Old 05-29-2013, 07:57 PM   #1
1972 23' Safari
Camas , Washington
center ceiling aluminum sheet removal?
I need to find out how do you remove the center sheet of aluminum on a 72 safari?
There is chanel runing the lengton both sides and the lower sheets are riveted under the center sheet. anyone know the proper procedure?
thanks
Pams72 is offline   Reply With Quote
Old 05-29-2013, 08:54 PM   #2
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Drill out the rivets?
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 05-29-2013, 08:59 PM   #3
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
I drilled out the rivets on our 1977 Tradewind and carefully removed it. It came down quite easily - just be gentle so you don't chip or crack the strips on each side.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 05-29-2013, 09:13 PM   #4
Central , Mississippi
Remove all of the rivets, lights, vent covers, blah blah blah, THEN pull down in the center so it pops down over its entire length. Then it will drop out. If you try to start at one end ya gotta basically rip it down, depending on your mood, that also may be a satisfying method.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 05-30-2013, 06:52 PM   #5
1972 23' Safari
Camas , Washington
got it out what a pita! the channel on either side made it very difficult I ripped away and tore the aluninum in one spot might just have to replace the forward piece. I had all the rivets removed when I asked the question, just needed to find out how to get it out of the side channels.
For future referance.
For the rear piece I used a wonder bar and opened the channel a bit made it much easier to get out. I figured the channel could be tapped back into shape after installing the sheet.
Silicone caulk on aluminum edglenn Leaks - Weatherstrips, Gaskets, Caulks & Sealants 43 12-21-2012 08:48 PM
