Old 12-21-2014, 09:53 AM   #1
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
Aluminum Wall Back-splash and Range-hood
From another thread, I was asked about this.
The incentive
After removing the damp and decayed kitchen over head locker, I discovered the destructive leak that the Negligent Airstream Factory Worker caused when he hawged the hole for the stove fan vent through the ABS plumbing stack. Evidently the black swarf falling at his feet caused little concern. Whoever swept it under the bathtub along with all the other construction debris didn't wonder about it either. Whoever fitted the fan and duct ignored it...
Forty-seven years of weeping water infiltration from the kitchen sink vent stack slowly rotted the wood, rusted out the range-hood, oxidized wiring and lighting, seized the fan.... This “un-findable” leak must have been horribly frustrating to the POs, as there were confluent glaciers of sealants around the roof vent, seams, stove, and sink vents.
The over-head
I didn't like the pseudo-cabinet anyway, it was rather ominous, heavy, head banging, and compartmentalizing to the interior. It doesn't function much as a cabinet as there's nearly no storage space, mostly just concealment of the range-hood and duct, the massive refrigerator chimney, and it's a blind reach into the unprotected, loose wiring for the kitchen light and fan.
The back-splash
With the wall cleared, I drilled and fished the wiring to new locations. To drill a 1/2” hole thru a horizontal rib, I drilled an 1 1/2” hole next to the rib, angled an 1/8” pilot bit into the rib center, then followed with a 1/2” bit. I grommeted the 1/2” hole, and fished solar cables to the rooftop center-line.
Prior to install, the covering sheets of 5052 .032” were wet sanded with varying paper grits to a faint brushed texture, and coated with micron thin applications of spar polyurethane to prevent oxidation and facilitate cleaning. The blind riveted aluminum sheets were edged with metals and transitions common to the counter-top trade. Total weight of aluminum sheeting applied to walls and bulkhead; 15.2 lbs.
The range-hood
I snipped, planished, and 5/32” modified brazier riveted 5052 .032” aluminum spherically in an 18” radius into a four segment range-hood. I wanted to enjoy the beautiful day outdoors, so I bucked it all together on a train rail with a hand set and my yard hammer out on the picnic table. Likewise, I riveted a .125” valance & .032” shelf that conceals a strip of 12V LEDs, and along inside the .125” range-hood edge band to illuminate the kitchen counter and cook-top, controlled by a pulse width modulator. Fan actuated by chain pull switch.
Smooth and Shiny
Link to pocket door explain... http://www.airforums.com/forums/f7/p...ce-128019.html
ID:	228974   Click image for larger version
ID:	228976   Click image for larger version
ID:	228978   Click image for larger version
ID:	228980   Click image for larger version
ID:	228982   Click image for larger version
ALUMINUMINUM is offline   Reply With Quote
Old 12-21-2014, 08:09 PM   #2
aquinob's Avatar
Portsmouth , Virginia
Gorgeous work.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 12-22-2014, 12:50 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Beautiful range hood. You've made your 68 so open, light and airy. The satin aluminum interior walls are perfect. Thank you for sharing your ideas, designs, comments and resultant photos. Your writing style is top notch.
David
Old 02-20-2015, 05:46 PM   #4
1972 27' Overlander
Denver , North Carolina
...note to self...Do Not show this to wife... End note
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 03-27-2015, 09:56 AM   #5
1964 19' Globetrotter
eagle , Idaho
love that vent hood
wow.
love that vent hood looks like it came that way.
nice work!
idahoair is offline   Reply With Quote
Old 03-27-2015, 06:02 PM   #6
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Excellent work! I wish we were neighbors!
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 03-28-2015, 06:40 AM   #7
1977 31' Sovereign
Ape coral , Florida
Your on to something here!!! Great design!!
InjectorJake is offline   Reply With Quote
Old 03-28-2015, 06:55 AM   #8
Baltimore , Maryland
very nice work! I am impressed! I hope you are very proud of yourself.
What alloy did you use? How will you protect it?
Old 03-28-2015, 07:33 AM   #9
txdxrider's Avatar
1976 31' Excella 500
Providence Village , Texas
Great work!!!
Let's party with Pirates and Ninja's.....
txdxrider is offline   Reply With Quote
Old 03-28-2015, 07:46 AM   #10
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Aluminuminum: Don't you go get a BIG head over all these accolades! The next thing we know you'll hire an agent to screen and respond to all these postings. And you may start selling "galley kits" for mid sixties Safaris, along with your patented mini blind installation kit, and your Corning glass bar - hinge sealing kit. Your future is bright.
David
Old 04-22-2015, 06:05 AM   #11
911Patriot's Avatar
1991 29' Excella
Marco Island , Florida
Images: 42
Rivet
I am COMPLETELY Wowed! Amazing workmanship & investigative trouble shooting. It is beautiful. Thank you so much for your step by step labeled graphics too which we can easily follow. Again...WOW!
