Old 06-05-2011, 05:53 PM   #1
NoMoSOBs's Avatar
1971 31' Sovereign
1998 30' Excella 1000
Aylett , Virginia
Images: 14
Aargh- how do I remove this cabinet??
I'm trying to pull the curbside rear cabinet out of my '98 Classic to work out a dent in the back corner. I've removed maybe 4 screws that I can find, (all in the wardrobe section) and I can't budge it. Does the upper cabinet need to come out as well?
John T.
TAC VA-16
NoMoSOBs is offline   Reply With Quote
Old 06-05-2011, 07:27 PM   #2
InsideOut's Avatar
1956 22' Safari
Edgewater , Colorado
Images: 94
Looks like it.
I'm not familiar with newer trailers, but I know with the vintage ones, they were built from the back forward - so anything in front of the cabinet (or anything installed after it) would have to be remove first - at least until you get to a break in the built-ins.
Good luck!
Shari
RMVAC | WBCCI DenCO Unit | Tin Can Tourists | Sisters on the Fly | BIRDY - our '56 Safari
Old 06-06-2011, 01:28 PM   #3
Dan@LED4RV's Avatar
Kernersville , North Carolina
Can you take a picture of the outside and post it? The dent
Dan Brown
Kernersville NC
Dan@LED4RV is offline   Reply With Quote
Old 06-06-2011, 07:45 PM   #4
NoMoSOBs's Avatar
1971 31' Sovereign
Aylett , Virginia
Images: 14
There's really nothing in front of it that's blocking it from being removed. Looking at the picture now, I'm pretty sure I can remove the upper cabinet beside this one and pull it out. Of course that is IF I can find the rest of the screws, and I'm sure I'll end up removing the bed as well. I was just curious to see if anyone else knew how to get it out before I pulled too hard and broke something. Dan, I've tried various methods of pulling it from the outside, but to no avail. If you saw the dent, you'd understand. Really the panel needs replacement, but I'm trying to make the best of it to use the trailer now and work on it in the off-season.
John T.
TAC VA-16
Will standard HD cabinet latches work? adwriter73 Cabinets, Counter Tops & Furnishings 0 05-14-2011 01:09 PM
Need to see pics of med cabinet rverforlife General Interior Topics 1 05-10-2011 12:05 PM
nt-22A cabinet tracker Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-13-2011 09:54 AM
2003 safari - how do you remove black water tank? greenrvlife Waste Systems, Tanks & Totes 3 04-08-2011 10:15 PM
How to remove slip hub / flange 1970 3/4 bath silversafari Waste Systems, Tanks & Totes 2 02-27-2011 07:40 AM
