Old 10-12-2014, 08:22 AM   #225
1982 31' Excella
Hemingford , Nebraska
Don't want to hijack your thread, but I have a quick question about the shower pan and thought you or your many followers would see it best here. We had to gut (ONLY) the bathroom, buy are having difficulty finding a replacement the shower pan. We have found plenty of 24"x 28" pans, but the drains are all in the upper right corner. Our shower drain (1982 Excella center bath) is in the upper left. We are not experienced plumbers or DIYers, plus we're working on a limited budget, so moving the plumbing is not an option. I'm wondering if the solution is obvious and we're missing it.
mwernke is offline   Reply With Quote
Old 10-12-2014, 11:07 AM   #226
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi mwernke; I think Airstream service center may have a replacement shower pan that fits your Excella. Since you are not as California Crazy as The Marco, you might find a replacement shower pan is much, much easier than what Marco has done. I'll bet Jackson Center would do an excellent job of replacing it for you while you enjoyed the many amenities of Jackson Center, especially the convenience store that sells pizza by the slice. Imagine that!
Another option is to advertise in the Airstream Classifieds on this forum asking for a used shower pan. There are other Marcos out there who rebuild their Airstreams and may save you the shower pan.
Lastly, many folks have repaired and repainted their plastic shower pans to look as good as new.
The Marco, back to work! A lot of us are enjoying sitting with our favorite beverage watching you learn to weld.
David
Old 10-12-2014, 03:42 PM   #227
The-Marco's Avatar
1972 21' Globetrotter
Culver City , California
Okay guys, I think I may have alleviated many concerns with my work this morning and yes, there will even be a tube running between the axles. And that hole in the boxes is an access hole to bolt the axles in. And so I can paint in there.
Name:	ImageUploadedByAirstream Forums1413150101.537911.jpg
ID:	224216Click image for larger version
Name:	ImageUploadedByAirstream Forums1413150110.887657.jpg
Name:	ImageUploadedByAirstream Forums1413150126.365561.jpg
Name:	ImageUploadedByAirstream Forums1413150138.548214.jpg
Name:	ImageUploadedByAirstream Forums1413150149.528160.jpg
The-Marco is offline   Reply With Quote
Old 10-12-2014, 03:52 PM   #228
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
put that bar in and measure from trailer ball center to same point left and right before you mount the other suspension device.
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-12-2014, 04:34 PM   #229
The-Marco's Avatar
Yeah, I'm being pretty careful with these measurements, they said to do that in the manual for the axles too. It's good advice!
Old 10-18-2014, 05:19 PM   #230
The-Marco's Avatar
Prepped the frame with the POR-15 de-greaser and metal prep, spraying it down with a pressure washer in between.
It did end up with a white residue and I'm hoping that is normal?
My plan is to pain with the POR-15 first thing in the morning. Hopefully someone can tell me about the white stuff before then
Attachment 224629
(White stuff is not in the pictures)
Name:	ImageUploadedByAirstream Forums1413674304.289807.jpg
Old 10-18-2014, 06:31 PM   #231
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
The white stuff is normal. The metal prep is a caustic chemical I believe to etch the "rust" for good paint adhesion.
David
Old 10-18-2014, 06:51 PM   #232
The-Marco's Avatar
Okay perfect, looks like I have plenty of it. Well for anyone using this thread as reference for their shower pan removal. When you use the POR 15 prep, this is what it will look like after you wash it off and it dries:
Name:	ImageUploadedByAirstream Forums1413679869.107027.jpg
Old 10-18-2014, 10:57 PM   #233
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Given the average shower pan replacement leads to a total demolition and rebuild of the average Airstream, I'll do my best to avoid that one for a while.
Go Marco!
Old 10-19-2014, 02:24 PM   #234
The-Marco's Avatar
First coat done! Only took 4 hours. And make sure you rubber band the sleeves of your tyvek suit over your rubber gloves. Scrubbing the first layer of your skin off is no fun.
Name:	ImageUploadedByAirstream Forums1413750253.435643.jpg
Old 10-19-2014, 02:34 PM   #235
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Attachment 224689
Not the first time a restorer has made that observation. That POR 15 stuff is EVIL. Perhaps you should merely think of it as a temporary tattoo!
Paula
Old 10-19-2014, 03:27 PM   #236
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
The POR-15 application is a messy job that is well worth the expense and effort. I can see your frame smiling. It will protect it from future rust for a long time. You can add it to your trailer's resume.
But you need to live in cold, wet Minnesota to really appreciate POR-15. The stains on your arm are badges of honor. I did mine laying on my back. Imagine how I looked! No, don't, it will upset your stomach.
David
Old 10-19-2014, 07:13 PM   #237
The-Marco's Avatar
Hahaha, these badges/tattoos look stupid! I got most of it off, leaving the small stuff so my skin can heal a little bit before the next scrubbing.
Old 10-20-2014, 03:22 PM   #238
1966 22' Safari
Santa Barbara, , California
Lucy- I think you got some 'splaining to do...
JRow is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
Shower pan/bench and yellow vanity..HELP! bowhead13 Sinks, Showers & Toilets 0 07-28-2010 08:22 PM
Roto tool is a great help anyone tried it gutsgolf General Interior Topics 14 09-20-2009 03:52 PM
shower pan / shower toastie Sinks, Showers & Toilets 6 10-12-2008 09:58 AM
REplacing Copper in tub/shower HELP!! Sunny51 Plumbing - Systems & Fixtures 0 07-16-2007 08:45 AM
