Old 08-17-2014, 06:45 PM   #155
The-Marco's Avatar
1972 21' Globetrotter
Culver City , California
The subfloor is cut! Everything pretty much lines up. I didn't expect it to be perfect because I read about the frame skewing without the shell and subfloor on it, thankfully I didn't have to drive it around too much to get it on the other side of my driveway, and I haven't turned it on its side to access the belly pan.
That old piece is in there as kind of a corner stone to line up everything else off of since it's holes were the least destroyed from removing the bolts and I can see through them to the holes in the frame.
Next I'm going to:
1.prep this wood with resin
2.plot out my holding tanks
3.research good insulation for under the floor
4.clean and prep the frame/paint it
5.figure out what to do about the belly pan.
6.seek therapy to pinpoint why I take on hobbies like this to punish myself.
Name:	ImageUploadedByAirstream Forums1408322718.605461.jpg
The-Marco is offline   Reply With Quote
Old 08-17-2014, 07:31 PM   #156
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Man... You may never do another one but you doggone sure are doing a fine job on this one!!!
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-17-2014, 07:32 PM   #157
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
Not a great pic of my skid plate, and my frame has been sandblasted and epoxy coated. The rectangular hole cut in my main frame rail (which weakened the rail) for the black tank drain was eliminated when I had my welder box in the main frame rails from the wheels to the bumper. There is also a hole in the skid plate, which could accommodate a drain line. It originally was for the city water connection, but I relocated that. Sorry for the grainy pic....can't located the original.
arktos55343 is offline   Reply With Quote
Old 08-17-2014, 07:46 PM   #158
2007 27' Safari FB SE
Spokane , Washington
Sand blasting a frame is overkill me thinks, also you lose too much material in the process. Powdercoating is also prone to chipping, and having it rust from inside out. Sand, prep, base and paint is the way to go. Just my opinion.
Marco looking good bro. Your project is got me wanting to pick up a beater and do a complete overhaul but I am not sure if my wife would hang around for it! She has told me another project and she's out! Lmao
shaggy1970AS is offline   Reply With Quote
Old 08-17-2014, 10:58 PM   #159
The-Marco's Avatar
Don't do it shaggy! For the love of god don't do it!
Arktos, thank you so so much for the pic, it cleared everything up for me. The PO welded a bunch of stuff on, which left me guessing what was stock and what was him. That piece seemed very janky to me, especially the hole cut for the incoming water, must have been that factory worker's first day on the job. And the waste hole definitely compromises the integrity of that corner of the frame. I'll figure out how to spice that area up a bit.
Cwf, this will surely be my first and last time doing this. The Airstream Marco Edition is going to be a one-off, I guess that will make it worth buku bucks (spelling?). Jk btw.
Old 08-21-2014, 05:29 PM   #160
The-Marco's Avatar
Okay team! So I started designing my new holding tank system and had a question...
Is there any foreseeable problems with having the shower drain directly into the gray holding tank? I'd hate to have to elevate my shower floor to make room for a P trap and the law of gravity. I'm 6'2 and headroom in the curved roof corner is scarce.
Name:	ImageUploadedByAirstream Forums1408663700.893544.jpg
Old 08-21-2014, 05:38 PM   #161
1972 25' Tradewind
Hopkins , Minnesota
I believe the problem is....without a p-trap, fumes and 'water' can slosh out of your drain/tank while you are towing. I've seen some talk of a valve that can be adapted for this situation..... but you need something to keep all that stuff where it belongs....in the tank.... not on your floors.
Old 08-21-2014, 06:38 PM   #162
The-Marco's Avatar
A valve would be great, I'll look into it. Thanks!
Old 08-21-2014, 07:58 PM   #163
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Yes the shower will act as your black tank vent which would be very much smelly! You need the trap and maybe a gray tank would be much better!
Cliff
Yes I said that! Or did I?
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 08-21-2014, 07:59 PM   #164
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Marco... i would personally prefer gray water "sloshing" up.. than the dumper... Also, Imagine...
you are headed downhill and have to slam on the brakes.. the full load in the tank moves forward....you will need a big shower basin to handle the flow...then have a nice aroma when you stop for the night.
So, I am also 6'2"... and to 'lean over' a bit, or sit on the shower ledge works great.... of course our Excella has a different shaped shell..
Why not build the correct height base and add a seat in the 'shower'? or, do like the SOB's... cut a hole in the roof and install a dome... you can shower and look around outside at the same time!
Channing
WBCCI# 30676
Old 08-21-2014, 08:18 PM   #165
The-Marco's Avatar
Hey Cliff, sorry for my cruddy diagram, but that pie shaped thing is the black tank, it would have its own vent. The box on the bottom is the gray tank.
I looked for a 1-way drain valve thing that would prevent the water and fumes from coming back up- such a thing doesn't exist, so all you inventors out there, I can't speak for everyone, but I'll gladly pay $30 for such a thing.
My best plan so far would be to have a drain I can plug when I'm not using it. I'm still all ears though. I imagine I'd use the plug no matter what anyway.
Cwf,
The dome thing... no. The seat, maybe
Old 08-21-2014, 08:26 PM   #166
reinergirl's Avatar
Hollis , New Hampshire
Here's something that would need less clearance. Hepvo Waterless Valve
Do a search on the forums, I think a few members have used them
Great job you've been doing!
reinergirl is offline   Reply With Quote
Old 08-21-2014, 08:37 PM   #167
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
We used the Hepvo Waterless Valve in our shower as well as the galley sink. So far so good! I think Airstream uses them in the Interstate RV's....not positive tho.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-21-2014, 09:25 PM   #168
The-Marco's Avatar
Reinergirl and Becky,
This thing looks like some kind of evil witch sorcery.... And I'm all about it!!! Thank you so much, this is PERFECT! I'm going to get 3 of these puppies.
P traps seem like a bad idea in a trailer that will be bouncing around, or sitting for a long time, the water will either shake out of the trap or evaporate. But the gremlins that live in this valve will do an amazing job! Thanks again!
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Shower pan/bench and yellow vanity..HELP! bowhead13 Sinks, Showers & Toilets 0 07-28-2010 08:22 PM
Roto tool is a great help anyone tried it gutsgolf General Interior Topics 14 09-20-2009 03:52 PM
shower pan / shower toastie Sinks, Showers & Toilets 6 10-12-2008 09:58 AM
REplacing Copper in tub/shower HELP!! Sunny51 Plumbing - Systems & Fixtures 0 07-16-2007 08:45 AM
