Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 05-01-2009, 02:32 PM   #1
Profile:  1976 31' Sovereign
Ocala , Florida
Custom bathroom, shower
Has anyone seen or done a bathroom in tile ? I have a '76 31' Sov. rear bath (thinkin' of makin it a center bath) and want to gut it, and build a shower/ sink/cabinets from scratch. Plywood,drywall,tile etc. ?? Any pics, stories, sugguestions, warnings, would help. I'm doing this 'cause :
1) I'm 6'4" 240 lbs. want more room, don't wanna crack plastic.
2) Don't care for the plastic look
3) Don't care for the painted look of plastic, not any I've seen.
ANYONE ??
thanks,
RB
rbrinkley is offline   Reply With Quote
Old 05-01-2009, 03:51 PM   #2
ricknach's Avatar
Profile:  1978 25' Tradewind
San Bernardino , California
Custom Bath
rbrinkley, I know of at least one member on the forum that used tiles in the shower and behind the sink as a back splash. There are pictures on the forum of this installation but I don't remember who. The important thing is the weight. If your unit is a rear bath you are adding weight at the worst possible location. Finding light weight tiles is difficult but the 1"x1" tiles will be the lightest in weight for the area they cover.
Rick N
ricknach is offline   Reply With Quote
Old 05-01-2009, 04:14 PM   #3
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
We just put in a stainless steel shower pan and walls - much lighter than tile would be and no plastic.
Where are you thinking of using drywall? There really isn't any application I can think of that would be recommended...as your trailer moves down the road the drywall would turn to dust from normal movement over time. Most interior "walls" are wood or wood/vinyl over particleboard, plywood or masonite. Besides, normal stick-frame construction type walls take up a lot of valuable floor space. In an Airstream, every inch is treasured.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 05-01-2009, 05:06 PM   #4
VIKING's Avatar
Profile:  1964 22' Safari
Boulder Creek , California
Welcome Rbrinkley, it's good to have you aboard.
Airstreams love to travel light. I suggest you read through the forums on restoration of interiors to get a feel for what works and what doesn't before deciding what to use.
Rich
See my blog: http://1964airstreamsafari.blogspot.com/
VIKING is offline   Reply With Quote
Old 05-01-2009, 07:25 PM   #5
Mainstream's Avatar
Profile:  Currently Looking...
Louisburg , North Carolina
I would not recommend tile as even one solid piece linoleum wrinkles and moves at each floor seem because of the constant twisting and flexing that an RV does as it travels down the road. I could almost guarantee it would come apart and the grout would crack at the joints. Besides as stated by ricknach it would add too much weight.
Just one mans opinion. Hope it helps.
"Shiny Aluminum Bodies will always turn a REAL man on"
Don't Let the Grass Grow under your Rig!
2004 GMC 1984 Avion 30 R
Mainstream is offline   Reply With Quote
Old 05-05-2009, 11:47 AM   #6
Ocala , Florida
Where did you get the pan/walls out of s/s ?? Custom made ? Can you send a pic or two ?? Thanks !!
Old 05-06-2009, 02:28 PM   #7
Profile:  1974 31' Sovereign
beautiful downtown Aurora , Ontario
Send a message via ICQ to Aage
Suggest the best "helper" for that work could be the Airstream Service Manual. If you go cutting something, there may be pipes or hoses behind that wall...
They are still available from Airstream.
The road to a friend's house is never long. (Old Danish Saying)
Aage is online now   Reply With Quote
Old 05-06-2009, 03:41 PM   #8
blacksheep's Avatar
Profile:  1965 26' Overlander
1962 24' Tradewind
Vincennes , Indiana
I plan on building a SS shower pan (with seat, hopefully) for my '65 Overlander. That "Airline" bathroom of '65 and '66 is totally ugly and not sturdy at all. Mine br sink was cracked into a few large pieces when I bought it. I plan on doing away totally with all that ABS (hmm, it just occurred to me that "BS" is in "ABS", how funny!) and build something functional, sturdy, and attractive!
