Old 12-19-2014, 05:11 PM   #267
The-Marco's Avatar
1972 21' Globetrotter
Culver City , California
I tried replacing the shower pan. Please help.
That doesn't look too shabby either! You guys have been holding out on me this weekend I'll be finalizing the tank selection and I'll order these things Monday
Do you drill your own holes and put on your own fittings, or have the factory do it?
The-Marco is offline   Reply With Quote
Old 12-19-2014, 06:31 PM   #268
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
T Marco, Neither! I used, and I recommend the grommet fittings that Inca Plastics sells. They work great. I too work in a rotomolding factory and make diesel fuel tanks similar to the ones Titan sells. We use grommet fittings for fuel out and fuel return. They are leak free.
The rubber grommet is molded with a sealing ring that presses into the tank. Then when the ABS pipe is installed, it "presses" the sealing diameter tight to the tank. It works good. The ABS pipe protrudes through the subfloor and ready to receive the drain line.
Here is a photo of the Inca Plastics grommets. I figured out where my toilet, sink drain lines and tank vents would penetrate the floor, and then hole sawed the floor to clear the ABS pipe. Then I mounted the tanks and marked them through the holes in the sub floor. Now I know where to drill the tanks and mount the grommets. Finally I remounted the tanks and pushed my ABS pipe connectors into the grommet. Done! A flexible seal that is quite durable.
A picture is worth a thousand words...
David
Name:	1312 Plumbing New Holding Tanks Grommet Side View.jpg
ID:	228902   Click image for larger version
Name:	1404 Waste Tanks Grommets Installed.jpg
Old 12-20-2014, 06:19 AM   #269
Sub'd
Stream Life is offline   Reply With Quote
Old 12-20-2014, 07:06 PM   #270
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Well hello Stream Life. Welcome to Air Forums. Maybe you're interested in old Globetrotters like T Marco and I. All marco wanted to do was repair a cracked shower pan in his trailer. One thing lead to another and bam! He's doing a total renovation.
Poor fellow...
David
Old 12-21-2014, 01:47 AM   #271
The-Marco's Avatar
David, thanks so much for the pictures and explanations, I don't know how this happened, but in my extensive research I was still left thinking that the things you just showed me were done by the factory (On other tanks I've seen). I was stressing about making diagrams for them because I couldn't really predict exactly where everything was gonna go without having the tanks in front of me. I'm so relieved! Thanks again buddy!
Old 12-21-2014, 06:44 AM   #272
Poor fellow...
David
Hello! Actually my wife and I are picking up our first airstream at the end of this month and we are beyond excited! It's an '83 Excella 31' that's been completely gutted. When we're done with it, we're going traveling around this continent for about a year and a half to 2 years. We absolutely love this forum!!
Old 12-21-2014, 07:16 AM   #273
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Oh boy stream life. The 31 excella is a very nice rig. You will thoroughly enjoy "building your own Airstream" and then living with what you built! We have an 86 Limited that has been in the family since new. It's a nice large size for comfortable rainy afternoons.
David
Old 12-24-2014, 03:03 PM   #274
The-Marco's Avatar
He's back baby!!!!
Picked up my gray tank today. Time to install this puppy.
Name:	ImageUploadedByAirstream Forums1419458562.423536.jpg
Name:	ImageUploadedByAirstream Forums1419458582.272939.jpg
Old 12-26-2014, 12:36 PM   #275
The-Marco's Avatar
Rails are welded in. I'm ready to start figuring out where to drill the holes in the tank.
Name:	ImageUploadedByAirstream Forums1419622560.942082.jpg
Old 12-26-2014, 02:19 PM   #276
The-Marco's Avatar
Put this tank holding thing-a-jig back on- moved it much closer to the new jack (husky brute). By the way, the husky brute has a lot of great features, but don't let pictures fool you, it's made out of plastic.
Name:	ImageUploadedByAirstream Forums1419628642.970640.jpg
Name:	ImageUploadedByAirstream Forums1419628694.105312.jpg
Name:	ImageUploadedByAirstream Forums1419628712.174437.jpg
Old 12-26-2014, 03:13 PM   #277
2007 27' Safari FB SE
Spokane , Washington
Measure twice and drill once! LOL
shaggy1970AS is offline   Reply With Quote
Old 12-27-2014, 07:04 AM   #278
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Good Morning T Marco. You might not want to drill your tanks until you have the shell back on and have engineered your drain piping according to the location of your shower pan (the original question you had!) You also need to spot the toilet over your black tank or figure out the black tank drain line and vent. Your gray tank and drain lines also need to connect to a vent so water drains smoothly.
I suppose you're going to mount something else on your A frame causing you to move the propane tanks forward. Generator? Solar? Battery box? Spare tire? I've seen all these things mounted on the A frame.
David
Old 12-27-2014, 03:11 PM   #279
The-Marco's Avatar
Thanks for the tip on waiting to drill, I'll hold off for a bit. And you are a smart one! I'm going to be mounting a mini-split AC condenser behind the LP tanks
Today I welded the stuff in for the fresh tank, so I could eliminate the heavy wood that went under it in the original design.
I cut down the weight quite a bit, didn't sacrifice and strength, eliminated the potential for more rotting wood, and made the tank more accessible from under the trailer if I ever needed to get at it again.
Name:	ImageUploadedByAirstream Forums1419718138.306970.jpg
Name:	ImageUploadedByAirstream Forums1419718154.388701.jpg
Name:	ImageUploadedByAirstream Forums1419718171.407146.jpg
Name:	ImageUploadedByAirstream Forums1419718186.389763.jpg
That's about 160lbs of pure Man standing at the center point of just one of the angles. Thankfully I didn't break an ankle trying to get that picture.
Old 12-27-2014, 03:22 PM   #280
The-Marco's Avatar
Name:	ImageUploadedByAirstream Forums1419718888.913331.jpg
Now I'm going to weld little plates under the angles for the underbelly sheet to screw into
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Shower pan/bench and yellow vanity..HELP! bowhead13 Sinks, Showers & Toilets 0 07-28-2010 08:22 PM
Roto tool is a great help anyone tried it gutsgolf General Interior Topics 14 09-20-2009 03:52 PM
shower pan / shower toastie Sinks, Showers & Toilets 6 10-12-2008 09:58 AM
REplacing Copper in tub/shower HELP!! Sunny51 Plumbing - Systems & Fixtures 0 07-16-2007 08:45 AM
