Old 10-23-2014, 11:30 AM   #239
The-Marco's Avatar
1972 21' Globetrotter
Culver City , California
I installed the axles and everything is square and symmetrical... Thank God. And I welded the bar across the axles so the won't buckle.
Name:	ImageUploadedByAirstream Forums1414085287.092652.jpg
Name:	ImageUploadedByAirstream Forums1414085340.696463.jpg
The-Marco is offline   Reply With Quote
Old 10-23-2014, 12:14 PM   #240
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
You're a pioneer! The first one that I know of to use this type of axle. We want a full report after your first tow.
David
Old 10-23-2014, 01:38 PM   #241
The-Marco's Avatar
Will do! Although I don't have much experience towing it with the original setup. I'm definitely going to try some crazy driving with it before i slide it back under the shell- and then try more crazy stuff with the shell on before i do the interior.
Old 10-23-2014, 03:27 PM   #242
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
It's fun to suggest jobs for others! I feel like a boss! But not!
You might want to check your axles alignment. Measure from the very front, center of your ball to the center of each spindle. You would expect less than 1/8" difference from left to right side. I used 18 ga automotive wire as it doesn't stretch and I can pull it tight.
You don't want your new frame following the tow vehicle at a 45 degree angle!
David
Old 10-23-2014, 05:05 PM   #243
The-Marco's Avatar
Thanks for the tip on the wire! First I tried string, which was useless- stretched way too much. I ended up getting 2 friends together and did it with measuring tape, the big metal roll kind that has the crank, and by some miracle it was almost exactly the same. The spindles can be adjusted a little too, which I was expecting to have to do, but nope, they were perfect.
Old 10-24-2014, 06:23 PM   #244
The-Marco's Avatar
Hub thingies and electric brakes installed and greased up.
Name:	ImageUploadedByAirstream Forums1414196562.567129.jpg
Old 10-24-2014, 07:22 PM   #245
The-Marco's Avatar
Don't worry, I have something better picked out (for the rims), plus these axles are for highway tires, not trailer tires, so I can get something better than the stuff offered for trailers.
Name:	ImageUploadedByAirstream Forums1414200172.001436.jpg
Old 10-25-2014, 07:13 PM   #246
The-Marco's Avatar
I'm so excited to be putting things back onto the trailer!!!
Name:	ImageUploadedByAirstream Forums1414286001.222343.jpg
Name:	ImageUploadedByAirstream Forums1414286016.449772.jpg
Old 10-26-2014, 08:07 AM   #247
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
You'll get a lot more excited when the shell goes back on!
Keep on going...
David
Old 10-26-2014, 08:28 AM   #248
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Now you ah e a trailer to go buy your wood for the floor!
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-26-2014, 09:40 AM   #249
The-Marco's Avatar
Way ahead of you cwf, the wood is already cut and everything!
Old 10-26-2014, 09:51 AM   #250
2007 27' Safari FB SE
Spokane , Washington
Looking good Marco, making great progress.
shaggy1970AS is offline   Reply With Quote
Old 10-27-2014, 09:13 PM   #251
The-Marco's Avatar
Does anyone know where to get the bolts to put the bumper back on? I had to chop mine off. It was nice how they sunk flush into the bumper.
Old 10-27-2014, 09:16 PM   #252
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
Good hardware stores carry a similar bolt in Grade 8 or better. But you may have to grind down the diameter of the head a bit for a perfect fit.
arktos55343 is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
Shower pan/bench and yellow vanity..HELP! bowhead13 Sinks, Showers & Toilets 0 07-28-2010 08:22 PM
Roto tool is a great help anyone tried it gutsgolf General Interior Topics 14 09-20-2009 03:52 PM
shower pan / shower toastie Sinks, Showers & Toilets 6 10-12-2008 09:58 AM
REplacing Copper in tub/shower HELP!! Sunny51 Plumbing - Systems & Fixtures 0 07-16-2007 08:45 AM
