avatar
I cut this beauty with the angle grinder:
Name:	ImageUploadedByAirstream Forums1422476204.341113.jpg
Old 01-28-2015, 02:21 PM   #307
Panama Red's Avatar
Obrien , Florida
Nice!!!
-Red, jealous of the mad side grinder skills...
Old 01-28-2015, 03:12 PM   #308
calais66's Avatar
1951 21' Flying Cloud
Sacramento , California
Nothing feels better under your feet than a new subfloor! Congrats in the milestone
calais66 is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
Shower pan/bench and yellow vanity..HELP! bowhead13 Sinks, Showers & Toilets 0 07-28-2010 08:22 PM
Roto tool is a great help anyone tried it gutsgolf General Interior Topics 14 09-20-2009 03:52 PM
shower pan / shower toastie Sinks, Showers & Toilets 6 10-12-2008 09:58 AM
REplacing Copper in tub/shower HELP!! Sunny51 Plumbing - Systems & Fixtures 0 07-16-2007 08:45 AM
