Old 07-10-2018, 10:07 AM   #337
1970 25' Caravanner
Incline Village , Nevada
Thanks all for advice. Colin is suggesting jack axle in place then use existing holes on axle mount plate to drill through frame or vice versa from frame into mounting plate with or without a washer welded to frame as additional support for what will end up as an oblong hole. Alternative would be drill new holes through both. Guess have no choice but to drill. Not excited about doing that underneath a trailer sitting on jackstands.
Jeremy9107 is offline   Reply With Quote
Old 07-10-2018, 10:09 AM   #338
1970 25' Caravanner
Acceptable belly skin aluminum alloys
Found a source for aluminum sheet up to 103" wide that you don't have to buy by the thousands of pounds. Their alloy is 3003 H16. Believe the recommendation is for 5052 for the underbelly. How similar are these?
Old 07-10-2018, 04:44 PM   #339
Central , Mississippi
'70 Caravanner restoration
I've used 3003 on several bellypans. No worries.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-10-2018, 08:57 PM   #340
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
3003 is what I bought. No issues.
Matt
rugjenkins is offline   Reply With Quote
Old 07-12-2018, 08:27 AM   #341
1956 22' Safari
Williston , Vermont
Is your source local to you? I am in the market for belly pan material.
What are your thoughts on how you would apply it, 103" is pretty wide?
Mark
Our restoration Blog
steinVT is offline   Reply With Quote
Old 07-12-2018, 07:19 PM   #342
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I've done three belly pan replacements and used the 5052 material at .025 thick. It isn't as strong as the 3003 heat treated stuff, but it is a bit cheaper. I buy it in a 48" wide roll at the length I will need to cover the area. I cut 48" wide by usually about 66" long and start at the rear of the trailer. I rivet it to the frame rails and cross members, and to the belly wraps from the exterior skins. Then I lay the next piece, and the next piece and so forth. I rivet the sections together as I go. Every piece needs hand trimmed to provide clearance for this propane line, that axle mount, and the steps over there.
Yep, I have a lot more seams than Airstream does, but I'm working on my back under the trailer, I need easy to handle. I don't worry about the seams as I hope they will allow additional draining if water gets in there.
David
Name:	1603 Belly Aluminum New (Small).jpg
ID:	316716   Click image for larger version
Name:	1604 Belly Pan New 1 (Small).jpg
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 07-13-2018, 12:15 AM   #343
1970 25' Caravanner
Glad to know 3003 will work. What about at thickness of 0.040"? Thinking most use 0.025 or 0.032. Will have some 90 degree bends so want to be sure can work this stuff.
steinVT. Check out https://trailermarketing.com/product...sold-per-foot/. Have searched a long time and called dozens of places and this is only place could find that sold Alum wider than 48" without having to buy several thousand pounds. They get this from Aurora http://aurorametals.com/index.html who confirmed it is 3003.
Other option was 48" wide :
Aircraftspruce 3003 0.032" $100/4'x12' sheet http://www.aircraftspruce.com/catalo...?clickkey=3797
Aircraftspruce 5052 H32 0.032" $98.75/4'x12' sheet http://www.aircraftspruce.com/catalo...?clickkey=3797
Locally have PDM who quoted $84/4'x12' sheet of 5052H32 0.025" https://pdmsteel.com/products/stainl...-aluminum.html
For our layout, $21 per linear foot works out cheaper than if buying sheets of 48" wide (depending on shipping).
As far as how to apply...no idea yet. Am used to winging it. Probably a lot of helpers and a lot of clecos. Won't be as methodical as David. Am trying to have one beautiful piece in front of axles though except for cut out that goes below fresh water tank. Figure will never have to remove it. Over and behind axles will be different as want to create separate pieces as means to access gray and black tanks without taking too much skin off. Have also modified back there to accommodate relocation of a black tank that is deeper than the frame rails. Thus have to do some bending of Alum. Will work on diagram and post so can get feedback on how terrible the idea is.
David. Recall that during removal of ours there were spots where the belly skin wrapped far enough up the side to tuck between the outer skin and C channel. Did you originally have something similar? It looks like your belly skin stops short of wrapping up each side. Asking cause was thinking don't need all that overlap.
Old 07-13-2018, 08:10 AM   #344
We have a local industrial specialty metals supplier that stocks 3003 in 4x10 sheets. The last I bought was under $50 a sheet. I also piece together the belly pan. Frame rail outward I run the sheets long ways. Between the rails I run it cross ways just like the plywood decking. That way I can leave some of the cross sections held in with clecos until the final plumbing connections are made.
Old 07-13-2018, 07:20 PM   #345
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I only overlapped about 8" under the wraps on each side.
I might add that I purchased my 5052 aluminum in a roll 48" wide.
David
WBCCI #8607
VAC Region 11
Old 07-15-2018, 06:25 AM   #346
1956 22' Safari
Williston , Vermont
3003 h16
Jeremy, thanks for all of the sources.
I admit, there is something elegant in forming a single piece belly pan. Not sure I would be up to the stress. Maybe if you first made a full size template.
Regarding the 3003 H16, the H16 refers to the heat treat.
"3003-H16 aluminum is a type of 3003 aluminum. It is furnished in the H16 temper. To achieve this temper, the metal is strain hardened to a strength that is roughly 3/4 of the way between annealed (O) and full-hard (H18)."
I would want to get a sample to play with. It might be too stiff to do what you want.
Mark
Old Today, 12:35 AM   #347
1970 25' Caravanner
Thanks for that tidbit steinVT. Maybe rugjenkins and HiHoAgRV can share if their 3003 was H16 and whether they attempted to bend?? Could use the 3003 in front which would be biggest piece as there are no bends and then 5052 48" sections where need to bend around frame and for bumper box.
1958 Caravanner Complete Restoration Raintight General Repair Forum 0 10-05-2016 05:37 PM
1970 Airstream Caravanner :: 1970 Airstream Caravanner Fishbowl Airstream Registry Discussions 0 12-29-2012 12:45 PM
Caravanner :: 1957 Airstream Caravanner floyds1 Airstream Registry Discussions 0 08-19-2011 08:32 AM
'57 Caravanner Island Girl :: 1957 Airstream Caravanner pbearsailor Airstream Registry Discussions 0 08-19-2011 08:30 AM
Vent cover restoration 76 Caravanner crowemagnon Roof Vents, Skylights & Fans 7 09-13-2010 03:19 PM
