Old 03-01-2016, 02:21 AM   #1
B_Boult's Avatar
1955 26' Cruiser/Overlander
Vancouver , British Columbia
Images: 21
Humphreys Lamp
Finally installed lamp and run gas line.
Lamp is easy to light and really quiet. Nice warm glow for the evening.
Used a solid mantle instead of tie on fabric one.
Excuse walls will get flaking paint all sorted later.
ID:	258020   Click image for larger version
"You'll Never Walk Alone"
B_Boult is offline   Reply With Quote
Old 03-01-2016, 08:35 PM   #2
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Hey B,
We have the same lamp. Love the light, love the heat on a chilly morning. Make sure you crack the roof vent.
Tim
Beaker63 is offline   Reply With Quote
Old 03-01-2016, 08:45 PM   #3
B_Boult's Avatar
Images: 21
Always
Old 03-01-2016, 09:27 PM   #4
Beaker63's Avatar
1963 16' Bambi
Hey B,
Do you have a name and number for the solid mantle? I've been using the tie on mantels and they always seem to fall apart just when you need them.
On several occasions the glass globe has fallen off onto the table but never broken, make sure you don't have any loose screws. Check the lamp too.
Tim
Old 03-11-2016, 09:35 PM   #5
B_Boult's Avatar
Images: 21
well I have one missing screw on globe. But I snug the globe up well enough.
The mantles can be bought on Vintage trailer supply. You might need to change your burner nose to put on mantle. when traveling you just place mantle back in container which is also designed so you can put mantle back on without toughing it.
I should buy a spare one.
Nice to have lamp running though. It helps keep trailer warm in winter and I use less battery power.
Seeking Replacement Stoplight Lamp Housing AirConditioner Electrical - Systems, Generators, Batteries & Solar 0 02-14-2005 06:46 PM
Humprey's gas lamp mantle 53flyingcloud LP Gas, Piping, Tanks & Regulators 3 05-10-2004 01:26 AM
Recessed lamp question uwe Electrical - Systems, Generators, Batteries & Solar 2 03-11-2004 09:45 PM
