Old 11-01-2015, 08:34 AM   #81
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Ceramic types
Thanks Gene. I now have a lot more to read. I live in my house made with SIPs. Six inch walls and 8 inch ceilings. That was the perfect match for this part of Texas. One of my Red Barns has closed sell spray foam and it is also very effective. In the Airstreams I have tried all but closed cell and am looking at it. Will, however check out you info....but, JEEZE its expensive. Stay tuned.
Did you notice the pictures of the stripped interior? The factory Guys used a generous amount of black adhesive to hold up the insulation. Impossible to remove. Do you think I could use reflectoflex as a clean shine outer layer, then come in with my regular insulation, thereby, getting an airspace and clean inner surface...?
Old 11-01-2015, 08:43 AM   #82
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Airbrite poloish
I used Airbrite from Vintage Trailer supply as the polish on the inner aluminum cabinets. Let me tell you....the coarse level really cut the surface. So much so that I don't need to use the wheel as a first applicator...just go to the wool pad. Its use was more abrasive than I really wanted and now I do have to double up on the "polish" steps to get rid of abrasive marks. Those are probably a result of the sisal wheel, however. More to follow.
Name:	Airbrite and cabinet.JPG
Old 11-01-2015, 12:00 PM   #83
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Red Barn Liner
Mine too has a lot of the black stuff. Especially the end caps.
I really think the insulation probably does more for noise than heat. The ribs transfer so much heat. I do believe a non metallic rib would do the most for limiting heat transfer. Some people try to put a barrier between the inner skins and ribs. I am not sure how well this works if your rivets are tight. Some barrier on the ribs without compromise to the strength of the monocoque construction. I think too soft a barrier will allow movement if you cannot get the rivets tight. That is just my thoughts.
$50 fiber, $20 epoxy, homemade vacuum bag and we can make a rib. I will pay for the materials if you are willing to use it on one rib of your trailer for an experiment. 😀
http://stores.infinityfrp.com/carbon...z-x-4-wide-3k/
FC7039 is offline   Reply With Quote
Old 11-05-2015, 12:38 PM   #84
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
rainy day project
I never thought I'd see it rain again, until this recent rash of floods here. Tornados and rain today so I am inside instead of under the Liner out front of the Barn. I made up the rolled edges I plan to use for the belly pan replacement.
Name:	Belly pan side wraps.JPG
ID:	251665   Click image for larger version
Name:	Belly pan wraps #2.jpg
Old 11-05-2015, 07:10 PM   #85
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
So, what radius did you make the wrap arounds? And how did you get them so good?
I used piece of large diameter plastic pipe and rolled the aluminum around it the best I could. Maybe you have a rolling machine in that red barn of yours. Or you formed it with your tailgate.
David
Old 11-05-2015, 08:49 PM   #86
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
not a day for work outside
The roll reminds me of the old Mexican woman who worked at Warnek Hat store down on the border. She would steam the brim of a new hat and use her belly to form the curve of the brim. It was the perfect curve. Funny how that brim got wider every year....for the twenty years I got hats from them.
I just made a cardboard template, used a roller and then a brake to make the top 2inches flat. I'm still hoping it all works out.
Old 11-05-2015, 08:51 PM   #87
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
storms coming in
Tornados skipped over me. Got lots of areas around the Barn, however.
Name:	tornado inbound.JPG
ID:	251688   Click image for larger version
Name:	tornado inbound #2.JPG
Name:	tornado inbound #3.JPG
Old 11-06-2015, 07:30 PM   #88
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Wow, that is a big thunderhead. We heard on the news about all the severe weather Texas has experienced of late. Bad drought a couple of years ago, and now bad floods and tornados. You folks need to get back to good old boring weather.
Thanks for the description of forming the belly wraps. I've bent aluminum over my knee once or twice, but never my belly. Forming my wrap with a large diameter plastic pipe wasn't the greatest method. It was just a 6 foot section behind the wheels that got bent up when I ran over a truck tire tread on the highway. I have used a roller in a metal shop before. But I never have tried an English wheel. Metal working would be very interesting to me.
Glad the storms missed your ranch.
David
Old 11-10-2015, 09:28 AM   #89
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Door hinges for a door within a door entry
Vintage Trailer Supply won't carry any more. Where can I find a Fabrication Shop to make some for us...?
