Old 08-28-2012, 08:32 PM   #1
Airstream Newby
CMSmith's Avatar
1975 25' Tradewind
Florence , South Carolina
Building materials?
I have done a search for building materials, but have not found what I am looking for. With all the interior rebuilds that I am seeing, it seems that a lot of weight is being added. What lightweight strong materials are being used to rebuild cabinets and furniture? Or is there really nothing better than what was originally used (for weight that is)
CMSmith is offline   Reply With Quote
Old 08-28-2012, 08:44 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
we're using red alder. It looks like new cherry when varnished and is very light weight. Boards are not expensive, but the 1/4 inch plywood is more expensive than oak or maple plywood. Hidden construction is basswood, again something quite lightweight but strong.
Kay
Old 08-28-2012, 09:29 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
The interior on the Tradewind was in pretty good condition when we rescued her. Airstream refered to the cabinetry of that era as Perma-Tech Furniture. I decided to keep the frames but replaced the laminate with inch Hickory plywood. It slips into the extruded framing just as the plastic did.
The thinner laminate strips on the face frames are either milled from Hickory stock or trimmed down “Iron On” edge banding.
The ply is slightly lighter in weight than the laminate and looks so much nicer when stained.
Good Luck,
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
