| grade and specs for restoration materials
Hi,
I am getting ready to restore a 71 airstream and need some help.
After reading the forums I am using going to use solid bucking rivets, but need the specs as there are a daunting number of variety's. What is the head size in 32's , what length, ( using standard alcore speced metal) should it be hard or soft ?
I also need the u channel in the rear(channel mounted to the floor to attach the interior and exterior skin), any place to buy this preshaped? Does any one stock the channel and Z stock for these trailers? If not what grade is it and what is the thickness?
Unfortunately a rear and front convex panel need replacing and I will have to make a form to shape the metal stock. Does anyone who has been through this have any suggestions to make this as error free process as possible. I am planning to make a wood convex form to shape the metal, so it anyone has gone this route please advise.
I have read the forums on skin replacement and have a 1973 service manual. Unfortunately the service manual does not give specs on the channel stock or rivets.
