Old 11-07-2019, 08:08 AM   #21
New Airstreamer
2020 22' Caravel
Somerville , Ohio
Thanks, Jason. I really like the floorplan of the 20FB but with three dogs, needed all the space I could get. I'm in Ohio, so our AS is put up for the winter. Part of me just wants to leave well enough alone and part of me wants to try out an HDMI audio extractor so I can use the HDMI ARC on the TV.
Counting the minutes until spring....
malicoreon is offline   Reply With Quote
Old 11-07-2019, 11:25 AM   #22
Dallas , tx
I wasn't aware of the HDMI audio extractor so I looked into that.
You are trying to get over air TV channel audio to come out of your speakers, correct? You will need to get a signal from the TV to the stereo without running additional wires.
You have upgraded your TV to have audio outputs on the back. You shouldn't need an HDMI audio extractor for that. You can plug in a Bluetooth transmitter to the back of your TV audio out and wirelessly transmit your over air television back to the JL stereo.
You may be talking about extracting audio from HDMI from the DVD to the JL stereo though vs using the already existing digital audio out.
Jason in TX is offline   Reply With Quote
Old 11-08-2019, 04:09 AM   #23
New Airstreamer
2020 22' Caravel
Somerville , Ohio
Thanks Jason, you are correct. I'd like to get the TV (and the DVD player) to play over the speakers, preferably without running wire. Another poster mentioned that HDMI ARC would play any audio it sees. I had assumed that the TV would have to be switched to HDMI (the DVD player, in my case) to have any audio to pass. The extractor would provide a mechanism to connecting that audio to the JL system's RCA ports.
Realistically, I doubt I'll be watching many DVDs. I upgraded to a smart TV so I would be able to watch Netflix, Prime, etc. IMO, DVD players are getting to be like CD players in that physical media isn't as popular or practical anymore.
I read about bluetooth transmitters in other posts on Airforums and there was mention of latency, enough to be distracting. I guess another option is to just suck it up, get a digital audio converter and run optical cable to it. Those cables are thin and small enough to not draw the eye. I'm not sure if I'd want to keep it coiled up when not in use as I understand it's fiber and subject to breakage.
Finally, I could get a soundbar, but to me that's something else to haul and potentially get banged up. Plus I would just like to use the nice system already in the camper.
With all that said, I'm going to revisit your post and read up on the items you so kindly linked. Thanks again for your feedback, I really appreciate it!
caravel
« New 2020 Caravels | Top | - »
Buying 2020 Caravel 20FB - Which Blue Ox for 2016 F150 Limited? Jason in TX Towing, Tow Vehicles & Hitches 15 09-07-2019 01:13 AM
Now time to add a 2020 Caravel Section Jason in TX 1980 Caravelle 0 08-20-2019 05:51 PM
the 2020 caravel 22FB walkthrough waninae39 2005 and newer - Bambi all models 1 06-08-2019 03:56 PM
New Caravel 16 2020 coming in June looks nice iCjay 1969-1971 Caravel 0 05-30-2019 07:31 PM
adding ext overhead light for 22Fb waninae39 2005 and newer - Bambi all models 2 10-17-2018 07:34 PM
