03-01-2015, 12:10 PM
1978 25' Tradewind
Metro Phoenix
How to find the center-line on the floor?
OK, my new dinette is coming together, but I need to make sure that things are parallel and perpendicular and stuff.
And for that, I need to find the center-line. I need to make a fine Sharpie line right down the middle of the (still bare plywood) floor.
Seems like the exact center of the front window and the exact center of the rear window would be easy-to-find reference points, but there's furniture in front of both of them, and no easy way to transfer that position to the floor.
Does anybody have a quick easy method of laying out a center-line?
"Between what matters and what seems to matter, how should the world we know judge wisely?" - E.C. Bentley, Trent's Last Case
03-01-2015, 12:23 PM
, At Large
On some newer model trailers, there is a steel brace running fore-and-aft down the center line. A stud finder would help you locate it.
03-01-2015, 12:26 PM
1978 25' Tradewind
Metro Phoenix
Unfortunately, mine is a 1978. I'll give it a shot, though.
Thanks!
03-01-2015, 12:27 PM
1980 24' Caravelle
corpus christi
I would use a string with thumb tacks first. Tack down front and back measure and move as needed to get center.
03-01-2015, 12:29 PM
1980 24' Caravelle
corpus christi
Also if your trailer is level side to side find the center of the ceiling then use plumb bob.
03-01-2015, 12:30 PM
1978 25' Tradewind
Metro Phoenix
I'm liking the string with thumb tacks. Thanks!
Now I'm stuck on "how do I figure out where to put the string?"
03-01-2015, 12:51 PM
2012 25' FB Eddie Bauer
Virginia Beach
Plane geometry memory... Pick a point on each side of the trailer - say the front of the wheel wells and with a compass (or string and chalk) draw a semi-circle big enough to cross the center line, then do the same from the front of the other wheel well keeping the length of the string exactly the same. The two points where the semi-circles cross will be directly on the centerline. Use a straight edge and draw the line, extending from front to back.
Of course where that can go wanky is if the side to side points are 1/3 of an inch off.
Paula
03-01-2015, 12:56 PM
2007 22' International CCD
Corona
Try a laser level that projects a line up the wall as well as across the floor to find window center.
Sent from my pocket Internet using Airstream Forums
03-01-2015, 04:52 PM
1978 25' Tradewind
Metro Phoenix
Well, what I ended up doing was this. I ran a string from the bottom center of the front window to the bottom center of the back window, held on with gorilla tape. This gave me a center line about 3 feet off the floor.
The I used an L square with an extension to transfer that line to the floor. I used a long board crossways to reduce the inaccuracy due to the undeveloped floor. I had a roll of 8" aluminum flashing that made a great straight edge.
Of course, there was my usual amount of fiddling and remeasuring.
Thanks for all the great input!
03-01-2015, 04:54 PM
1978 25' Tradewind
Metro Phoenix
That would be "uneven" floor. Dang autocorrect!
03-01-2015, 06:01 PM
1980 24' Caravelle
corpus christi
It works.
03-02-2015, 04:03 PM
Dallas Center/Des Moines
, Iowa
The Handyman has it right.
