Old 08-05-2015, 09:47 PM   #21
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I tried to work thru it
I got an early start today...nearly died in the heat of the Airstream shell out in the Sun. 105 deg is what the radio said....123 degrees on the thermometer inside where I was trying to work. I quit.
ID:	244696   Click image for larger version
Name:	deconstruct in the heat.JPG
Old 08-12-2015, 10:44 AM   #22
whitsend's Avatar
1954 25' Cruiser
Kyle , The Republic of Texas
So cool, and progress going so fast. Typical Robin. I'll be following this one!!
I love that old time rock & roll.
whitsend is offline   Reply With Quote
Old 08-12-2015, 10:52 AM   #23
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Robin,
Per your request I've moved your thread to the 50-56 Liner subforum. I left a redirect in the earlier Liner subforum that will point to this new location for a couple of months, so for that time it'll appear to be in 2 places.
David
Old 08-13-2015, 04:16 PM   #24
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Thanks David.
Old 08-13-2015, 04:27 PM   #25
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
That is a beautiful trailer and a great project. I wish I was closer - I'd lend a hand just for the experience. Are you planning to lift the body, or just replace floor segments?
No WD, but a great DW!
robert claus is offline   Reply With Quote
Old 08-13-2015, 05:27 PM   #26
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
It is nice to be appreciated
Well, thanks. I wish you were, in fact , closer. Today I finished pulling the bath/shower area out. I am glad I did too. Pictures tomorrow. A few more interior skinks can now be accessed and removed.
Old 08-13-2015, 07:17 PM   #27
65CV's Avatar
Western , Massachusetts
Just found this thread.
I doubt I was the only one on this forum going through "Melody Ranch Thread Withdrawl Syndrome".
Very cool to watch. Thanks for the fix!
65CV is offline   Reply With Quote
Old 08-13-2015, 09:49 PM   #28
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
some progress made
I did get the entire bath/toilet/shower out. What a mess to work with. There was no black tank, just a straight poop chute out the bottom. A home made shower pan of fiberglass over a real mortar leveling base (completely disintegrated) silicon all edges and corners. Original stainless pan screwed to the rotted out floor. Window siliconed inlace...maybe two whole tubes. Lights were wired with an old extension cord fed thru the wall and siliconed between the stainless and a shower board liner. Pictures tomorrow.
Name:	bath shower room.JPG
ID:	245424   Click image for larger version
Name:	Texas working temps.JPG
Old 08-16-2015, 11:43 AM   #29
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
What lurks below....
You see, I had suspicions based on the "coverup" work I could see. The bath area looked so nice I was going to work around it. Then I got the heebie jeebies and decided to do it right....glad I did. Not that big a deal now that it is all opened up. I have all the plywood flooring standing by and cans of Chassis Saver (I use instead of POR) and floor sealer/paint. Here we go.
Name:	floor under shower:toilet.JPG
ID:	245604   Click image for larger version
Name:	floor under shower:toilet 2.JPG
Old 08-16-2015, 12:13 PM   #30
1999 25' Safari
Somewhere , Ohio
Hi Robin! I, too, just found this new thread, and look forward to following along.
We are just now in the process of talking about getting back onto our '56 Bubble, we've had a great deal of family issues as well as work to deal with.
Your Red Barn Liner project is exciting!
Deb
Air Cruiser is offline   Reply With Quote
Old 08-18-2015, 12:49 PM   #31
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
slow but sure in the heat
Finished up the interior skin and old insulation removal. Nasty. Even with a face mask I end up coughing. No mouse or insect evidence, which surprises me. I did find evidence of attempted leak control at both end caps. I have no idea what the white plastic looking stuff is which was used on the seams. More clean up and then the wood floor removal.
Name:	interior skins gone.JPG
ID:	245775   Click image for larger version
Name:	end caps out.JPG
Name:	attempt at leak control.JPG
ID:	245777   Click image for larger version
Name:	aft deconstruct.JPG
Old 08-18-2015, 01:13 PM   #32
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Look at that allow number 24S-T3, the for runner to 2024
Old 08-20-2015, 12:27 PM   #33
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
test
photo upload seemed slow but worked.
Kip, is this what you were referring to
Name:	24S-T3  .032 skins.jpg
ID:	245880   Click image for larger version
Name:	Aluminum skins.jpg
Old 08-20-2015, 12:31 PM   #34
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Here you go....a complete AC electrical wiring.
I pulled all the AC today. The 12v system seems to be only theater, running and brakes. This was a Liner made for Park use only.
Name:	1953 Liner electrical system AC.JPG
Old 08-20-2015, 04:01 PM   #35
mapleton , Utah
Gotta love the taped connections on the old wiring. Mine had several shorts to the shell. Glad to see you have another great project going.
tim
rumrunner is offline   Reply With Quote
Old 08-20-2015, 06:09 PM   #36
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
where you been?
Good to hear from you Tim. I hope the Cloud is still moving along with help from Cleco.
Old 08-21-2015, 12:35 AM   #37
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Melody,
So was my Liner, all 110V and no ground. Connections inside the skin, scary.
Bill
Just my personal opinion
Old 08-21-2015, 09:38 PM   #38
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Floor removal info
I asked Friends if there was any secrets they had for floor removal. Nope, just do it. So I used my old hole saw method of cutting around the carriage bolt head to expose the head for vice grip bend and snap off technique. Because hole saws have a center drill for alignment and stability I had to modify my saw to be used without the drill bit center. Doing that now requires some sort of stabilizing guide to keep the saw from traveling. I made a guide and placed it over each carriage bolt head and sawed away. I did have to use my circular saw and clear a path thru the floor covering over the carriage bolts. I think the pictures show all of this.
Name:	carriag bolt removal technique.JPG
ID:	245981   Click image for larger version
Name:	Floor tools.JPG
Name:	carriage bolt removal.JPG
ID:	245983   Click image for larger version
Name:	floor tools 2.JPG
Old 08-23-2015, 05:33 PM   #39
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Nice drill guide you made there Mr. Ranch. I especially like the twin size 11 clamps. Solid.
Hole saws are nice tools. You can pilot with the drill bit, or pilot with the od of the hole saw. The guide I made was not as clever as yours. It was only a single size 10 clamp. I can't remember what I used it for. Getting old!
When I did my Trade Wind subfloor under the bath, I just grabbed the bent elevator bolts with my vice grip from underneath the trailer and wiggled a bit. Snap, bolt is gone. Air Forums folks taught me that one.
David
Name:	1501 Hole Saw Guide.jpg
Old 08-23-2015, 06:55 PM   #40
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
The hole saw guide
The guide is a life saver. I have most of the elevator bolts clear and ready to remove from the bottom. If ANYBODY has a good idea on the elevator bold removal from the C channels....let me know. I have the first front floor panel out. now.
Red Barn Safari Melody Ranch 1955 Safari 101 01-29-2019 10:59 AM
Red Barn visitors Melody Ranch Cleaning, Stripping & Polishing 72 09-09-2013 01:10 PM
1947 Liner - "1006" :: 1947 Airstream Liner wdscentral Airstream Registry Discussions 0 09-05-2013 05:16 PM
1953 Liner :: 1953 Airstream Liner 57BB Airstream Registry Discussions 0 07-16-2013 04:05 PM
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 01:18 PM
