02-04-2016, 07:50 AM
#101
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
I hate it when this happens
All my belly pan wraps had to be scrapped. I measured the vertical sides wrong....the inside part which fit under the C channel needed to be two inches longer to really work well. Oh well, it was a good idea. The new, correct, ones are beautiful. I work belly insulation today and then the completed pan sections.
02-04-2016, 06:19 PM
#102
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Oh how many times have we vintage Airstream enthusiasts made an error that costs time and money. Many times there is a rework or work around that salvages the material and the time. But I suspect you start over as it must be done right. The finished trailer will be first class.
I took a chance on an older converter working and installed it taking quite a bit of time. Then the thing demonstrated it could not maintain 13.3 volts maintenance charge rate. So out it came and in went the new one. I think it cost me about 4 hours of wasted time. And that was just today's mistake.
David
02-12-2016, 06:28 PM
#103
1953 32' Liner
1955 22' Safari
Valley View
C channel is in
Part of the belly pan install required that the C channel be replaced too. So, new C channel all the way around. .050 all the way round for added strength. Working around a lot of the problem areas I had with the wheel wells and level flooring....it needed the Pro help.
02-12-2016, 06:30 PM
#104
1953 32' Liner
1955 22' Safari
Valley View
Insulation...something different for me.
Insulation is going in and seems OK. Typical insulation job...a pain.
02-14-2016, 10:26 PM
#105
1953 32' Liner
1955 22' Safari
Valley View
He really tried
I had to stop insulation work to fix a terrible bad rear window leak problem. Previous owner must have tried it all. It looks like there was some sort of hardening plaster forced in around the window edges. When that did not work he tried a white caulking...that failed too so he went the silicone route. All bad ideas with no craftsmanship involved. I drilled out the windows...wrong rivets used for his installation....then spent hours cleaning up the frames. Then replaced the screen with my supply of bronze screen.
02-15-2016, 06:15 AM
#106
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Forstner bit
Originally Posted by Melody Ranch
This might be a tip to some. In order to have a flush floor for final work I had to have a way to flush the carriage bolt head. Hammer just did not do it. So I used a hole saw and cut a 1/8th inch deep , +/-, groove. Then a chisel out the center piece. The carriage bolt now can be hammered in flush.
Hi Robin! I guess I've missed this thread.
Beautiful ol Liner! Nice work, as always.
What is the insulation that you chose to use?
I know this is from months ago, but a 1" Forstner bit is the easiest way to counterbore the wood sub-floor for the elevator bolts to be flush. It works best to use the Forstner bit first, then use the 1/4" drill bit to drill through the rest of the sub-floor and frame.
I'm sure we'll see you in the Liner soon, yeah?
Lance
02-15-2016, 06:33 AM
#107
1953 32' Liner
1955 22' Safari
Valley View
I should have known that
1" Forstner bit.....I should have thought of that. I even have them here.
The insulation is a new type of duct wrap. Supposedly won't absorb moisture, has a high R value and relatively easy to cut.
The end cap install is next and that could be tuff as a solo job. It all continues.
02-15-2016, 11:38 AM
#108
NO HUMBLE OPINION
1968 20' Globetrotter
ANN ARBOR
, THE GREAT LAKES
Your Thinking chair
I'm admiring your restoration chair. Looking through your posts, it's apparent that it has seated countless hours of contemplation and innovation.
I'm spending my time on the thinking end of a five gallon pail, which has been part of so many eureka moments, that I'm going to have it bronzed, and keep it as part of my camping system..
It's very helpful when skilled folks like you explain your accomplishments and errors.
Thanks for your contributions.
02-17-2016, 04:38 PM
#109
1953 32' Liner
1955 22' Safari
Valley View
some problems
The front window(s) are proving to be a pain to disassemble and replace the screens before sealing and reinstall. I am down to the last action...but, not sure about it. The three screws under the seal are out and the old sealant broken loose. Now it "looks" like the outer edges are crimped to the frame....I don't want to break or bend anything....any experience here would be welcomed before I start tomorrow AM.
02-25-2016, 10:15 PM
#110
1953 32' Liner
1955 22' Safari
Valley View
still on front windows
I have to finish up rebuilding and installing the front windows before any progress can be made. The windows have to be in and sealed before the insulation, before the polished end cap reinstall, before the electrical wiring can be run. There is a sequence which as to be followed. I did clean and acid etch the window frames. New hardware from Vintage trailer supply. New seals too. These windows are a real pain. Bronze screening is hard on the fingers...I am leaving a bloody trail.
02-26-2016, 09:20 AM
#111
Central
, Mississippi
Those bloody screens will make you scream as you reassemble the interior with them already mounted. I learned a new chant...
Don't bump the screen
02-29-2016, 08:49 AM
#112
1953 32' Liner
1955 22' Safari
Valley View
I am at that point
"Don't bump the screen." I am there now. The windows in now... in and sealed. I had to rebuild all the interior bracing from prior owners work. I will do the end cap insulation, then wiring, then the polished interior end caps. A delicate job by myself...."don't bump the screens."
02-29-2016, 07:24 PM
#113
1950 Flying Cloud 7039
1950 21' Flying Cloud
Allen
Is that a water inlet above the electric?
03-03-2016, 09:56 PM
#114
1953 32' Liner
1955 22' Safari
Valley View
wiring
After most of the insulation work and the window rebuilds at both ends...wiring. I mark pathways with yellow and junction box locations with red.
03-05-2016, 10:33 AM
#115
Central
, Mississippi
No matter how much I plan ahead, I always end up with a junction/ outlet box just a few inches from ideal when I start installing the interior. Hope you have better luck
03-05-2016, 04:29 PM
#116
1953 32' Liner
1955 22' Safari
Valley View
moving on
I have learned to leave plenty of extra wiring to allow for J box placement. I made some of my neutral (ground) wires to short on my last project....that was a pain.
03-05-2016, 04:32 PM
#117
1953 32' Liner
1955 22' Safari
Valley View
It is hell to work alone
Some jobs just beg for that extra pair of hands. The reinstall of the end caps was one of those jobs.
03-05-2016, 07:46 PM
#118
1986 34' Limited
1975 27' Overlander
Conifer
That is one fancy end cap! It sure has a lot of difficult sheet aluminum cutting and forming. You can sure see why Airstream went to fiberglass and then plastic for end caps. The cost must be much lower.
I think people will look at that end cap in awe when the Liner is out of the barn.
David
03-06-2016, 02:21 PM
#119
1964 17' Bambi II
Schererville
, Indiana
Love the endcap! I dream of a 13 panel trailer...Why can't I just be content with what I have?? They're so cool!
Becky
1964 Bambi II
1988 Avion 32S
03-08-2016, 06:28 PM
#120
1953 32' Liner
1955 22' Safari
Valley View
layout planning
By taking the old wall panels and placing them in position....I can plan the location of the new walls and the electrical layouts better.
