Originally Posted by submariner
Hi guys. I need some help identifying an old airstream. From the shell and length it looks like an old Liner with pipe frame . The vin is only partially on the type plate.. Someone drilled though the forth number..
The first three are 126 . It is California made .Any help here ? I hope to verify that it is a 48.
Hi, I am maintaining a list of all known still existing pipe frame Airstreams. There are currently none known with serial numbers between 1249 and 1276, so I would very much like to see a photo of your serial number plate, even if it is missing the last digit. I would also love to see other "as found" photos of the trailer.
My current best guess after years of research is that the
1948 model year ended at approximately SN 1250 or so and that the 1949 model year began about SN 1275 or so based upon no known Liners with serial numbers in the 1250s or 1260s, but that is just an educated guess. Airstream 22-foot serial numbers began at 1000 or 1001 in May 1947 and continued to at least 1484 in 1951 (skipping the 1300s, though). Excepting the 1300s, there are known existing 22-footers with serial numbers in every series of ten (e.g. 100X, 101X, . . . 124X, 127X, . . . 148X, etc.) except none currently known in the 125X and 126X series, which is hard to explain.
If yours is really in the 1260s, I suppose it could be a very late
1948 or a very early 1949 model, but either way built in about September or October 1948.
