Old 02-23-2016, 02:15 PM   #1
SLC , Utah
Foam Futon on Guacho, who is using it and do you like it?
I've seen lots of posts asking about futon mattresses, but am still a little vague on how well they work. Seems many people say they are fine, and some say they are hard to convert to a couch and only good as a temporary solution.
Will a 6" foam futon mattress work on a gaucho? It will mostly be folded down and used as a bed, but I want to be able to put it up as a couch when company visits.
I found a 6" foam futon here:
http://www.foambymail.com/FTN-F6/foa...-mattress.html
which seems more likely to work than a thicker or spring version.
In checking into getting a custom hinged mattress, the futon is less than hal
roadtripryan is offline   Reply With Quote
Old 02-26-2016, 01:53 PM   #2
Paddledipper's Avatar
1977 27' Overlander
1996 34' Excella
Florida Panhandle , Florida
Following.
The Evans' Family
Florida Panhandle
1977 Overlander / 27' ~ The Attitude Adjuster
1997 Airstream Excella / 34' ~ The Sane Asylum
Paddledipper is offline   Reply With Quote
Old 02-26-2016, 01:58 PM   #3
dznf0g's Avatar
Oswego , Illinois
Although not used in my AS, I have two futons with custom mattresses from here:
http://www.customfutons.net
They are very nice.
-Rich-
Old 03-16-2016, 04:39 PM   #4
SLC , Utah
I bought one and wanted to report back with a short term report:
The good:
- Very comfortable
- An economical solution.
- Fits full size sheets better.
- Has stayed in place nicely while in the up position, without any antislip mat or other things.
The bad:
- Hangs over the front about 4-5 inches and is deeper, which makes it a little less comfortable for sitting.
- Harder to fold, I have to pull up on the futon a bit to get it to push in. Not terribly difficult, but does require a bit of coordination.
Conclusion:
Short term, I am happy with the purchase. I have replaced the rear one which I will mostly leave down. My plan is to use it in the up position a bit in the next few months and if I still like it, replace the front with the same thing. Sleeping wise it is miles beyond the old worn out one that was there.
Old 07-22-2016, 02:56 PM   #5
GumbyGirl's Avatar
1970 27' Overlander
Brookings , Oregon
Thanks for the update. It makes sense that it would be longer since the original gaucho adds on a separate piece when you set it up to make up the rest of the width.
GumbyGirl is offline   Reply With Quote
Futon, futon, whose got a futon?? COArgosy78 General Interior Topics 12 03-16-2015 12:01 PM
Flexsteel or Futon (PICTURES)? bimi Upholstery, Blinds, Walls & Interior Finishes 15 04-10-2006 08:17 PM
using a futon mattress instead of cushions tinsltootsie Interior Restoration Forum 7 05-13-2004 08:01 PM
replacing front couch with futon gatorsharon General Interior Topics 15 08-02-2003 12:02 PM
