Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 07-12-2014, 03:11 PM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
1961 24' Tradewind
Strasburg , Pennsylvania
Distance between bunk beds?
I am almost to the carpentry stage of the Bambi II resto! Feels good to get to this point...I am planning to build bunk beds for our daughters where the wardrobe and part of the kitchen used to be.
Can anyone tell me what distance to leave between the bunks? I have read that 30" is a good distance...but it is hard to visualize. I could use some real numbers.
Thanks for any input!!
Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 07-12-2014, 04:53 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
American Bureau of Shipping Guide for Crew Accommodations on Ships calls for these dimensions on bunks:
Top of bottom bunk at least 12 inches off the deck (floor for your trailer);
Distance between top of the bunk and any overhead obstruction, minimum 24 inches, optimum 32 inches.
So, if your trailer allows for it, the top of the mattress on the bottom bunk 12 inches off the floor. The distance between the top of the bottom mattress and the bottom of the top bunk 24-32 inches, and the distance between the top of the top bunk and the ceiling also 24-32 inches. Within those limits, try to make the clear space over each bunk the same.
If you're curious, ABS also gives bunk dimensions as 78×31½ inches minimum, and 80×38 inches optimum. You may not be able to meet those dimensions, but you should probably get as close as you can manage.
Old 07-12-2014, 04:56 PM   #3
Ben
Ben,
That dimension varies, depending on how well the "bunkers" get along.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-13-2014, 05:03 AM   #4
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
I just measured the bedroom dimensions including a bit of data about bunks in our 27FB twin for another 'streamer. Here is the text from that thread:
Our 27fb Flying Cloud is a twin bed model. Dimensions:
92" from front wall of coach to bulkhead walls of shower & bath
Front overhead lockers (full width) protrude 22" into room and are 58" off floor
There is 10&1/2" of space between foot end of beds and bulkheads
The lockers at foot of beds are 25&1/2" wide, 12&1/2" deep and are 38" off floor
There is 35" of floor space between bed bases and 28" of "walking" room between mattresses
ShinyPete is offline   Reply With Quote
Distance Between Tires Olie Tires 1 03-05-2013 02:16 PM
Installing a room air conditioner between the beds SSChanger Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-02-2009 07:41 PM
Distance between fridge burner and water line? mimiandrews Refrigerators 1 04-09-2009 11:53 AM
24' Argosy Motorhome cabinet between beds Bonitafarms Cabinets, Counter Tops & Furnishings 0 03-13-2009 08:51 PM
Distance Between Axles joopkeizer Axles 3 11-04-2007 05:22 PM
