Old 08-07-2012, 10:07 PM   #1
jerryahyman's Avatar
1974 23' Safari
Mesa , Arizona
Front gaucho conversion to dinette or L lounge
My wife and I are thinking of getting an additional Airstream in the Overlander to Ambassador size range. Most likely in the mid 70's to 1983 range. Can anyone point me to any threads where someone has successfully taken out the front gaucho/lounge out and installed a dinette or L shaped lounge like on the current Airstreams?
I looked at what brochures I could find from those years but couldn't find where the factory produced a model like that in this size class. We prefer the looks of the 27 footers but would go to the 29' if we need the room for the dinette or L shaped lounge.
~jerry
jerryahyman is offline   Reply With Quote
Old 08-22-2012, 10:50 PM   #2
ddruker's Avatar
2000 27' Safari
Palo Alto , California
I am almost done with a U-shaped lounge in the front of my 1999 safari 27. It's looking great - when I finish I will post a bunch of pictures. I made it out of cherry hardwood with stainless steel accents. It's going to be far more usable than the old convertible couch and side table that it is replacing.
Basically I built three 24 inch deep, 14 inch high lightweight benches laid out a U shape that wrap around the front of the trailer - one across the front wall of the trailer, a shorter one from the door on the curb side to the front bench, and a third from the front bench to the pantry on the street side.
Each bench has a hinged top that lifts to provide storage access. To keep the weight down, I used stick construction with glued and screwed joints, and I used rubber upholstery webbing instead of plywood for the top surface.
I'm having five inch thick cushions made both as backrests and as seat cushions to bring the seating height to 19 inches.
A table in the middle of the U drops down to form a queen sized bed.
If you search the forum there are many threads on replacing the sofa with a lounge - not too many plans as each one is pretty custom.
The basic strategy is to go real slow and measure often - the interior of the trailer is quite irregular. There is also a lot of thought to put in if you want to make the lounge transform into a bed - you need to get the cushion sizes just right so the backrests are the right height and length to cover the tabletop.
ddruker is offline   Reply With Quote
Old 08-28-2012, 10:30 PM   #3
1974 23' Safari
Mesa , Arizona
Ddrucker, any photos to post yet?
~jerry
Old 08-28-2012, 10:48 PM   #4
ddruker's Avatar
2000 27' Safari
Here you go...
Working on the drop down table right now, and getting bids for cushions. While it's not obvious in this picture, the bench tops all open up on hinges for storage access.
Approximate sizes - facing the front of the trailer - leftmost bench is about five feet long, back bench is about 8 feet long, and right bench is about 3 feet long. All of the benches are 14 inches tall and 24 inches deep at the top of the bench. I'm planning on 5 or 6 inch thick cushions, to bring the seating height to 19 or 20 inches. The table is going to be 48 inches wide and 32 inches deep, and 30 inches high.
When the table is lowered, it rests on cleats you can see on the sides of the benches. Two of the backrests will then drop down onto the table to form a queen sized bed.
Old 08-29-2012, 10:47 PM   #5
1974 23' Safari
Mesa , Arizona
Thumbs up
Absolutely beautiful work! Please post photos when it is completed.
~jerry
Old 08-30-2012, 05:59 AM   #6
PhilipKS's Avatar
1999 34' Excella
NE Central , Kansas
Very nice! I second the request for more photos when the work is complete.
Philip
AIR 57698, TAC NM-9. http://www.flickr.com/photos/philipks/
PhilipKS is offline   Reply With Quote
Old 08-30-2012, 06:44 AM   #7
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
WOW!!!!! Absolutely gorgeous!
Skatiero is offline   Reply With Quote
Old 08-30-2012, 07:08 AM   #8
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
Our 1977 has a factory dinette. Browse the images in our profile for details.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 08-30-2012, 07:23 AM   #9
1962 19' Globetrotter
1974 25' Tradewind
1973 31' Sovereign
Charlottesville , Virginia
I LOVE this! You have done a great job and have inspired my next renovation on my Tradewind. I chuckled when you said measure often, I have found no straight line, nothing plumb, square or otherwise bearing any relation to any other line in my Globetrotter. I refer to it as freeform carpentry.
ASIcons is offline   Reply With Quote
Old 10-07-2012, 12:55 PM   #10
pickpick
1966 28' Ambassador
Jonesboro , Arkansas
My family of four just got back from our first time out in our 66 Ambassador. The first thing we decided was to get the goucho out of there. I drew a diagram of what I wanted exactly the shape you have done. What is the table going to stand on while in the upright position? I thought about the floor mount pockets and pipes but, I don't really want those floor brackets there all the time. Thanks for the info and pics.
lizpickering is offline   Reply With Quote
Old 10-08-2012, 09:18 AM   #11
ddruker's Avatar
2000 27' Safari
After getting a quote for more than $4,000 for upholstery at two local shops, I decided to go the DIY route.
I just finished cutting cushions out of six inch thick upholstery foam, and I found remnants of Naugahyde Nauga-Soft fake leather in the exact color I want on eBay for about $7 per yard. Total material cost about $500 vs. more than $2,000 in the bids from the upholstery shops.
I'm having a local seamstress sew the cushions - so my total cost will be about $1000 when all done.
Here's a picture with the cushions mostly done.
- Dan
1999 27' Safari + 2011 Mercedes GL 350 Turbo-diesel
Old 10-08-2012, 10:26 PM   #12
1974 23' Safari
Mesa , Arizona
Dan, I can't wait to see the finished product. Thanks so much for posting photos of you progress.
~jerry
Old 10-08-2012, 11:38 PM   #13
tinyhome's Avatar
Victoria , Texas
This is one of the trailers where many of us can't wait to see the final pics!
tinyhome is offline   Reply With Quote
Old 10-18-2012, 06:02 AM   #14
palmtreegirl's Avatar
2008 25' Safari FB SE
Medina , Ohio
I did it this way:
Wow! I love that design.
I had a '92 Excella and did not like the gaucho looking toward the bedroom - here is what I did to mine (before I sold it) to make a dinette:
http://www.airforums.com/forums/f46/...one-82027.html
Hope you get it the way you want!
Liz, Brian and 3 Yorkies
The Silver Pearl & The Black Pearl
2008 25' Safari FB SE Queen converted to King
2014 Ford Expedition EXP Limited 4x4 V-8
McKesh towing mirrors
Centramatic Balancers
Hensley Swift-Arrow Hitch
palmtreegirl is offline   Reply With Quote