Old 12-17-2015, 10:26 AM   #90
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
while the pan is being worked
I have all the wood interior pieces out and stripped. Am replacing all the original cabinets with new ash as original.....originals had to many drill and nail holes for my liking. The doors and drawer fronts will be reused. The cabinet framing will be replaced too..damaged on removal.
ID:	254016   Click image for larger version
ID:	254018   Click image for larger version
Name:	curbside closets.JPG
Old 12-17-2015, 06:50 PM   #91
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Building cabinets is a key piece of any Airstream renovation. Maybe woodworking was a hobby of yours at one time. You do very good work.
I can get through the mechanical work pretty good, but I am no good at cabinet making and finishing.
Did you find someone to make your hinges, or did you just make them yourself?
David
Old 12-17-2015, 07:01 PM   #92
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Beautiful cabinets, Robin!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 12-24-2015, 01:58 PM   #93
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
those old cabinets
Hi Becky....those are the original cabinets I am rebuilding and refinishing. Overtime I look at the original pictures I wonder why I was not satisfied. I like work I guess.
Old 12-24-2015, 02:00 PM   #94
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
when you have to many old Airstreams
I get confused on which projects I am on. Five old Airstreams an a few old cars.....oops! keep on track
Name:	Rivets and 2024.jpg
Old 12-24-2015, 04:59 PM   #95
FC7039's Avatar
Allen , Texas
Ok. I will bite. What is that?
Old 12-25-2015, 08:28 PM   #96
Becky B.'s Avatar
1964 17' Bambi II
Even the last picture?? Well, they look pretty darn good in the picture! But, you can probably see imperfections in real life that don't show up in the pix. I know I'm a stickler for beautiful finishes, and you're probably the same! I really like this trailer :-)
Becky
1964 Bambi II
1988 Avion 32S
Old 02-01-2016, 08:28 AM   #97
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
It s back from the "Doctors"
My C channel was just beyond repair and the new Belly pan required a two man operation.....so I had to take the Liner into a Friends shop. Two months later I got it all back and am ready to start again. The Pan and Channel work are superior, by the way. I sat in side it yesterday and tried to visualize where I am going with the interior....then pulled out the interior I got....from a 2016 Cloud FB. Placed it in different spots and narrowed the decisions . Then I sealed all the seams inside in prep for the insu;action, wiring and new anodized panels.
Name:	front trial placementr.JPG
ID:	256615   Click image for larger version
Name:	Liner and Nomad.JPG
Old 02-01-2016, 07:35 PM   #98
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I imagine the shell was lifted to install the new C channel. I'm glad you got your old Liner back in good shape.
That 57 Chevy sure looks nice next to the Liner. I suppose that is what you worked on while the Liner was away.
We were at an RV show admiring the new Airstreams. That "U" shaped dinette you found from a new trailer is what my son thinks would work well in his 69 Globetrotter. We saw one at the RV show. The table drops down making a fairly nice bed. The table pedestal was a robust contraption, much stronger, less wobbly than the other trailers we looked at with "U" shaped dinettes. So that is the design idea we have for the front dinette in his Globetrotter.
David
Old 02-01-2016, 07:43 PM   #99
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I imagine the shell was lifted to install the new C channel. The old Airstream ads show two men lifting a shell. So yes, it is a two man operation. I'm glad you got your old Liner back in good shape.
That 57 Chevy sure looks nice next to the Liner. I suppose that is what you worked on while the Liner was away. Tow vehicle?
David
Old 02-02-2016, 11:16 AM   #100
Becky B.'s Avatar
1964 17' Bambi II
Sounds like the very hard, heavy work is finished! I like the colors of the new furniture. Guess you won't need a black tank with your special commode! Haha!😀
Becky
1964 Bambi II
1988 Avion 32S
Red Barn Safari Melody Ranch 1955 Safari 101 01-29-2019 10:59 AM
Red Barn visitors Melody Ranch Cleaning, Stripping & Polishing 72 09-09-2013 01:10 PM
1947 Liner - "1006" :: 1947 Airstream Liner wdscentral Airstream Registry Discussions 0 09-05-2013 05:16 PM
1953 Liner :: 1953 Airstream Liner 57BB Airstream Registry Discussions 0 07-16-2013 04:05 PM
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 01:18 PM
