05-29-2012, 05:48 PM
1968 28' Ambassador
Westford
, Massachusetts
Curtains
How do I put the eye sliders that hold the curtains into the channel. There doesn't seem to be a large hole to tuck them in and slide them along. I don't want to buy them unless I know how to get them in!
05-29-2012, 06:14 PM
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Bismarck
, North Dakota
I think it is the same
I am not sure which curtains you are referring to but all of ours seem to function the same way. You find the end of the curtain track, remove the screw at the end that keeps the sliders from falling out of the end, insert the sliding part of the tabs, and then slide them along where you want them. Once you have them on, reinsert the screw to hold them in the track. I have several different types of sliders depending upon the track but they all appear to work the same way.
Sandy
05-30-2012, 06:49 AM
1968 28' Ambassador
Westford
, Massachusetts
screw? don't see a screw!
It would seem reasonable to have a screw that, once detached, would allow the eye hangar to slide in... Mine seemed to have some caulk on the end and I took it off. Didn't see a screw! I'll take another look. I came away thinking I'd have to take apart the woodwork to get the things on there.
05-30-2012, 07:12 AM
Airstream Fanatic
1976 31' Sovereign
1959 17' Pacer
1965 26' Overlander
Bismarck
, North Dakota
Might be missing a screw
I am not sure we had all of our stop ends on our track either. I guess you could say we had a few loose screws. We've been accused of worse. You can buy them through some of the suppliers if yours is missing.
Our tracks were not encased in any woodwork but your trailer is different so I can't speak for that. I would hope AS made them so the curtains can be removed easily for washing. There is no way I am going to go from season to season camping without washing all the curtains. Hope this helps.
Sandy
05-31-2012, 06:48 AM
1968 28' Ambassador
Westford
, Massachusetts
curtain hangar eyelets
I believe the curtains will come off easily once the hangars are there. The hangars look like this, the "o" hangs down so you can put a curtain hook through them :
O
If I get into a "bind" I'll drill a screw hole and get with the program to slide in these things so the "O" hangs down.
05-31-2012, 07:57 AM
The Real Chief Ding Dong
1966 28' Ambassador
Patterson
, Louisiana
Hope this helps.....
I ran out to our Ambassador to check this out and take pictures just to make sure before I responded. You are right, there doesn't seem to be any easy way to get the new plastic pieces in there. The track is riveted completely in and wrapped in a wooden "valance". We only had one window that needed to be changed and I took a picture of our "solution". We have never had problems with the curtain slipping out, yet the hole is drilled at the very far end of the track. The hole is big enough to screw in a wing nut to stop the curtains from sliding out if need be and the wooden valance hides the wing nut. We still use the clips with the holes and curtain hooks inserted through for easy removal of the curtains, but I have heard that the track can hold some of the larger sew on tabs, eliminating the need for the curtain hook. I feared it would be tight and hard to slide the curtains and removing them for washing wouldn't be fun so I stuck with the hooks. I hope this helps...
Picture one - plastic "loops" with curtain hooks
Picture Two - solution
In love with my Airstream
Melissa Dudoussat
1966 Ambassador Twin (Special Order)
06-01-2012, 06:12 AM
1968 28' Ambassador
Westford
, Massachusetts
Good to have the affirmation before I drill yet-another-hole in the poor baby. Thanks!
06-01-2012, 07:30 AM
1966 28' Ambassador
Patterson
, Louisiana
I get sick in my stomach every time I see the hubby with the drill
Melissa Dudoussat
09-28-2012, 07:51 PM
2012 25' FB Flying Cloud
2015 Interstate Ext. Coach
Nevada City
I have a 2012 Flying Cloud FB and want to know if the plastic end caps come off and if so how? The screws don't look like they need removing. I need to get the curtains off to be washed. (swatted mosquito bodies). thank you
