Old 02-13-2010, 05:46 PM   #1
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
Batwing antenna removal help.
Has anyone removed the large antenna on the roof of their AS? Mine needs to go. Also, The 12v antenna plug/switch inside the coach, what do I need to do to get a cat 5 cable into the coach to replace the old antenna wires? Thanks all!
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline   Reply With Quote
Old 02-13-2010, 05:49 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Needs to go why? Cat5 from top of trailer? Even bigger why?
Vaughan
Old 02-13-2010, 06:30 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Are you talking about a manual or a OEM Braund powered antenna? What do you mean by a "12v antenna/plug switch"? Are you talking about the TV antenna/ and 12v outlet plug? I replaced mine with a Winegard unit wired for coaxial. Photos would help.
I replaced my christmas tree antenna with a Winegard Batwing. I could not reuse the OEM antenna wire and could not fish new wire through. I drilled a hole under the fridge vent and rewired with coaxial from there.
Old 02-13-2010, 07:01 PM   #4
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
The original antenna is huge and I wont use it. Is cat 5 coxial?
Old 02-13-2010, 07:05 PM   #5
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
LU,
Im talking about the manual crank type antenna. 70's original, I think. Yes, Iam talking about the tv/12 outlet plug. I guess I need to what you did under the fridge.
Thank You!!
Old 02-13-2010, 07:47 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
Erm. Category 5 wire is twisted pair, not coax, not much good for an antenna connection.
Old 02-13-2010, 08:12 PM   #7
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
A guy was talking about the two together. Just misunderstood him. Thanks for clarification.
Old 02-13-2010, 08:13 PM   #8
Ottawa , ON
Too bad, it's still good to receive the new digital TV signals, Cynthia. And I think it looks cooler'n all git out when it's up !
Old 02-13-2010, 08:30 PM   #9
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Hey Mr. Man, I dont think it will work with my hdtv, will it?
Old 02-13-2010, 09:50 PM   #10
1983 34' Excella
1967 24' Tradewind
Images: 32
Jammer is right about the difference between coax and cat-5. Cat-5 is for Ethernet, not TV signals.
Search for HDTV Antenna to see the numerous threads about this. The answer still is that the signal doesn't know that it's HD. All TV antennas work just fine for HD and always have.
The good news is that you can relax. What you already have will work fine without you doing anything. Anyone who tells you different is just trying to sell you something.
They were using the Skyliner (not Batwing) antenna in 1967 and still using it in 1983. I promise you that the Skyliner works perfectly with my HDTV. You can download Braund manuals here to verify that is what you have. Someone could have replaced it with a Windgard Batwing at some point, more info at Winegard's website. Still should be OK either way.
Vaughan
Old 02-13-2010, 10:51 PM   #11
Ottawa , ON
It will, ma'am, it will. You jes' gotta have a strong signal.
Old 02-14-2010, 06:45 AM   #12
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I had a Skyliner with the internal amplifier, which is behind the TV/12outlet. I replaced it with the Batwing with the amplifier in the antenna. The batwing is better for both regular and HD TV. If you are parking in a campgrounds with cable, it worth it to put in an alternate coax connector, so you can hook in. If you move frequently and are parking close enough to civilization, buying and resetting up a satellite system every night is not worth the effort. I now leave mine at home.
tv antenna removal kokomoscalls Roof 15 08-31-2015 10:23 AM
Winegard HA-0130 antenna... might buy Lothlorian Audio, Video & TV 3 03-10-2014 09:56 PM
Roof crank up antenna wire goes where ??? dryenko Audio, Video & TV 10 01-17-2012 07:54 PM
Help with antenna location and setup dznf0g Phone, CB & Ham Radio 0 10-16-2011 08:46 PM
Radio antenna needed? SilverHoot Audio, Video & TV 25 01-19-2011 11:01 AM
