Old 09-09-2016, 09:39 AM   #1
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Pipe frame, modify or replace
We just purchased a 51 clipper. It spent most of its life in the desert and the frame pipe and connections look virtually new. The full restoration is at least a year out if not more but in the meantime trying to figure out the best route to go.
I've seen extensive aluminum c channel frames and retrofitted and rebuilt pipe frames. I've considered welding on steel bolt flanges to strengthen the outriggers and adding full length steel for the suspension attachment points but wonder what others have done, how it's held up etc. not great pics but here it is.
Name:   ImageUploadedByAirstream Forums1473435412.375406.jpg
Name:	ImageUploadedByAirstream Forums1473435429.771027.jpg
ID:	271300Click image for larger version
Name:	ImageUploadedByAirstream Forums1473435451.242883.jpg
ID:	271302Click image for larger version
Name:	ImageUploadedByAirstream Forums1473435473.109571.jpg
Name:   ImageUploadedByAirstream Forums1473435496.355068.jpg
Name:   ImageUploadedByAirstream Forums1473435552.567463.jpg
PS the awesome shop was the seller's facility. Wish it was mine!!
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 09-09-2016, 10:34 AM   #2
goransons's Avatar
1963 22' Safari
Name:	ImageUploadedByAirstream Forums1473438813.663497.jpg
ID:	271310Click image for larger version
Name:	ImageUploadedByAirstream Forums1473438828.687250.jpg
ID:	271311Click image for larger version
Name:	ImageUploadedByAirstream Forums1473438850.914280.jpg
ID:	271312Click image for larger version
Name:	ImageUploadedByAirstream Forums1473438861.786478.jpg
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 09-09-2016, 10:39 AM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I guess it all depends if you plan on putting in underfloor tanks.
Old 09-09-2016, 10:58 AM   #4
goransons's Avatar
1963 22' Safari
I'd love to tuck in a couple gray water tanks, figure we are going to put in a very small powder room for middle of the night needs only with an above the floor black tank. Gray would likely be in the kitchen area near the axle.
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 09-09-2016, 11:05 AM   #5
goransons's Avatar
1963 22' Safari
I should add, the serial range is #22XX, I think that puts it as a '51 is that correct?
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 09-09-2016, 12:46 PM   #6
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Hi Scott:
After a cursory look on the internet, I have been unable to locate any listing of serial numbers for Silver Streak Clipper travel trailers. But here are two web sites to peruse at your leisure:
http://tompatterson.com/Silverstreak/Pictures/Units.php
http://tincantourists.com/wiki/doku....=silver_streak
The birchwoodbeauties web site seems down, as I was directed to an unrelated web site when trying to reach it:
http://www.birchwoodbeauties.com/pag...r-corning.html
You also might try to contact the Silver Streak Trailer Club, 226 Grand Ave. #207, Long Beach, CA 90803, 310-433-0539, for serial number infomration.
Have fun with your new aluminum beauty!
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 09-09-2016, 08:03 PM   #7
goransons's Avatar
1963 22' Safari
Thanks for the info. I've reached out on those as well. Did some initial cleaning with a respirator and removed over 30 lbs of rat pellets. Smells better already. The rat urine smell is on the metal. I sprayed everything down with pinesol to disinfect every surface I could and to help deodorize.
Name:	ImageUploadedByAirstream Forums1473472843.811403.jpg
ID:	271348Click image for larger version
Name:	ImageUploadedByAirstream Forums1473472866.321851.jpg
ID:	271349Click image for larger version
Name:	ImageUploadedByAirstream Forums1473472892.985574.jpg
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 10-18-2016, 12:00 PM   #8
1951 18' Clipper
Seminole , Florida
Scott - Noticed you said your serial number was 22xx. I have a 1951 Silver Streak Clipper Model 7 20 Foot Trailer Floor Plan # 1 that has serial number 2233 on it - picture attached. I am very curious as to the exact number on yours, can you share the last 2 digits? I just inherited this one when my dad passed at the beginning of this month. It has been in the family since it was purchased new in July 1951. It is very rough, but in pretty much untouched original condition. Floor is very rotten. It's name is Merlin and it is currently located in Florida. Was in Ohio from 1951 until 1985. Dad acquired it and towed it from Ohio to his place in Florida in 1985. It was his dream to restore it, but sadly, he never got the chance. Let me know if I can provide any info from mine that would help with yours. I am just starting to look at mine and trying to figure out what to do with it. I have no want to restore or use it myself, but dad loved Merlin so much, I must find a good place for him to go very soon.
ID:	273731   Click image for larger version
Melin is offline   Reply With Quote
Old 10-18-2016, 07:47 PM   #9
goransons's Avatar
1963 22' Safari
cool!
Welcome to the forums! I just sent you a private message. Ours were probably on the assembly plant floor the same day. I sent you that info, I would love as many interior pictures as you can. As you can see the front and back areas inside on ours were torn out and although I plan to reconfigure the back for a small powder room, the front area I'd like to get close to original.
Very cool trailer you have!
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 10-18-2016, 08:02 PM   #10
Bluestar99's Avatar
Bartlett , Illinois
I have a 51 Clipper #2175. Almost 100% original. In the process or restoring. I'll be happy to help with questions or pictures.
Bluestar99 is offline   Reply With Quote
Old 10-18-2016, 08:06 PM   #11
goransons's Avatar
1963 22' Safari
Thank you!
Yes while I'm financially a ways out on starting the project, I'm trying to plan long ahead and start to collect the parts I need. Glass in the door is missing, and it's really unclear what held it in originally, can't tell if it had wood stops (bits of wood remain, but could have been a hack repair job) or if it had sheet metal stops, or a combo of layers.
Also not sure what the original refrigerator cabinet looked like, just a few rivet holes remain, as well as the original dinette configuration, including the cabinets under the front and rear windows.
Also quite odd, almost all the rivets on ours are gold, inside and out, most have faded due to pitting. I'm going to be putting in plexi soon to keep the weather out this winter, but going to have some issues repairing some cracked front and back window trim. Pointers are greatly appreciated!
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 10-19-2016, 05:10 PM   #12
Bluestar99's Avatar
Bartlett , Illinois
Thank you!
The window in the door is plexi glass. It has what may be wood or a dried up rubber gasket between the plexi and the front of the window. There appears to be a sealent as well. The backside has an L shaped molding riveted in.
I do not have a refridge cabinet. Mine is a Marvel , electric only and it's just in between the closet and the stove. If you want any pictures just PM me, with what you need. I don't want to hijack this thread.
Old 10-19-2016, 07:20 PM   #13
goransons's Avatar
1963 22' Safari
Thank you! I'd love some pictures of the refrigerator and how it sits. Mine would have been by the door on the curb side. Haven't seen that layout, may have been somewhat custom or I haven't seen every option out there yet. I'll pm you. Thanks!
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
How to modify and install rock guard on Minuet Janet H All Argosy Trailers 72 09-09-2015 11:44 PM
Cabinets - modify, replace or what? drboyd Cabinets, Counter Tops & Furnishings 18 02-27-2015 03:01 PM
Rebuilding 65 rear end to modify or not to modify? tbrom Repairing/Replacing Floor &/or Frame 4 06-21-2007 08:53 AM
Can I modify my classified ad? twopips Forum Admin, News and Member Account Info 1 08-29-2005 05:44 PM
How to modify toilet for long term fixed usage? haynes Waste Systems, Tanks & Totes 0 05-26-2004 04:31 AM
