Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 02-23-2016, 11:49 AM   #1
1978 31' Sovereign
Arlington , Washington
holes in panels
I'm remodeling 1987 airstream sovereign and wanted get some feedback on how to fill holes in the panels before I paint? Thanks
TMorris is offline   Reply With Quote
Old 02-23-2016, 12:30 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If they are just screw holes put a round head screw in them and paint over.
If they are larger I have used blank ivory 2x4 electrical covers. painting is your option depending on color differences. They go unnoticed.
2004 Excursion 4x4
Old 02-23-2016, 12:48 PM   #3
PKI
PKI's Avatar
Walnut Creek , California
Artwork, you need artwork. Pin striping was developed to salvage chipped or scratched expensive paint. Maybe? It could certainly be an interesting way to draw the eye away from the holes. Always thought a riveted patch to be an acceptable utilitarian solution, but the suggested electrical cover plate is certainly more elegant. Used a mirror to cover a door hole once. Always need a full length mirror to check the cut of your jib. Pat
Old 02-23-2016, 01:07 PM   #4
Kevin245's Avatar
I use rivets in open holes when possible.
William C. Swinney
Old 02-23-2016, 08:06 PM   #5
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Hey Tmorris,
Because I had removed the panels for restoration, I put a piece of duct tape on the back side and filled the front with auto body filler. Sand and paint. If you don't have the panels off just stick a rivet in the hole and paint.
Tim
Beaker63 is offline   Reply With Quote
Adding panels on top of panels instead of replacing? The-Marco Ribs, Skins & Rivets 18 08-02-2014 04:53 PM
New panels, old holes? foto4peter Upholstery, Blinds, Walls & Interior Finishes 14 05-11-2013 09:29 AM
New toilet holes don't match old holes RichHog Sinks, Showers & Toilets 8 03-15-2009 06:36 PM
holes in the skin bhsl8 Ribs, Skins & Rivets 7 01-06-2004 05:52 PM
Wingard batwings and holes in the roof Dave Jenkins Our Community 5 09-04-2003 11:10 PM
