Old 08-30-2012, 08:07 PM   #1
1974 31' Excella 500
newport , Rhode Island
...and so the adventure begins
Hello all; ...new to the Forum, taking delivery of our Excella 500 on Tuesday, and she's given me one year to redo the interior and all the systems! I have not tested anything inside, but if anyone is interested in what seems to be the original stove, refrigerator bath fittings(rear bath) etc, you are welcome to them!
.....wish me luck!
tikiman57 is offline   Reply With Quote
Old 08-30-2012, 08:16 PM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Cancel the cable TV and high-speed internet, go back to dial-up and have only two bookmarks.. the weather forecast and airforums.
Old 08-30-2012, 08:25 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Totally doable. I did a shell off in a month and a half. And then was able to use it for a 3 week trip. Had no cabinet doors and not all the trim in but hey. You can't have everything. Now I'm starting to work on that stuff. Wife gave me till 3 rd week in October when we head to Zion NP. Good luck.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-31-2012, 12:06 AM   #4
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Take time to post pictures, we want pictures!
Mrs. NorCal Bambi traveling in S Tardis ~ from the Great State of Jefferson!
My blogs: http://yrekahistory.blogspot.com
http://siskiyoucountycamping.blogspot.com
http://campingalongi-5.blogspot.com/
CaddyGrn is offline   Reply With Quote
Old 09-04-2012, 05:48 PM   #5
...Put her in a comfortable, protected spot between two shipping containers, and went to work! My wife, as it turns out, is a rivet destroying machine. We got much of the aft furnishings out - left the bathroom for tomorrow. The amount of mouse droppings is incredible, and I vow to erase all trace of them! Pulled out the oven and it seems in good shape if anyone in the region has a use for it. Off to Home Depot!
ID:	167470   Click image for larger version
Old 09-16-2012, 09:12 PM   #6
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
just double checking....any progress?
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 09-17-2012, 07:46 PM   #7
Back in the saddle
.....taking advantage of the September weather and breezes to get out the toxic chemicals and go to work! Thank you to all who have gone before us and shared their product discoveries on various threads regarding stripping vinyl from interior skins! We picked up a couple gallons of KleenStrip Premium (Jasco was not available locally) and so far so good - but make no mistake about it; you cannot protect your body too much!! We started out wearing goggles and chem resist gloves, and rapidly progressed to chem suits, a baseball hat, and a paper kerchief to guard from napalm-like spatters!!(see photo below) We are fortunate to be in an open field with ocean breezes, so there was no discernible odor, but all you need is one blob of stripper dripping off the ceiling onto the back of your neck to get your attention. The KleenStrip works great, although it took as many as four applications in some areas to release. As previously mentioned, it comes off like a thick latex balloon, and is so satisfying! Two of us did 3/4 of the 31 ft in about 10 man hours. So far we have used 3 gallons of stripper and a lot of shop towels. Obviously, there will be a lot of touch-up work after the rivets and overlap comes off, but it feels gratifying to make such visual progress in one day!
ID:	168596   Click image for larger version
Old 09-17-2012, 09:51 PM   #8
1973 25' Tradewind
Augusta , Georgia
Looks like you are removing the interior coating. Do you know if this is the same plastic coating on a 1973? Soon to start putting the interior panels back in and have gone back and forth on the interior panels. I've cleaned with Simply Green and thought about Andy's floor wax polish. Right now panels are removed and stacked in corner of shop so stripping would be easier than what you are tackling. Would like to paint something other than beige. Actually like raw aluminum look.
Keep up good work - dennis
DGJackson is offline   Reply With Quote
Old 09-18-2012, 11:58 AM   #9
1973 31' Sovereign
2007 20' Safari SE
wow...that's some progress, are you guys painting the interior or will polish it?
2 chronicles 7:14
Old 09-20-2012, 04:33 AM   #10
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Just found this post, we are neighbors!
You are obviously not fooling around with this project. Looks like fun.
Keep the pictures and reports coming we all live vicariously here!
Bruce
Bruce B is offline   Reply With Quote
Old 09-26-2012, 09:05 PM   #11
......the plan is to get all of the residue off, remove the panels, take her down to nothing but ribs and skin! Sounds easy, right!? In about two years, we'll probably spray the walls, along with the casework, a low luster white. That's the plan, anyway. subject to change.
...where we are right now - took the headliner down to remove the last trace of vinyl. After pulling out the insulation, there is some left because of the adhesive used. Does anyone have experience removing the fiberglass that is stuck on the wall cavity? Thanks!
Old 09-26-2012, 10:02 PM   #12
tinyhome's Avatar
Victoria , Texas
It looks like you have a great project. Keep the pictures coming, it is a motivation for us new to airstreams.
tinyhome is offline   Reply With Quote
Old 09-27-2012, 07:52 AM   #13
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Just curious, why are you removing the panels down to the ribs and skin. Are you going to put them back up at some point.
Don
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 09-27-2012, 02:34 PM   #14
1973 31' Sovereign
2007 20' Safari SE
Attachment 169020
nice progress! we saw a couple of threads that they used stripper again to remove the fiberglass left over and after steam cleaning! It did look good and totally sanitized!
keep the pics coming, btw any tricks to remove the headliner?
2 chronicles 7:14
