Old 09-17-2015, 08:39 AM   #61
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
stay tuned
Hi Becky, I may have gotten in over my head here. The Liner was apparently in excellent condition as found....see photo. Then, as I always do, I started digging in and found many things I did not like at all. So, it looks like I will do another "make it for myself" project. I have to get rid of the others and make room. I hate to because they were all labors of love and done right. This one will be special but might be to big for my tastes. I got it because it was so rare and so nice already. Stay tuned.
Name:	1953 right side.JPG
Old 09-17-2015, 09:07 AM   #62
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
How long is she? I like the fact that she has 2 axles unlike a lot of the long vintage traylas😊.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 09-18-2015, 07:50 AM   #63
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
For any Vintage
http://www.airstream.com/wp-content/...44fe50e51b.pdf
Old 09-22-2015, 08:32 PM   #64
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Liner floor work slow but sure
I have cut the 3/4 inch floor boards and painted with high grade porch paint for weather proofing I then coat the edges with a smoothed out Tempro sealant. I take the cut to size floor board and use it as a forming template for the .032 aluminum belly pan.
Name:	floor edge  seal Tempro.JPG
ID:	248756   Click image for larger version
Name:	curved belly pan eedge flutes.jpg
Name:	belly pan and floor board sizing.jpg
ID:	248758   Click image for larger version
Name:	belly pan edge work.JPG
Name:	floor board and belly pan.JPG
Old 09-22-2015, 08:38 PM   #65
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
frame clean up and POR
Frame was in great condition....except for the rear crossmember
Name:	floor replacement 2.jpg
ID:	248762   Click image for larger version
Old 09-24-2015, 06:47 PM   #66
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
You have made the frame look new. 3/4 subfloor and .032 belly pan. You build them to last. Great idea to use the cut to size floor as a forming die for the belly pan curve. I had much difficulty with the rear curved belly pan segments on my 66. I used .025 material instead of the .032. The fronts were the formed aluminum "banana wraps" that take the difficulty out of forming the compound curves. the 86 has plastic banana wraps in front making the job even easier once the mold is made.
There is a lot of good work that goes on in the red barn of yours.
David
Old 09-25-2015, 08:00 AM   #67
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
As I repair damage from a tire blowout I offer this suggestion. While you can, replace the wheel wells with sturdy steel. The thin galvanized wells do not hold up well to a tire thrashing. Also just behind the wheels reinforce the floor. Maybe screw a steel sheet to bottom of the floor.
FC7039 is offline   Reply With Quote
Old 09-25-2015, 08:39 AM   #68
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Good advice for when doing a rebuild. I have considered that.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 09-28-2015, 04:31 PM   #69
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
floor boards an fit
I am using 3/4 inch scrap wood to hold the side wall and floor spacing. This seems to be the most difficult task so far.
Name:	floor board side wall spacers.JPG
ID:	249249   Click image for larger version
Name:	All floorboards cut and fit..JPG
Old 10-05-2015, 09:09 AM   #70
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
carriage bolt installation
This might be a tip to some. In order to have a flush floor for final work I had to have a way to flush the carriage bolt head. Hammer just did not do it. So I used a hole saw and cut a 1/8th inch deep , +/-, groove. Then a chisel out the center piece. The carriage bolt now can be hammered in flush.
Name:	floor work looking aft.JPG
ID:	249720   Click image for larger version
Name:	floor carriage bolt work.JPG
Name:	floor work carriage bolt installed.jpg
Old 10-05-2015, 11:37 AM   #71
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
slight diversion
I have to watch the weather here in Texas. I figured I should strip the end caps before the first freeze coming here in three or four weeks. Do the outside work while I can. Then things move inside the Red Barn. I am using Citristrip. I usually use Aircraft Stripper, but will try this now.
Name:	End Cap stripping #1.JPG
ID:	249749   Click image for larger version
Name:	End Cap stripping #2.JPG
Old 10-05-2015, 05:01 PM   #72
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Great idea on "counter boring" the carriage bolt heads. I used carriage bolts and hammered and ground them flush the best I could. I suppose I should have purchased "elevator bolts". I also had trouble getting the carriage bolts tight. I elected to use lock nuts. So I ended up cutting a screw driver slot in the head of the carriage bolt.
