Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 03-09-2005, 10:02 PM   #1
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
clocks
Looking for ideas on clock replacements or repair sources for my 71 &73. I have the old 73 clock and could probably replace the works. The 71 dial is printed onto the contol panel and I also need works and hands.
Also any ideas on instrument sources which would fit the original control panel holes?
Lumatic is online now   Reply With Quote
Old 03-10-2005, 12:15 AM   #2
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
clocks
Greetings Marshall!
You might try checking the classifieds in Hemmings Motor News. There are several firms that rebuild automotive clocks, and one of them may be able to help you out with rebuilding the '73 clock and the works for the '71 clock.
http://www.hemmings.com/
The website doesn't have all of the advertisements found in the actual periodical, but will give you an idea of what might be available.
http://www.hemmings.com/index.cfm/fu...ch/type/clocks
Good luck with your projects!
Kevin
Kevin D. Allen
AIR #827
Old 03-25-2005, 11:25 AM   #3
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Nice, 2 units! If you have not already seen this thread?
http://www.airforums.com/forum...ad.php?t=15370
I still have not yet done any disassembly on mine. But I have a plan.
I picked up an assembly manual, now I know how it comes apart
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is online now   Reply With Quote
Old 03-25-2005, 12:48 PM   #4
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
Profile:  2006 30' Safari
Fayetteville , Georgia
If you are looking for a quick, cheap fix you might go to a hardware store or craft store and pick up a battery powered "movement" kit that includes the inerds for making a clock. They run about $5 each. They use a single AA battery runs about a year or two on each battery.
We did this on a cheap kitchen wall clock and used wall paper and self-adhesive numbers to re-do a clock to make a "custom" clock face to match our kitchen. When we re-wall papered the kitchen again a couple of years ago, we re-wall papered the clock face, too, and have a "new" custom clock.
All you would need to do is remove the lock washer and insert the shaft that holds the hands through the face plate and re-apply the lock washer and attach the hands. You can get different styles of hands and cut them to length with tin snips.
Old 03-26-2005, 05:32 AM   #5
balrgn's Avatar
Images: 74
Talking Assembly diagram
If you do not already have it disassembled....
Member of VAC
www.balrgn.com
Remember to turn your clocks back! Silvertwinkie Our Community 16 11-04-2008 06:08 PM
16CCD owners frozen chosen 1999 - 2004 Bambi 99 11-09-2004 07:03 AM
Ebay: A fad or a paradigm shift? ipso_facto Our Community 31 05-12-2003 01:28 PM
How to convert 220 AC/50hz to 120 AC /60hz brunoffrance Electrical - Systems, Generators, Batteries & Solar 5 12-28-2002 06:47 AM
