Old 03-30-2010, 08:50 PM   #1
1994 30' Excella
Haslet , Texas
Falling padded ceiling panel
I just purchased a 1994 Excella 30'. I opened the door tonight and the padded ceiling panel above the door is falling down. The antenna handle is keeping the panel from falling further. From the antenna handle to the roadside wall the ceiling is still intact. Is there a recommended adhesive to repair the ceiling panel?
94 campster is offline   Reply With Quote
Old 03-30-2010, 09:14 PM   #2
_
hi campster and welcome
short answer no.
_________
this a common issue in 94-95 and there are some 'creative repairs' using hoops/buttons and so on...
IF u want the original look it requires NEW headliner and adhesive.
and don't be surprised if OTHER segments fail...
all ya need 2 read is in these threads....
http://www.airforums.com/forums/f46/...lla-14989.html
http://www.airforums.com/forums/f348...ice-58082.html
http://www.airforums.com/forums/f39/...ing-40416.html
http://www.airforums.com/forums/f39/...sic-36424.html
there is even a poll on what years have issues...
http://www.airforums.com/forums/f232...ure-21176.html
cheers
2air'
Old 03-30-2010, 09:39 PM   #3
The correct fix, is to completely remove all of the padded material, clean off "ALL" of the old adhesive, apply new adhesive, and then apply new padded material.
You cannot apply any adhesive over the old, as it becomes no better than the old, and would quickly fail.
The cause of the failure was the water based adhesive that Airstream was forced to use.
Hundreds of other owners, had the same problem.
Old 03-30-2010, 10:14 PM   #4
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
This reminds me of the foam backed GM headliners that would sag over the years.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 03-30-2010, 11:33 PM   #5
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
I have seen a repair done by some people in Florida that looked very good. I was at Land Yacht Harbor (airstream park in Melbourne Fl) and they had an advertisement on the bulletin board.
They used round buttons (for the lack of a better term) that had been attached I think to the ribs. Didn't pay too close of attention.
I once had someone tell me that airstream charges $3500 dollars to do this job.
You need to keep this thread going until someone replys with more exact info. There were a lot of trailers with this problem.
Best of luck.
wingfoot321 is offline   Reply With Quote
Old 03-31-2010, 07:58 AM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
You should know of this problem
During my search for a 1994 21' Sovereign I always asked about the headliner sag situation. Many very indignant responses from proud owners who said "yes" but its a simple fix. Yea, sure. Completely disassemble the interior so you can do the fix correctly...as Andy mentioned...I finally did find one that is perfect...but I am always waiting for the "other shoe to fall."
plastic extrusion for Aluminum Panel Edge on Ceiling macbob1240 Interior Restoration Forum 3 08-29-2007 08:54 AM
falling ceiling , 96 Excella mauser1 General Interior Topics 5 05-04-2007 10:31 AM
A/C Ceiling Panel Installation panabax Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-12-2006 04:32 AM
re-install ceiling panel Chuck General Interior Topics 4 12-11-2004 02:26 AM
Ceiling Panel Removal Gunnyusmc General Interior Topics 3 11-16-2004 07:14 AM
