Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 05-30-2018, 11:45 AM   #1
1972 29' Ambassador
saint louis , Missouri
framing
im renovating a 1972 ambassador and need to replace some damaged framing members. where is a good source for these? are the new ones same dimension and available from a dealer?
trashbag is offline   Reply With Quote
Old 05-30-2018, 04:01 PM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
You can find frame parts at out of doors mart here:
http://odmrv.com/catalog/index.php?m...ort=20a&page=2
If you're taking your frame to a welder, I'd suggest just having them fabricate the pieces you need. An outrigger is just a piece of steel channel with a curve cut into it. If you don't need the holes in the frame members, you can use regular steel stock and save some money.
N.B., the current generation of Airstreams are a few inches wider than they were in the 70s.
TheGreatleys is offline   Reply With Quote
Old 05-31-2018, 06:43 AM   #3
1972 29' Ambassador
im needing the aluminum wall framing and floor channel. bad chassis parts I just welded steel angle and plate. I have some damage and spots where floor channel was cut out.
Old 05-31-2018, 06:46 AM   #4
1972 29' Ambassador
damage
Framing for New Water Heater Opening silver-man 1960 - 1964 Overlander 3 04-25-2011 11:17 PM
framing issues on vintage airstreams dmand001 Repairing/Replacing Floor &/or Frame 2 10-14-2010 04:10 PM
Framing with 5" channel - outrigger source JoePfznik Repairing/Replacing Floor &/or Frame 3 02-14-2009 03:56 AM
Framing out 60x80 bed LI Pets General Interior Topics 29 11-30-2006 09:30 PM
AC hole cut-out framing silver 67 Furnaces, Heaters, Fireplaces & Air Conditioning 8 10-05-2006 10:53 AM
