Old 09-26-2014, 11:28 AM   #1
Westminster , Colorado
How do I get this wall out?
I have a 59 overlander, and I can't figure out how to get to the screw behind the propane heater to get it out, to subsequently get the wall out. Ideas?Click image for larger version
painterfam is offline   Reply With Quote
Old 09-26-2014, 11:48 AM   #2
Originally Posted by painterfam View Post
I have a 59 overlander, and I can't figure out how to get to the screw behind the propane heater to get it out, to subsequently get the wall out. Ideas?Attachment 222901
Airstream's are built in layers.
You will have to remove some that is blocking the panel.
Old 10-02-2014, 09:01 PM   #3
B_Boult's Avatar
1955 26' Cruiser/Overlander
Vancouver , British Columbia
Images: 21
I took my furnace and wall out of my 1955. Most of what you are looking at is probably not going to be reused, so pulling it out in pieces is ok. The top of the walls and cabinetry is screwed into the inner shell and sometimes screws are well hidden but once the top is loosened the wall should slide out of the curved aluminum channel which is riveted to the inner skin.When taking walls out of my 55 Overlander. I just pulled out in pieces, walls I was not going to use. The furnace is screwed into it and also to the floor.
Hope that helps
"You'll Never Walk Alone"
B_Boult is offline   Reply With Quote
To wall or not to wall foto4peter Upholstery, Blinds, Walls & Interior Finishes 4 04-09-2013 11:44 PM
Wall to Ceiling attachment - Head Wall 2003 25' safari Clawdan General Interior Topics 1 11-27-2011 10:01 AM
wall covering??? leather, Wall paper Josh Loki General Interior Topics 1 07-02-2011 10:16 AM
Wall-to-wall carpet alternative mcneon Upholstery, Blinds, Walls & Interior Finishes 9 11-20-2008 01:41 PM
How do you get to the rear wall? AccessMaster Airstream Motorhome Forums 1 08-24-2003 06:27 PM
