Old 01-04-2012, 08:08 AM   #1
JGS
1967 30' Sovereign
Saint Augustine , Florida
'67 Sovereign Wall Paint
I have reecently purchased a 1967 Sovreign 30' Walls have been ckeanced and are ready to paint. Doew anyone know if Latex is OK? Did AS have oil based paint. If so I can't go over wth lates as it won't stick well. Please advise. If it is LAtex I ma planing to do Kils primer 1st. If it is not Latex and information (PMS color etc) would be helpfull. Thanks, John
JGS is offline   Reply With Quote
Old 01-04-2012, 10:02 AM   #2
The vinyl coating on the walls, "MUST" be sanded with at least 150 grit sandpaper.
Not scuffed but SANDED, then the paint will bond.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-04-2012, 11:38 AM   #3
1977 31' Sovereign
1989 34' Excella
McHenry , Illinois
The walls are likely to be a little sticky from the exuding plasticizer from the flexible vinyl coating on the walls. Very few paints will be able to stick to it. You first need to get the plasticizer off the wall and then use a primer to get proper adhesion. It is much like the vinyl wallpaper that is used in '70s bathrooms.
Old 02-03-2012, 07:22 PM   #4
stowaways's Avatar
2007 27' Safari FB SE
1969 31' Sovereign
Ft. Worth , Texas
About To do same for '69 31' Sovereign Land Yacht... same advice apply? Sorry to hijack...
Sammie, Krystal, Lucas, Spencer & Jake!
stowaways is offline   Reply With Quote
Old 02-05-2012, 04:09 AM   #5
1977 23' Safari
1986 34' Limited
Idaho Falls , Idaho
Does a 67 have the vinyl "wallpaper" or Zolatone? Our 64 has zolatone only. What year was the switch made from zolatone to vinyl "paper"? Or is this a different "vinyl"? And zolatone must be oil-based it is so tough, yes?
Vivian
Richard and Vivian
Caliban The Wonder Dog: gone but not forgotten
Cerberus
Too many vintage A/Ss...
Need 62 FC tub & lav cabinet
Landshark is offline   Reply With Quote
Old 02-05-2012, 09:03 PM   #6
Vivian
The vinyl-clad aluminum interior walls started with the 1965 models.
All the vinyl-clad aluminum that Airstream used, was exactly the same, except for the vinyl color and design.
It is not in any form, a paper.
Andy Rogozinski
Inland RV Center
Corona, CA
Shower wall covering peeling ?? Solution ?? polarlyse Sinks, Showers & Toilets 6 02-06-2012 08:08 AM
How to deal with this paint issue? Eaglemate Clearcoat, Exterior Paint & Trim 4 09-13-2011 10:46 AM
Need a wall measurement for 2000 bambi Gator Ron 1999 - 2004 Bambi 0 09-11-2011 04:15 PM
Wall Covering Pictures Roadrunner Upholstery, Blinds, Walls & Interior Finishes 7 05-19-2011 10:50 AM
Interior Wall Structure Strip chowman2011 General Interior Topics 3 05-17-2011 08:09 AM
