Old 08-15-2014, 07:06 PM   #141
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I think hot and cold water to the bath sink is expected. I use warm water for washing and shaving. It's a luxury since the early 20th century don't you know.
I purchased my waste water tanks from Inca Plastics. They did fine by me. I recommend them. Their on line catalog is huge with many tanks of all kinds of dimensions and shapes.
I'd recommend you sketch out your new layout before making any appliance placements. Plumbing in PEX is easy enough. Place your fixtures where they will work and tie them together with PEX. I found there were so many considerations when "designing" a new interior in an old Airstream. The frame rails and floor "joists" are major factors. The drains and toilet are inside the frame rails because tanks fit inside the frame rails. The shower drain trap goes below the floor, and then must drain above the floor to the tank. The drain tanks need vents that go through the roof. The fresh water tank in my 66 is above the floor in the front of the trailer so it stays heated. The fill port was already there, so I reused it. The plumbing design got tricky for me. A good plan will minimize disappointments later.
Then on to the propane system. And then on to the electrical system, both 12v and 120v. It's like building a small house!
David
Old 08-16-2014, 07:16 PM   #142
The-Marco's Avatar
1972 21' Globetrotter
Culver City , California
If I keep the original tank and rotate it 180degrees I was going to just rout all the important stuff under the kitchen cabinets, because yes, if I didn't, the access hole would be just about at the front door.
I'm still brainstorming all of this though. I think at the moment I'm leaning toward all new tanks.
The-Marco is offline   Reply With Quote
Old 08-16-2014, 07:22 PM   #143
The-Marco's Avatar
David,
Thanks for the message, I definitely have a TON of planning to do, and yeah, I think I'll put the hot water to everything. I'd regret it later if I didn't.
And looks like my outdoor shower plan is gonna work like a charm (going in the battery compartment)
Name:	ImageUploadedByAirstream Forums1408238531.867679.jpg
Old 08-17-2014, 11:26 AM   #144
The-Marco's Avatar
Well it was finally time to take up my entire driveway. As hard as it was working under the shell between the wood frame, at least there was shade.
Wish me luck on the next steps going quickly!
Name:	ImageUploadedByAirstream Forums1408296367.362558.jpg
Name:	ImageUploadedByAirstream Forums1408296383.822199.jpg
Old 08-17-2014, 12:08 PM   #145
2007 27' Safari FB SE
Spokane , Washington
Marco while you got access to the frame I would use a d8 and sand down all the rust and corrosion and apply rustoleum non rust paint and protect the frame from cancer down the road. I rebuilt my boat trailer two years ago and applied duraliner truck protectant to all cross members and wheel wells so no chipping that will lead to rust down the road. If you need pics or questions I am happy to provide my experience. I think doing that to your frame will make it bullet proof and last for years. Cost 150 in paint and duraliner plus sand paper, that's it. I like doing the job right the first time.
shaggy1970AS is offline   Reply With Quote
Old 08-17-2014, 12:45 PM   #146
The-Marco's Avatar
Hey shaggy,
Here was my plan of attack:
Name:	ImageUploadedByAirstream Forums1408301093.534991.jpg
I'm going to see how far I can get using my drill to do the sanding- as my compressor is quite dinky.
I love the idea of the duraliner. Do you think that will stick to the Por15? And can you coat the underbelly skins in it?
Old 08-17-2014, 12:51 PM   #147
The-Marco's Avatar
Just got the remaining boards separated from the frame.
For the elevator bolts you can access from the edges I recommend grabbing them by the square nut from the underside with vice grips and wiggling till they break off.
The ones you have to remove from the top are a pain, I used an angle grinder, a cup of water so the wood wouldn't catch fire, and a hammer, chisel, and finally a punch to push the remnants of the bolt through. It was not pretty.
Name:	ImageUploadedByAirstream Forums1408301491.043889.jpg
Old 08-17-2014, 01:24 PM   #148
Marco, looks like your on the right track. D8 and 40 gallon compressor is the way to go! I stripped sanded, taped, primed, duraliner and painted and took me two full days. The duraliner stuff I bought at napa paint store and it bonded to the primer without a problem. Used one quarter of one quart. A little goes a long way.
Pics on how the duraliner looks and how it turned out.
Old 08-17-2014, 01:25 PM   #149
The-Marco's Avatar
Do any of your 1972 21footers have this extra bit welded to your frame? On the street side rear of your trailer? Can't tell if this was done by the PO. It is not on the curb side.
Name:	ImageUploadedByAirstream Forums1408303497.396906.jpg
Old 08-17-2014, 02:24 PM   #150
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I used the POR-15 on a few frames....it's great stuff. I think it would have been easier to fix the shower pan crack in place, but you're sure doing a thorough job!! Thanks for your fun thread!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-17-2014, 02:42 PM   #151
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
That's your skid plate. If it has a hole in it, your drain line can run through it. Mine also had the fresh water intake spigot located there.
arktos55343 is offline   Reply With Quote
Old 08-17-2014, 03:56 PM   #152
The-Marco's Avatar
Thanks arktos, would you be able to send me a picture of yours when you get a chance? I'd really appreciate it!!!!
Old 08-17-2014, 03:59 PM   #153
The-Marco's Avatar
I tried replacing the shower pan. Please help.
Feels great to finally be creating something, rather than demolishing! This marks the very first thing I fixed/made for the trailer!!!!
Name:	ImageUploadedByAirstream Forums1408312716.498124.jpg
This template will allow me to make an excellent replacement for this rotted piece
Old 08-17-2014, 04:00 PM   #154
The-Marco's Avatar
Oh wait...
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Shower pan/bench and yellow vanity..HELP! bowhead13 Sinks, Showers & Toilets 0 07-28-2010 08:22 PM
Roto tool is a great help anyone tried it gutsgolf General Interior Topics 14 09-20-2009 03:52 PM
shower pan / shower toastie Sinks, Showers & Toilets 6 10-12-2008 09:58 AM
REplacing Copper in tub/shower HELP!! Sunny51 Plumbing - Systems & Fixtures 0 07-16-2007 08:45 AM
