08-09-2016, 08:50 AM
1978 31' Sovereign
Botgek
Harbor Freight Rivet Gun Issues
I've put in nearly 600 olympic rivets with the HF gun with no issues. The problem is with 1/8" pop rivets, the gun won't grip the rivets. I took it apart and found that the pop rivets are to small for the thing that grips them. The gun has a tip for 1/8" and I'm lost why the rivets would be to small.
Anyone else run into the problem?
Ryan
08-09-2016, 09:18 AM
2012 25' FB Flying Cloud
Parker
For $20 you can just get a new 1/8 rivet tool at home depot. For the small ones that's all you need. Easier than trying to figure out what's wrong with yours. Mine works just fine. Understand your wanting a gun for the larger ones
2012 25FB with solar
2012 Toyota Tundra 5.7L V8
08-09-2016, 09:24 AM
It shoud ble easy to fix. Take the chrome nosepiece off and you'll see the jaws that grip the rivet mandrel.
Unscrew the jaw holder and you will probably find a piece of rivet or just dirt that is keeping the jaws from closing around the rivet.
Clean it, grease it, put it back together and it'll work fine for another 600 rivets. Just needs a little routine maintenance.
08-09-2016, 09:30 AM
1973 21' Globetrotter
Houston
First question is, do you have the gun with max capacity of 1/4" or max 3/16"? I have had two of the 3/16" and have had no problem with either of them (in terms of gripping a 1/8" rivet shaft). Also, look in the little bag of replacement parts that came with the gun--you might have a second set of grippers that can be swapped out. The other thing is be sure you are shooting 1/8" rivets with aluminum mandrels. It could be that you are using steel mandrels and the gripper is just not finding purchase on the steel.
good luck!
08-09-2016, 09:34 AM
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain
, Ohio
Just to be per-emptive to the Harbor Freight haters about to post, I am loving that store! We had a new one open about ten minutes from me, and is stealing my money regularly!
For the restoration of my trailer, I have found that I'm more often than not using HF tools. These including the revit gun, grinders, sanders, metal shears, metal brake, welder, blankets, straps, and various expendables. It's starting to smell like China in my shop.
Realistically, I'm not expecting the precision and longevity of my Snap-On stuff, but the tools are only about 15% of the price.
For low frequency, non-proffesional use, I have no issues with HF.
08-09-2016, 09:43 AM
Houston
I only want my trailer restoration tools to last for exactly one restoration anyway. Don't want a bunch of tools lying around tempting me to take on another project trailer!
08-09-2016, 09:52 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
SFSG....25+Yrs & counting...$35 or so on Amazon.
08-09-2016, 09:58 AM
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain
, Ohio
About $45, only got 8-10 years on it though.....
08-09-2016, 10:29 AM
Biloxi
, Mississippi
I have HB gun that has probably 300 rivets thru it in the last 5 years. Only complaint I have is that it grips the shafts so tightly that I have to pull them out with pliers.
MICHAEL
08-09-2016, 10:54 AM
1973 23' Safari
1970 27' Overlander
Boerne
I also was having some issues with getting shafts out after each rivet. I just tried a nosepiece, same size, from my manual rivet tool - works great now.
Greg
08-09-2016, 12:14 PM
1977 31' Sovereign
Lynnwood
I've used 1/8" Harbor Freight rivets for years. In fact, I used a few yesterday. No problems.
After 600 rivets, your rivet gun's semi-circular, conical "jaws" may need cleaning (accumulation of aluminum dust and debris over time), or jaw "teeth" may be worn. You need to disassemble your rivet gun for inspection.
Tom
08-09-2016, 01:46 PM
Biloxi
, Mississippi
I had a HP-2 for years until some scum bag stole it. They are still good value at $35 from Amazon.
Careful using the HF rivets on an Airstream. They are steel shanked. I get my all aluminum rivets from Vintage Trailer Supply.
MICHAEL
08-09-2016, 01:55 PM
belen
, New Mexico
Hf
You get what you pay for!
Have a power sewer rooter that works as designed.
Heavy dolly wheels I recently got collapsed under the thing I wanted to move.
The place is fine for weekend tinkerers but NOT for we who fixes things for a living!
08-09-2016, 03:00 PM
Biloxi
, Mississippi
And on the other hand I build wooden boats commercially. Burned up several high end and very expensive angle grinders. Bought a HF grinder to use for one job. This was our ten years ago. Over a dozen boats later it is still going strong.
MICHAEL
08-09-2016, 08:00 PM
Mission Viejo
I have a huge problem with stuff that lasts for only one job. It all goes straight to the landfill. It bothers me that the world is grinding out crap that lasts for ten minutes of use and ten thousand years in a mountain full of trash.
I'd rather rent a tool if I only need it once, or buy a high quality thing that I can use for many years.
08-09-2016, 08:04 PM
Registered User
1957 22' Custom
Lago Vista
Harbor Freight Tools
Has anybody else ever noticed that all Harbor Freight tools have a unique smell? I actually like it
08-09-2016, 08:22 PM
1978 25' Tradewind
Metro Phoenix
It's a mixture of blood sweat and tears from the six year-old Chinese girls who work 14 hours a day making this stuff.
It'e either that or Cosmolene.
08-09-2016, 09:27 PM
1971 31' Sovereign
Temple
I built my Sonex airplane using a HF rivet gun. After somewhere around 11,000 rivets I am now using it on my Airstream restoration. I think its safe to say I got my money's worth out of this tool.
08-09-2016, 09:43 PM
1978 31' Excella 500
Genoa
, Nevada
So? You probably don't have the reclamation contract on that landfill yet then. You probably don't even own very many acres of growing trees to replace those cut to make the house you live in. That mountain of land fill sounds like a resource for a lot of valuable materials in the future to me. Buy some land with clay for landfill liners. Invest in the folks making manufacturing islands on the floating plastic waste islands.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
08-10-2016, 04:25 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Outhouse?