911Patriot is offline   Reply With Quote
Old 04-24-2015, 04:46 AM   #12
I would love to know the answers to my two questions…
I ask because I have not been happy with the longevity of the surface of any of the projects I done of exposed aluminum. I only do this sort of work in stainless because of how the surface looks after just a very short time. Watch out for any kind of slightly acids liquids...
Old 04-24-2015, 07:58 AM   #13
NO HUMBLE OPINION
Thanks all, It's assuring to receive your positive responses.
Turns out, growing up poor without toys was a “gift”. I played with string, hairpins, tape, coat hangers, empty cans, paper clips, rubber bands, clothespins, pencils, milk bottles, newspaper, thread spools... whatever I could find on the floor. Life got better... Elated by a can of Tinker Toys, then some Lincoln Logs, an Erector Set, a Gilbert Chemistry set. Then on to skillfully painting and decaling dozens of plastic Revell car models. With great pride, I glued up a USS Forestal while surrounded with squadrons of model bombers and jet fighters suspended from my bedroom ceiling. Secretly stayed up all night 'til dawn building the “Visible V-8”. Strung a network of wire throughout the neighborhood to communicate with my playmates by Morse code, self taught soldering by a building a Crystal radio (today, proficient with TIG)... By the seventh grade, I was amazed to win my division at the State Science Fair, building a Van de Graaff electrostatic generator from household items (a story in itself). Many flying balsa and silk models powered by a progression through rubber bands, Cox .020, .049, Fox .09 and finally the coveted McCoy 35 Red Head. Did all that stupid boy stuff like launching them with a fuselage full of firecrackers on a long fuse.
Funded all this nonsense by cutting lawns with my home-made power mower, a leaf rake, a snow shovel, and a paper route. Sixty years later and thousands of projects, I still fabricate most all of my toys.
I sense that there are hundreds of Airstream restorers on this forum with very similar histories.
Frank, I wrote this weeks ago, but didn't get it edited down into a less verbose response, so you'll have to suffer through my entire, and personal, rambling.
Stainless is the best. At a professional level, I don't expect that my method has the durability that I would guarantee “out the door” without a caveat of caution. It isn't idiot proof. It might not meet the standard that you demand of yourself. I've been self-employed in the trades, and I know how important flawless, guarantee-able work is to me. So, I'll call it “Do it Yourself” or better, “Hillbilly” quality to be safe, as I haven't exposed it to anything that eats polyurethane. It does resist oxidation, olive oil, and finger oils, which suffices in its controlled environment. I keep it clean, it's maintainable... I think it's too labor intensive to do for anyone but yourself.
The metal was prepped prior to installation. To plain ol' 5052 .032 and .125, that was directionally hand sanded, the coating of exterior(non-yellowing) semi-gloss polyurethane, thinned to a wipe-able consistency is applied with a soaked rag instead of brush or spray. I scrub it in really well, then nearly all off, to assure there are no brush marks. Let it dry hard for a day, wet-sand with 1000 grit, and wipe it down again, repeating until it feels like about a half-thick spray coat. Took a while, but visually, it's difficult to detect the presence of a coating, surface looks satiny-polished, has depth, shows faint grain, inhibits oxidation. An attempt to closely mimic the original exterior finish.
It resists water stain and cooking spatter as any enamel paint would, cleans with warm soapy water, a little Windex sometimes.... I cannot expect it to resist scratches better than polyurethane paint, but has held up remarkably well, and will be easy to blend a touch-up when necessary... It looks and feels good. I think that one could use a catalytic polyurethane for added durability.
There are professional/commercial coatings superior to what I concocted. Possibly order from Airstream/Alcoa/Kaiser/Reynolds, a factory coated aluminum sheet.
Yup, it took a while. Scribing the wall to hood contour was tedious, but it was a rewarding challenge, and less than a hundred bucks in material including the wall and hood metals.
Again, thanks. I much enjoy reading posts from folks sharing their restoration, travel, and camping discoveries. You're inspirational, and I wish that I could contribute to, as much as I've learned from, this fabulous forum.
ID:	236942   Click image for larger version
Old 04-24-2015, 08:03 AM   #14
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
You have a gift.
NavyCorpsman is offline   Reply With Quote
Baraldi Range hoods, The Stainless steel Range hood found in 2009 Airstreams AeryCorp Commercial Listings 18 05-10-2016 01:41 PM
Refrigerator, range hood fan and light and burners all out BambiBirder Electrical - Systems, Generators, Batteries & Solar 4 09-08-2014 01:00 PM
Hood/hood lights and water heater stopped working!!! Thomas_G Electrical - Systems, Generators, Batteries & Solar 1 06-17-2013 12:49 PM
Mosaic tile back splash tkasten General Interior Topics 12 01-01-2012 02:14 PM
back splash walls in aluminum; CCD owners please help SmokelessJoe Cabinets, Counter Tops & Furnishings 5 05-09-2007 10:43 AM
