Old 05-26-2016, 07:01 PM   #1
how to get tambour doors out to paint them
I want to paint my faux dark brown tambour bulkhead doors white. How do I remove them? I have removed various screws from the side brackets, but the wont budge. I am planning on using Diamondhard Acyrilic Enamel in a sprayer
ebarrett is offline   Reply With Quote
Old 05-26-2016, 08:04 PM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Welcome to the forum:
In order to properly serve you it would be helpful if you included year, model and trim level of your Airstream. While tambour has been prevalent across the many years Airstreams have been produced, I'm sure there have been many different ways it has been installed.
As for my tambour in my 310 I removed the track with the tambour still in place, light scuff with an abrasive pad (fine), clean with a good cleaner like Spray Nine, masked off the track and handle and then spray painted the tambour that would show with the door closed.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 05-27-2016, 04:56 PM   #3
It is a 1976 Argosy. It tried to roll them up tight and push over to one side and wiggle the other end out.. There doesnt seem to be any play . Is there a trick to it popping them out ?
All access panel locks damaged... can I drill them to open them? flaagan Exterior Storage Compartments & Access Doors 13 05-19-2015 03:42 PM
Keep them or send them back? JimW Tires 11 05-04-2010 01:01 PM
Reinforcing Tambour Doors Navigator Cabinets, Counter Tops & Furnishings 1 03-04-2004 11:28 PM
repaired the tambour doors remcolent Cabinets, Counter Tops & Furnishings 12 01-13-2004 08:02 PM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 08:34 AM
