Old 03-13-2015, 03:39 PM   #1
2004 19' Bambi
2010 23' FB Flying Cloud
Bridger-Teton , Wyoming
Anybody ever put a new Fantastic-Fan in a '67 Overlander.
I'm thinking about replacing the existing vents with fantastic fans. I'm wondering if it is a straight up swap or if cutting will be involved.
veg hed is offline   Reply With Quote
Old 03-13-2015, 03:56 PM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I replaced the original rear vent in my 68 with a Fantastic Fan. A little cutting is required but not much. I tried various methods but I found that the easiest was the using a cut off wheel (one for aluminum) on my 4 1/2 angle grinder. A template comes with the fan. The inside cut is messy but if you get a helper to hold a shop vac by the grinder as you cut, you can minimize the mess.
I would suggest you buy from Vintage Trailer supply as Steve has a curved bezel for the inside that fits the curve of the Airstream ceiling and looks great and has a gray cover that matches. Also, the model with the rain sensor and thermostat is well worth the small extra cost (only takes one thunderstorm while you are away to make the rain sensor seem like a bargain- how do I know this- ha)_
Final tip, toss the mounting screws that come with the fan. Instead, by some stainless steel panhead screws of proper size and put a small SS flat washer under each screw head. This will distribute the pressure over a much larger area than the countersunk factory screws and will be much less likely to cause the flange to develop a crack later.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 03-14-2015, 02:45 PM   #3
2004 19' Bambi
Awesome, thanks for the tip TWind. I'll probably order some here in a couple of days.
Old 03-14-2015, 04:12 PM   #4
Greg@AirLA's Avatar
1960 24' Tradewind
Riverside , United States
Put 2 in my 1960 Tradewind, piece of cake.
Greg
Greg Paulsen
Greg@AirLA is offline   Reply With Quote
Old 03-15-2015, 01:10 PM   #5
chapparel's Avatar
1965 22' Safari
Three Rivers , California
I have two in my 1965 Safari, and I love them. Installation is very easy.
"Life isn't about how to survive the storm,
but how to dance in the rain."
AIR #17571
chapparel is offline   Reply With Quote
Old 03-15-2015, 01:53 PM   #6
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
I myself installed two in our 67 with no problems.
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 03-15-2015, 02:52 PM   #7
1965 17' Caravel
Silver Cliff , Colorado
I installed Fantastic vent in 64 Tradewind.
It was pretty much a straight switch. The opening was a good fit and wiring access was close.
I am assuming it would go as well for your 67.
Don B
D Bishop is offline   Reply With Quote
Old 03-15-2015, 02:53 PM   #8
1965 17' Caravel
I installed one in a 64 Tradewind, very easy.
Old 03-15-2015, 04:07 PM   #9
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
I installed one in place of a standard vent. Pretty easy - I had to trim the inside opening a bit with a pair or snips. Cutting through the old exterior caulk to make a good smooth surface to mate to was the hardest part, as I recall. I tapped into wiring for a nearby light. I heavily caulked the seat and perimeter of the exterior flange and over the screw heads, but a couple of years later the flange cracked. So, I'd recommend covering the entire flange with vulkem or other good caulk that you can smooth with a putty knife.
robert claus is offline   Reply With Quote
Old 03-15-2015, 04:08 PM   #10
1969 27' Overlander
1949 22' Liner
1959 18' Traveler
Seal Rock , Oregon
I installed two in my 69 Overlander. THey went in well. Had to remove the old adhesives and used tin snips to square the openings. Had to tap into some power for the rear fan (formerly a venting skylight) the front powered vent skylight had power and was a snap.
One issue was the interior trim not fitting well because of the lengthwise ribs in the center trim that runs the length of the ceiling. The trim piece is just a smidge too wide and so I filled the gap as best I could with some rigid foam trim
Sealrocker is offline   Reply With Quote
Maxx Fan Vs. Fantastic Fan Lumatic Roof Vents, Skylights & Fans 19 09-07-2011 07:10 AM
Anyone ever put a new fridge in their Caravel 1967Caravel 1966-68 Caravel 6 09-10-2009 11:02 AM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
Anyone ever put a wood stove in their trailer. Mrcrowley Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-16-2008 09:14 PM
anybody ever buy a service manual from AS? Chuck Our Community 3 02-28-2003 09:09 AM