Actually with your idea to counter bore. You could bore the hole big enough to get a thin wall socket in there. And then use a regular hex head bolt and not have the trouble I had. Or use a smaller counter bore and then a socket head cap screw and an Allen wrench to hold the bolt steady while tightening it from the bottom.
I need to learn how folks bolt their subfloor and c-channel with elevator bolts.
David
Old 10-12-2015, 06:27 PM   #73
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
still on the floor and pan
Still fastening the floor to the frame and the shell to the floor/frame.
ID:	250291   Click image for larger version
Name:	Floor front.JPG
Name:	Floor at entry.JPG
ID:	250293   Click image for larger version
Name:	Floor under.JPG
Old 10-12-2015, 09:57 PM   #74
mapleton , Utah
I have a polishing question Robin.Since you have done way more 55's than I ever intend to, what is the sequence you've worked out? I have started with the caswell black compound on a vented wheel and I do have a cyclo available when I get to that point. So what do I do in between?
BTW- the bronze window screens look awesome!!!!
keep up the great work
tim
rumrunner is offline   Reply With Quote
Old 10-13-2015, 12:43 PM   #75
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
end caps
Finished up the stripping of the caps....that was not fun or easy. Twice around with Citri strip then brass brush, Aircraft stripper and aluminum wool. Now I have the cap braced up and I am starting the polish.
Name:	end cap first cut.JPG
ID:	250381   Click image for larger version
Name:	end cap first cut #2.JPG
Name:	End cap ready to polish.JPG
ID:	250383   Click image for larger version
Name:	End cap ready to polish #2.JPG
Old 10-13-2015, 04:38 PM   #76
Becky B.'s Avatar
1964 17' Bambi II
Looking good, Robin! I do recall that being a huge pain! You're making great progress, as usual :-)
Becky
1964 Bambi II
1988 Avion 32S
Old 10-19-2015, 12:02 PM   #77
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Endcaps update
Got the Jetsco yellow wheel first and the Jetsco sisal with red bar done. Then, for the heck of it a quick wool pad check with the new Vintage Trailer Supply medium grade polish.
ID:	250655   Click image for larger version
Old 10-26-2015, 07:52 PM   #78
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
todays fill in work
Before I do the finish up un the belly pan I thought I could do the busy work. I used the VTS product Airbright coarse...to start the polish of the newly stripped cabinets. The inside floors of the cabinets were very difficult because of accumulated food spills, etc.
Name:	front cabinets.JPG
Old 10-31-2015, 04:23 PM   #79
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
OK...so starts the arguments. Insulation
Again....I will just use this forum area to paste in information I plan to use. I am looking at Prodex applications, rock wool/aluminum faced duct material and closed cell foam. Here we go...Stay Away from Foil-Faced Bubble Wrap | GreenBuildingAdvisor.com
Old 10-31-2015, 04:55 PM   #80
FC7039's Avatar
Allen , Texas
Red Barn Liner
Try this and let's us know how it works. http://www.amazon.com/BrickWood-Oven.../dp/B00L9DOJ8Q
http://inspectapedia.com/Energy/Insulation_Ceramic.php
In my tests the two things that make the most difference is the conduction of the ribs and the other thing is how clean and shiny the skins are. Not the the side you see but the inner sides. For the same reason that insulation is foil lined your inner sides should be shiny. This is to deter radiant heat. You will need air space as anything that touches conducts.
The sunlight hits the outside. White reflects this radiation best. But it will get hot. This heat will radiate, conduct and convect through to the inner skin. The inner skin will radiate it or convect it to you. Shiny aluminum surfaces radiate less than painted surfaces.
Maybe you can replace your roof ribs with homemade molded carbon fiber ribs 😄 a joke but I bet a better solution.
Red Barn Safari Melody Ranch 1955 Safari 101 01-29-2019 10:59 AM
Red Barn visitors Melody Ranch Cleaning, Stripping & Polishing 72 09-09-2013 01:10 PM
1947 Liner - "1006" :: 1947 Airstream Liner wdscentral Airstream Registry Discussions 0 09-05-2013 05:16 PM
1953 Liner :: 1953 Airstream Liner 57BB Airstream Registry Discussions 0 07-16-2013 04:05 PM
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 01:18 PM
