Old 03-18-2015, 02:19 PM   #29
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
VIN is confusing. Looks like 24D-0200.
There is a 1959 Tradewind listed on Vintage Airstream Model Year Reference chart with a VIN of 24D-0273, which seems to indicate yours is older than 1959 but I think that was the year the TW debuted and there is no other 24 footer in that time period??
BambiTex is offline   Reply With Quote
Old 03-18-2015, 05:51 PM   #30
flygrrl
flygrrl's Avatar
1962 19' Globetrotter
Winchester , Ontario
1960 tw
My references (Airstream Serial Numbers by year from Airstream.com) show that the 0 before the 200 is the year therefor she is a pretty 60. The D was the Jackson Centre code, it looks like the twins were made in California and the doubles in Ohio in 1960. Tradewinds were 24', and she is not an International because there is no I at the beginning of the serial#.
So, 24D-0200 is right on. Width 96". Dry weight listed at 3200-3450 and tongue weight 340.
TV: 2007 Jeep GC Laredo diesel
Toy: 1995 Jeep YJ
Experience is what you get from not having it when you needed it.
flygrrl is offline   Reply With Quote
Old 03-19-2015, 06:39 AM   #31
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
BUT the nameplates clearly indicate it was built in CA...
Old 03-19-2015, 07:34 AM   #32
1960 24' Tradewind
Biltmore Lake , North Carolina
Vin
Thanks!
24D 0200
#359
Donnagoes is offline   Reply With Quote
Old 03-19-2015, 07:46 AM   #33
1960 24' Tradewind
24d 0200
#359
Old 03-19-2015, 08:27 AM   #34
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Link?
Old 03-19-2015, 09:15 AM   #35
KCN
KCN's Avatar
Jackson , Wyoming
It's a puzzle because VIN's weren't standardized until the mid-60's. Coupled with that is the fact that California-made coaches had to conform with the Department of Housing regs beginning in 1958 so you have that extra badge on there with numbers that don't necessarily correlate to the coach manufacture.
But, it looks like yours is a California-made 24D - 24-foot Double, and that length makes it a Tradewind. As with cars, model years started manufacture the previous year, so a trailer badged as a 60 was made in 59 and sometimes the manufacture date confuses the model year date. So yours could have been manufactured 3/59. The 0200 could be 1960 and #200 in production sequence.
Check with vintageairstream.com - tons of good info on that site
KCN is offline   Reply With Quote
Old 04-12-2015, 03:42 PM   #36
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Oh boy, I just found this thread. You definately have a TradeWind based in the serial number. 24 = TradeWind / 24 foot in length - bumper to ball, D = double bed, 0200 is the production number off the assembly line for this model from the CA plant and 359 was the model year = March of 1959. Yours is a CA built unit because of the streetside toilet and curbside tub/shower. I have been keeping an Early TradeWind Registry based on serial numbers and have 166 TradeWinds listed with the inclusion of yours.
CA and OH built TradeWinds, as well as other models, used a different coding style as you can see from the link below from RJ Dial's Archives. I have serial number 24T-0114 - 858 from the CA factory when it was located on Firestone Blvd in Norwalk.
1959 Trade Wind 24' - Vintage Airstream
You'll find RJ's archive site to be invaluable for reference and ideas. If you have refurbishment questions, just ask away. Congrats on your new-to-you early TradeWind. They're the perfect size and era of trailers IMHO.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 07-30-2015, 04:49 PM   #37
1960 24' Tradewind
Claremore , Oklahoma
Water fill?
I also have a 1960 tradewind in the process of bringing it back to life. I have a question about hooking up to city/campground water. If your looking at the back of the trailer there is a water valve behind the bumper on the left side (facing the back) is that the fill or the drain for the water lines/water heater?
Jake72311 is offline   Reply With Quote
Old 07-30-2015, 05:05 PM   #38
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Hi, We have a much smaller trailer, a 1963 Bambi. Hubby restored it about 10 years ago... at the time of the restoration he had a lengthy thread with lots of how-to's and photos... when you have some time you might want to scroll through to see what problems he came up against and his solutions. I can tell you we refurbished everything we could and didn't purchase new unless necessary... All our original appliances were brought back to life... so that saved us bundles! Hubby did all the work including completely rewiring, plumbing, etc. You definitely want new wiring and plumbing. You might also think about upgrading lighting to led, etc. to save battery power, especially if you camp without hookups. Have fun and enjoy the ride... take thousands of photos, especially when dismantling... you will want to refer to them! Here is his thread: http://www.airforums.com/forums/f36/...mbi-17925.html
Mrs. NorCal Bambi traveling in S Tardis ~ from the Great State of Jefferson!
My blogs: http://yrekahistory.blogspot.com
http://siskiyoucountycamping.blogspot.com
http://campingalongi-5.blogspot.com/
CaddyGrn is offline   Reply With Quote
Old 07-30-2015, 05:56 PM   #39
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Hi Jake ~ welcome to the group. Its hard to tell what that connection is without actually seeing a picture of it. Could you post one or two? In fact, I'd like to see pictures of your whole trailer, inside and out.
If I haven't already, I'd also like to add your TW to the registry.
FF
Old 07-30-2015, 06:38 PM   #40
1960 24' Tradewind
I will have to post a picture of the connection tomorrow when I get home but here's some photos I have on my phone. If I can figure out how to load them
Old 07-30-2015, 06:54 PM   #41
1960 24' Tradewind
Work in progress theses are just the most recent photos on my phone
Old 07-30-2015, 06:56 PM   #42
1960 24' Tradewind
Still have more gutting to do
'74 Tradewind project Baseman 1970-79 Tradewind 17 03-27-2016 02:11 PM
'73 Tradewind Project constructor 1970-79 Tradewind 89 08-14-2014 05:53 AM
1975 Tradewind project - questions! lots of them! keithmac 1970-79 Tradewind 4 03-05-2011 10:10 AM
Got a project here on a '68 Tradewind harestream 1959-69 Tradewind 21 04-05-2007 10:10 PM
