Old 09-05-2016, 12:40 PM   #1
2010 16' Sport
Golden , Colorado
Help removing bottom panel from closet door
Hello
I have an Airstream 2010 sport 16 ft trailer.
I am trying to seal up leaks and add insulation to the area underneath the closet and refrigerator.
I was trying to remove the wood panel on the bottom of the closet (for better access) and was having difficulty. If anyone could offer advice, it would be greatly appreciated.
Thank you.
Kristen
kristen86 is offline   Reply With Quote
Old 09-05-2016, 01:47 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Mine has pocket hole screws thru the bottom to the cabinet walls. For pictures and info Google "pocket hole".
MICHAEL
Old 09-05-2016, 06:25 PM   #3
2010 16' Sport
Golden , Colorado
Thank you for responding.
I was able to remove all the pocket hole screws I could see (about 10 total) that attached to both side walls, but the bottom panel (beneath the closet) will still not budge.
I notice screws holding wood planks that support the cardbord piece that forms the bottom of the closet "floor". I have not removed those yet - do you think that would help.
I will take a picture tonight and post tomorrow.
Thank you again for your help. This has been a weeklong project for me to try to figure out how to remove the bottom panel from the closet area.
Kristen
Old 09-06-2016, 06:35 AM   #4
AWCHIEF's Avatar
Images: 33
I would keep removing every screw I could see. When I removed the front couch it was also held together with a couple of dozen hidden staples. To me it looked like that was how it was first put together and then the screws were added. That could be the case with the rest of the furniture.
MICHAEL
Need Battery door and bottom vent door on main side Swimhard4 Airstream Classifieds 0 03-09-2015 09:27 AM
Rivets broken on rear bottom panel airhaus General Repair Forum 3 08-08-2012 12:29 PM
Need help removing back closet and tub. drowe42 1966 - 1968 Safari 0 04-04-2009 04:56 PM