Godspeed,
Trent
TV1: Black Sheep, 2001 Dodge 3500, 792,xxx miles,a few non-stock parts here and there...
TV2: Brownie, 1989 Dodge W250, only 253,000 miles!
"Too much of what I once knew I now know not" Me
blacksheep is offline   Reply With Quote
Old 08-31-2009, 09:59 PM   #9
Profile:  1977 31' Sovereign
Dallas , Texas
I talked to my husband about doing the same in our AS, but he was concerned that it would always feel cold. Is that the case?
janie
wbcci 7078 :: air 4125 my favorite color is SHINY
janiemerle is offline   Reply With Quote
Old 08-31-2009, 10:13 PM   #10
StingrayL82's Avatar
Profile:  1971 31' Sovereign
San Angelo , Texas
Images: 37
Only if you're using cold water! Seriously, though, once the hot water starts coming through, the metal will get warmer, besides the fact that the heater vent comes out under the shower pan, so you should get some radiant heat from the duct to keep things warm.
SFC Frederic Lynes
1971 Sovereign International
2004 F-350 King Ranch
EX-WBCCI # 8371
AIR # 8239
StingrayL82 is online now   Reply With Quote
Old 08-31-2009, 10:23 PM   #11
Foiled Again's Avatar
Virginia Beach , Virginia
In my old house I had a claw footed tub. Those babies were made out of cast iron with a baked on porcelain finish and took two inches of hot water to warm up the bottom. They also conducted the heat OUT into the bathroom - hence modern tubs are enclosed.
Stainless will warm up with enough hot water, and perhaps you'd want to coat the back side with truck bed liner to reduce noise and help retain the heat.
I did see one very small vintage unit with an end dinette, where they had actually built a copper bathtub cleverly hidden under one bench of the dinette! It was set up with a shower set - flex hose - but I'd take a shower sitting or kneeling if I had it - no shower curtain or protection for the walls, table, etc.
Paula
Today is a gift. That's why they call it "the present"
Old 08-31-2009, 11:10 PM   #12
truckasaurus's Avatar
Profile:  1961 26' Overlander
Airdrie , Alberta
Images: 24
I really like the idea of a fully enclosed shower unit. I plan to do some investigation and see whether stainless of aluminum would work. I don't want the cold metal feel and look so I'd probably have it painted with something like POR marine. Fiberglass is a close runner up but I think a welded unit that stands alone just secured to the floor has merit in a flexing trailer. Specifically I want to be comfortable with the weight and cost is of course going to play a part.
preparing for the maiden voyage in 2010...
truckasaurus is offline   Reply With Quote
Old 09-01-2009, 07:46 AM   #13
Profile:  1956 22' Flying Cloud
Dallas , Texas
Truckasaurus, take alook at http://vintageairstream.com/archives...des/a68a_3.JPG for a nice looking aluminum or stainless steel wet bath.
hjlairf is offline   Reply With Quote
Old 09-01-2009, 09:52 AM   #14
InsideOut's Avatar
1956 22' Safari
Images: 87
We had the pan itself custom made, but the tank cover & walls we did ourselves. Here are some pics.
No, it doesn't feel cold - it's the same as the ambient temperature of the trailer. There's also wood behind the SS so I would imagine that helps keep the warmth inside during a shower....
Shari
Bathroom vanity and Bathroom vent lights... sovereignrwe Electrical - Systems, Generators, Batteries & Solar 8 10-30-2009 11:43 AM
A how to- Custom Shower truckasaurus Sinks, Showers & Toilets 21 09-25-2009 02:52 AM
Custom Shower Pan Tom Bray Sinks, Showers & Toilets 19 04-29-2009 07:28 PM
building custom bathroom / interior pinkflamingoes Cabinets, Counter Tops & Furnishings 33 11-26-2006 06:27 PM
Shower Curtain or Shower Door for 1972? mello mike Sinks, Showers & Toilets 9 07-14-2005 02:42 PM
