Old 04-08-2013, 12:37 PM   #1
1964 30' Sovereign
bremerton , Washington
Bathroom dimensions, help!
We are trying to map out our layout of our gutted 1964 30' airstream. We have the general areas mapped out but are looking for some specific dimensions for the shower and bathroom (we want to do the split style). We had the idea of putting the shower against the side of the wheel well to create a seat (for shaving legs). Any help, thank you!
jrossingaul is offline   Reply With Quote
Old 04-08-2013, 02:40 PM   #2
Klatawa (to travel)
Klatawa's Avatar
1965 24' Tradewind
Bremerton , Washington
We moved our bath from the rear to a side mid bath on our 24', and found using cardboard to mock up the walls and cabinets useful. Each trailer is so unique due to window placement, wheelwell, ceiling openings. We did end up with a shower stall about 26" x 32" with part of the wheelwell in the shower.
Goodluck!
Klatawa
(Dave & Debbie)
1965 24' Tradewind
1965 Chev Carryall
http://s1237.photobucket.com/albums/...ind%20Rebuild/
Klatawa is offline   Reply With Quote
Old 04-08-2013, 03:52 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Sounds like you want a step tub. They come in many different sizes. Here are two web sites where we did a lot of looking:
http://www.pplmotorhomes.com/parts/shower-rv-pumps-water-filters-fixtures.htm
http://www.icondirect.com/categories/RV-Interior-Parts/Bathtubs/
We mocked up pretty much everything we've built in the trailer with cardboard to make sure things were going to fit as we expected. Several times, we ended up changing plans because the mock up's showed that what we thought would work ok actually didn't work at all.
Chris
