Old 11-23-2013, 05:26 PM   #1
submariner's Avatar
1948 22' Liner
1989 34' Limited
long beach , Mississippi
Liner ID help
Hi guys. I need some help identifying an old airstream. From the shell and length it looks like an old Liner with pipe frame . The vin is only partially on the type plate.. Someone drilled though the forth number..
The first three are 126 . It is California made .Any help here ? I hope to verify that it is a 48.
submariner is offline   Reply With Quote
Old 11-23-2013, 06:57 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
Got any Pictures?
reinergirl is offline   Reply With Quote
Old 11-24-2013, 07:04 AM   #3
submariner's Avatar
1948 22' Liner
1989 34' Limited
i dont have any pictures at the moment, but was hoping that someone knows, how to decode the ID. the AS does have the looks of a liner, with single axle, one window in front of the door and 2 windows after the door.
Also has the recessed entry step.
the pipe frame does look solid, however i can turn the pipe to both directions a little..
Old 11-24-2013, 11:08 AM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Liner ID help
Greetings submariner!
I found the following data and the VintageAirstream.com website that may be of help:
1947 Liner 22 -- VIN --1001 to about 1090
1948 Wee Wind 16 -- VIN -- 3001 to about 3041
1948 Trail Wind 19 -- VIN -- 5001 to about 5018
1948 Liner 22 -- VIN -- 1090 to 1280
1948 Whirlwind 28 -- VIN -- 2001+
From the data above, it looks like it may be a 1948 Liner. Reading and hearing of the experiences of several who have restored pipe frame Airstreams, any movement at all in the center pipe is reason to be concerned about the advisability of trying to tow the trailer on its existing running gear. Most with whom I have had contact recommend flatbedding a pipe frame trailer unless there is absolutely no evidence of movement in the central pipe.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 11-24-2013, 06:04 PM   #5
submariner's Avatar
1948 22' Liner
1989 34' Limited
Thanks for that info.. Looks definitely like I got a real 48 liner here..
As for the pipe frame.. I got a good 15 degree turn to both sides.. The liner is in rough shape and I will pull the shell definitely off to either fix or build a new frame. As for transport.. It already made it on a flatbed to my backyard :-).
As for the resto.. I won't start till after Christmas... Is there anywhere a good write up about the pipe frame?
Old 11-24-2013, 06:34 PM   #6
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Thanks for that info.. Looks definitely like I got a real 48 liner here.. As for the pipe frame.. I got a good 15 degree turn to both sides.. The liner is in rough shape and I will pull the shell definitely off to either fix or build a new frame. As for transport.. It already made it on a flatbed to my backyard :-). As for the resto.. I won't start till after Christmas... Is there anywhere a good write up about the pipe frame?
Pictures man! We need pictures please!
Congrats on your trailer arriving safely to your back yard.
Mike
desertair27 is offline   Reply With Quote
Old 11-24-2013, 06:37 PM   #7
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Liner ID help
I don't remember anyone posting a detailed progress-type thread here on the Forums about rebuilding a frame for one of the pipe frame Airstreams, but the following threads do have some data about pipe frames:
Replacing Pipe Frames -- Sadly, the gentleman, Bud Cooper, who is mentioned several times in this old thread passed away several years ago. He was definitely well-versed in the engineering of the pipe frame and its replacement.
1949 curtis wright clipper tube frame help -- Several post down in this thread is a somewhat detailed post about one method of structuring a new frame to replace the pipe frame.
New Frame -- This thread deals with constructing a new frame that is designed to maintain the appearance of the pipe going down the center.
I am sure there are other threads, but these were some that prompted my memory of having read them when they were among the latest Forum activity.
Try the "Google Search" feature under "Search" here on the Forums and the results can be astonishing!
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
