Old 08-24-2015, 06:56 AM   #41
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Originally Posted by Melody Ranch View Post
photo upload seemed slow but worked.
Kip, is this what you were referring to
yes
Old 08-24-2015, 04:01 PM   #42
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
floor wood out
I took only the from two pieces of flooring out so I could replace the plywood. I found the nest for the Hornets which have attacked me since getting home with the Liner. The hold down bolts in the C channels seem to be my only real problem as of now.
Name:	front floor section 1 & 2.JPG
ID:	246242   Click image for larger version
Name:	floor removed front two pieces.JPG
Name:	Black Hornet nest..JPG
Old 08-25-2015, 06:38 PM   #43
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I was trying to think of all the ways we have removed rusted bolts.
Grind the head off
Drill the head off
Bolt cutters
Cutting torch
Plasma torch
I had access to the bolts from the bottom of the rear C channel of my 66 Trade Wind. The vice grip and "wiggle" method worked good for me.
I hope some one will step forward for a solution for you.
David
Old 08-25-2015, 09:24 PM   #44
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Front frame section
The bolts in the C channel are inserted from the bottom and the nut is on from the top....in the channel I can't get the vice grips in there to wiggle and break. I got all the others out and POR (Chassis Saver) the exposed frame.
Name:	POR frame.JPG
ID:	246390   Click image for larger version
Name:	POR frame 3.jpg
Name:	painted A frame.JPG
Old 08-26-2015, 01:53 PM   #45
calais66's Avatar
1951 21' Flying Cloud
Sacramento , California
Red Barn Liner
Maybe an ocillating tool? Cut the bolt in the middle and remove from the top and bottom (assuming they're not rust-fused to the frame). Outside of cutting a slot in the lip of the channel to facilitate vice grips and then patching it up, that's all I can think of.
When I removed mine, I put a wrench on the head of the bolt (inside the channel) and was able to break them by working them from below, using the outside of the channel to keep the wrench stationary.
calais66 is offline   Reply With Quote
Old 08-26-2015, 10:10 PM   #46
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Thanks to all. I think I have it working now.....Needle nose vice grips.
Old 09-02-2015, 12:30 PM   #47
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
floor replacement
In order to remove the old floor easily (somewhat more easily) after I cut the hole saw sections away from the carriage bolt heads, I run a saw, set to the floor thickness, right down the middle of the whole floor. I can now work with a smaller old floor board section. I also use the removed sections to verify the patter I made for the new floor wood.
Name:	1:2 floor technique.JPG
ID:	247041   Click image for larger version
Name:	floor front section.JPG
Old 09-03-2015, 09:30 PM   #48
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
floor progress
The front belly pan and C channel with the front body hold down were the focus today. I got it all out and played out for reproduction tomorrow or day after. I go to Fort Worth to get my belly pan aluminum.....seven sheets on the Liner. The new flooring is cut to approximate fit and painted. I usually coat the edges of the flooring with a coat of 635 for water proofing. The body hold down was remade with aluminum angle.
Name:	new flooring.JPG
Old 09-08-2015, 09:30 PM   #49
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
into the liner
The first two floor pieces are being fitted now. I am having some trouble with the hold down plate....new hold down plate.
Name:	3:4 in new flooring..JPG
Old 09-08-2015, 10:51 PM   #50
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
Amazing progress!
When I cut out the ones on the 63, I used one of the high speed osculating saws. I put vice grips on the top of the bolt sticking up and plunged under the c channel and it cut pretty fast. Helped that they were really rusty and broken down. Chewed up a few blades but worked ok.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 09-10-2015, 09:35 AM   #51
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Top to bottom
The floor work continues. I needed a break to think the front belly pan/floor/shell connect up front, so I removed the AC in prep for the wiring and drain tube install coming up. Dilemma now is....should I replace the well working old AC unit now or wait till it does an age related self destruct.
Name:	1953 Liner AC opening #2.JPG
ID:	247774   Click image for larger version
Name:	1953 Liner roof.JPG
Name:	floor work front.JPG
ID:	247776   Click image for larger version
Old 09-10-2015, 10:46 PM   #52
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
You should wait on the AC until a good hot August day when your 1000 miles from home.
FC7039 is offline   Reply With Quote
Old 09-11-2015, 06:22 AM   #53
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
That answered that....Looking for the new AC today.
Old 09-11-2015, 07:43 AM   #54
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Was the old one an Armstrong?
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 09-11-2015, 04:42 PM   #55
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
Never mind-I see in the pic it was not
Bruce
Old 09-11-2015, 04:49 PM   #56
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I was going to check for you....I thought it was a Coleman. It does work well and is cleaner than I would have imagined.
Old 09-11-2015, 07:16 PM   #57
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
That is what it looks like
Bruce
Old 09-12-2015, 10:18 AM   #58
FC7039's Avatar
Allen , Texas
Don't let my joke make your decision. I do not know much about ACs and what could be wrong. One issue and I am not sure it is an issue is the coolant used it the AC and what is available today. But if the AC needs coolant then it probably has issues with seals
Old 09-17-2015, 06:35 AM   #59
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
repair and mouse proof same time
I chose to replace the rear crossmember of the frame because it had the typical vintage chaffing where the frame rubbed the belly pan curve. There was significant rust where the floorboard rested on the top of the crossmember too. I removed the center portion of the belly pan for access and torched the crossmember out. Four small cuts is all. The new 4 inch channel was modified, a bit, by extending the ends to fit inside the side rails of the frame and blocking off the famous critter entry passages along the frame. It all fit perfectly and will be POR'd this morning.
Name:	Rear crossmember replacement.JPG
Old 09-17-2015, 06:49 AM   #60
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I don't know how I missed your latest project, but I'm so glad I stumbled upon it! I love your new Liner & will love watching your progress! That's a biggie compared to most of your projects. Are you keeping this one for yourself? It'll be amazing, I'm sure!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Red Barn Safari Melody Ranch 1955 Safari 101 01-29-2019 10:59 AM
Red Barn visitors Melody Ranch Cleaning, Stripping & Polishing 72 09-09-2013 01:10 PM
1947 Liner - "1006" :: 1947 Airstream Liner wdscentral Airstream Registry Discussions 0 09-05-2013 05:16 PM
1953 Liner :: 1953 Airstream Liner 57BB Airstream Registry Discussions 0 07-16-2013 04:05 PM
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 01:18 PM
