Old 05-31-2013, 01:52 PM   #1
1969 27' Overlander
St. Louis , Missouri
A/C now or later!
I've got a gutted 69 overlander. Plannin on doing a shell on resto because of limited space. My plan is to remove the floor, lift the shell to inspect, repair, clean and por15 frame. I have a major leaked coming from the existing AC, which works for a few minutes before dieing and throwing the breaker. I'm wondering if I could put in a new AC now because... dang it gets hot in there. I'm hoping to seal the leak and stay cool while working this summer. I'm thinking I will use a Penguin ll with heat strip. Are there any issues with installing it now? I also thought about buying a cheap window unit and placing it in the door but that seems like a waste of money. Any thoughts or suggestions appreciated.
Noco is offline   Reply With Quote
Old 05-31-2013, 02:24 PM   #2
SteveH's Avatar
Common Sense , Texas
My thought are you wouldn't catch me working inside there in the summer without A/C.
YMMV.
Regards,
Steve
Old 05-31-2013, 03:48 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
First thought is that your old unit may be a easy fix if it is not the compressor. All the parts for the old Armstrong units are readily available. The problem may just be a relay or a capacitor, my bet would be a bad capacitor. Lots of trouble shooting info here on the forums for the old units. I kept old Armstrong unit because it cools great but it did have a serious leak. I found the main leak was inside the unit where the freon and power lines go through the top of the trailer was the main problem. There were smaller leaks at a couple of attachment points. If you are not going to try and save the old one, then by all means go ahead and get a new one now. I worked 2 Mississippi summers in mine without AC (did not have a 30amp circuit at the time) and it was not fun.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
2nd A/C for a 34' - 2002 Classic HighFlying 2001 - 2005 Classic 10 11-17-2011 07:04 PM
A/C leak only with sideways rain Bowmans Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 10-07-2011 10:47 AM
A/C Pops Breaker RichWoodward Furnaces, Heaters, Fireplaces & Air Conditioning 28 07-19-2011 05:57 PM
Second AC pendletonkm 2011 - 2015 International 3 07-19-2011 12:32 PM
No Power To A/C (power at breaker) vhariable Electrical - Systems, Generators, Batteries & Solar 3 06-28-2011 05:54 PM
