Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 12-22-2003, 11:04 AM   #1
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
67 Overlander: convert to twin beds
I just acquired a 1967 Overlander with double bed/closet instead of twin beds. Due to family considerations, I'm considering switching over to two twin beds instead of the current configuration. At issue is the bathroom door: Is it shifted street side a bit in models that came with twin beds?
I've been looking at the photos everyone has been kind enough to post, and can't decide if twin beds are doable in my trailer. Also, does anyone have photos of how the twin bed is constructed? Is it just a narrower version of the double bed?
Old 12-22-2003, 11:17 AM   #2
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
Door location
The doorway in the twin configuration is in the center.
The mattresses are simply rectangular and are positioned slightly in each doorway, about 3 to four inches.
I hope this helps and welcome to the forum.
Smily
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 12-22-2003, 11:32 AM   #3
Navigator
Profile:
I am in a similar situation, however my rear bedroom is bare.
I would like to purchase (2) matresses with a curve profile on 1 corner, and in order to flip over the matresses, they would have to be the same width. [For example, the right side mattress when flipped would then become the left side mattress] The length of each mattress would remain 74 inches long. Ideally each mattress would then have to be 36 inches wide. The right side mattress would extend the full width of the bathroom partition, where as the left side mattress would extend into my aisle about 9 inches.
I think that the difficulty lies in obtaining correct mattresses first, then building the bed frame.
Anyone know where I can get the above mattresses without spending $1,200.00 for Bear Beds?
Dick
Navigator is offline   Reply With Quote
Old 12-22-2003, 11:41 AM   #4
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
I bet if you take your dimensions to a local mattress company they will make them for you with a minor custom charge over the regular price of the same basic size.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 12-22-2003, 12:41 PM   #5
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Personnaly I'm going to check with the local mattress company and see how expensive it will be.
Check out this Thread on Mattress's It has some links to companies that will make Foam matress to your deminsion. The rounded Airstream corner is a stock shape with several companies..
Also do a Search (Top Right Corner) on Mattress's and there maybe a few other companies not listed in that thread.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 12-22-2003, 05:52 PM   #6
flyfshr
ModeratorMan
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
I'm not sure if you have a Beds Direct in your neck of the woods, but I highly recommend them. We had custom mattresses made and are they ever comfortable. Although our twin beds are in the center in our rear bath model, I asked if they could make a rounded corner mattress to fit a particular radius and they said they could. It took them a little over a week to make our mattresses and the cost was appr. $150 each.
When out camping and travelling, I insist on a good night's sleep and these mattresses do the trick. Good luck.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 01-13-2004, 07:24 PM   #7
66whitebread
Profile:
Exchanging My Twins
I just picked up the interior from a 68 overlander this weekend, actually it is still in my truck. I plan on using it as a pattern to build the full bed/desk closet combination. When I pull the twins out I will have no problem selling them. It should be within a month or so. Anyone that is interested please contact me.
66whitebread is offline   Reply With Quote
Old 02-16-2004, 11:13 AM   #8
riverdreamer
Profile:
Last summer we pulled out the closet on our 1971 Overlander and put the gaucho couch that was in the front of our coach where the closet was. We bought a jackknife couch fom a 1961 Airstream Sovereign to replace the front couch, and are in the process of getting it recovered. The front gaucho fit exactly into the side.
riverdreamer is offline   Reply With Quote
