Old 08-11-2017, 08:34 PM   #1
Bexar's Avatar
1960 24' Tradewind
San Clemente , California
Aluminum Interior Segmented End Cap-2 (1960 Tradewind)
Decided to create a new post for this 60 Airsteam based on an earlier post by Larry B who did all the heavy lifting figuring out how to cut the aluminum segments and how to install them.
I've changed the material to 2024 T3 Alclad to match the now stripped interior aluminum skin based on forum advice. He used 5052.
Also have found the ribs of the infrastructure are 1-1/2" thick until the cut off edge of the original fiberglass endcap is reinstalled. At that point and at that interface a 1-3/4" thickness is established. This is a must because without the old fiberglass edge in place you can cannot close the 1/4" gap. And since the other edges of the new panels where they meet the walls and front window have 1-1/2" ribs, the spacer blocks have to be different sizes. I'm starting with 1-3/4" at the ceiling, then 1-5/8" midway, and ending at 1-1/2" at the windows and edges. Hope this makes sense!
Do the newer Airstream's have thicker 1-3/4" ribs?
Bexar is offline   Reply With Quote
Old 10-05-2017, 09:07 PM   #2
Bexar's Avatar
1960 24' Tradewind
ID:	296335Click image for larger version
Progress! But did not foresee Larry B’s measurements were for a later Airstream. These panels are laying out differently and will take additional panels to make up for a lower starting point for the first panel on each side.
Aluminum Interior End Cap segmented larry b General Interior Topics 65 05-31-2019 09:02 AM
Interior aluminum end cap Cochese Interior Restoration Forum 11 11-20-2016 04:53 PM
1960 Airstream Tradewind :: 1960 Airstream Tradewind streaming24 Airstream Registry Discussions 0 09-03-2015 02:53 PM
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
